  bingsatellites Mostly Ambient
 Forum index » Clavia Nord Modular » Wish List
Pitch Down different then UP like Nord 3
Page 1 of 1 [8 Posts]
Do u want to add this option to G2 ?
yes
66%
 66%  [ 2 ]
no
33%
 33%  [ 1 ]
Total Votes : 3
Infected
PostPosted: Tue Feb 13, 2007 11:42 pm    Post subject:  Pitch Down different then UP like Nord 3
Subject description: Up+2 Down-24
It will be great if G2 will have the option like Nord 3.
that pitch bend up can be set different then Pitch Down.
For example i want to set pitch Bend up to 2 and pitch bend down -24
of course i can create an alternative preset using modulation as -24 and pitch bend as +2 -2.
but i want to have the modulation for cutoff and pitch bend for pitch.
I hope that some of you think the same Smile
THanks
jamos
G2 patch files: 35
PostPosted: Wed Feb 14, 2007 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
The beauty of a modular system is that this can be done through programming. Here's an example (not fully tested)
A sub-patch for scaling positive pitch bend to 4x the range of negative bend
 Filesize:  11.56 KB
 Viewed:  5517 Time(s)
Infected
PostPosted: Wed Feb 14, 2007 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, i couldn't get it to work,
i also emailed long ago to clavia and they sent me a patch that didn't work.
is there a chance you can upload the patch ?
Pitchbend up +2 / Down -24
Thanks
G2 patch files: 584
PostPosted: Wed Feb 14, 2007 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a patch that does something similar, see block in red. Remember the patch settings PB amount has no effect on the device module.
guitar0023.pch2
 Filename:  guitar0023.pch2
 Filesize:  3.62 KB
 Downloaded:  813 Time(s)
davep
Audio files: 10
G2 patch files: 73
PostPosted: Wed Feb 14, 2007 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
The diode idea is what I was picturing. That should work. Note that you can use a pair of simple LevAmp modules set to different amounts instead of the NoteQuant modules.
Dave Peck
G2 patch files: 584
PostPosted: Wed Feb 14, 2007 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is a little dodge for natural vibrato, but not as bad as I expected. The note quant gives a nice easy range setting. A two input mixer in lin mode might be the cheapest option.
Infected
PostPosted: Wed Feb 14, 2007 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks g2ian .
it works,
i dont know why clavia did add this option in the core of the machine.
why to reduce options from an older model like nord 3 ?
it will help me alot! thanks.
davep
Audio files: 10
G2 patch files: 73
PostPosted: Fri Feb 16, 2007 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Keep in mind that you can also process ths signal through shaper modules etc. to get different responses from the pitch stick. Some combinations may result in a more natural 'feel'.
Dave Peck
