  bingsatellites Mostly Ambient
help please! testing the tm 3 without Hz/cv
Page 1 of 1 [4 Posts]
erich
PostPosted: Fri Feb 23, 2007 6:42 pm    Post subject: help please! testing the tm 3 without Hz/cv Reply with quote  Mark this post and the followings unread
I just bought a tm 3 on ebay because it was a good deal, even though I have no midi to cv converter. I have a vx 351 for my moog voyager, but I just found out that this wont operate the tm 3 because it operates using Hz/cv instead of octave/cv like the moog will output. I don't know if I will be able to get a midi to cv converter that does this for a while. I kind of screwed myself. Does anyone know a way I could test the tm 3 just to see if it is working properly when I get it? I don't even need to operate it musically yet, but I want to know if it is working when I get it. Any suggestions?
Muff Wiggler
PostPosted: Fri Feb 23, 2007 9:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
no suggestions
(although you can drive the TM-3 with a guitar or bass signal, and get a crazy distorted signal) if you can tune the two oscillators using the knobs on the TM-3 while sending a signal through it, it's probably working fine
if you are looking for a cheap midi-to-cv that will work the kenton pro-solo mk.1 works great, and i got mine used for about $100
or you can also get the synhouse midijack II for $129 and built a little enclosure for it
The cake is a lie.
deknow
PostPosted: Sat Feb 24, 2007 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
...or you can look up the specs of what the voltage range this beast is looking for, and just wire up a battery and a pot to a jack. this won't test tuning, but it will tell you if it's responding to the cv.
deknow
thermionicjunky
PostPosted: Sat Feb 24, 2007 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just patch one of the cv outputs of the vx-351 through an attenuator and into the tm-3. If you limit the voltage range to to the usable range of the tm-3 , it will be quite easy to control. Try the wheels , pedals , lfo and s&h. You could also run the voyager's signal into the tm-3 for fm effects.
Niio1
