  Various Artists electro-music.com March Equinox Concert
Blocked Shreds?!?! What does this mean?
Page 1 of 1 [18 Posts]
sir honey
PostPosted: Tue Feb 27, 2007 10:11 am    Post subject:  Blocked Shreds?!?! What does this mean?
Subject description: MIDI control in this program seems to f%cK with my ChucK
So I'm pretty excited to do this gig on a local radio station this weekend. I really want to use chuck for some sampling and messing around. I've started to write this program:
Code:
// here we go MIDI implementation
//jack ryon 2007
SndBuf samp1 => Echo echo1 => dac;
"/andyloops/dnb/DN078B~1.WAV" => samp1.read;
10::second => echo1.max;
0 => echo1.mix;
1 => samp1.loop;
0 => samp1.play;
2 => samp1.interp;
float playrate;
MidiIn min1;
MidiMsg msg1;
min1.open(2) => int minopen1;
if(!minopen1) me.exit();
MidiIn min2;
MidiMsg msg2;
min2.open(1) => int minopen2;
if(!minopen2) me.exit();
while(true)
   //-------------CONTROLS FOR OXYGEN8 KEYBOARD--------------//
   min1 => now;
   while(min1.recv(msg1))
      <<<msg1.data1,msg1.data2,msg1.data3,"MIDI OXY!">>>;
      //----sample playback rate (MOD CTRL ON OXYGEN)----//
      if(msg1.data1 == 176)
         if(msg1.data2 == 1)
            64.0 => float ratediv;
            (msg1.data3/ratediv) - 1.0 => samp1.rate;
            samp1.rate() => playrate;
            <<<(msg1.data3/ratediv) - 1, "playback rate">>>;
      //----TURN OFF PLAYING SAMPLE (MID C ON OXY8)----//
      if(msg1.data1 == 144)
         if(msg1.data2 == 60)
            if(msg1.data3 != 0)
               0 => samp1.play;
   //-------------CONTROLS FOR FCB1010 FOOTSWITCHER-------------//
   min2 => now;
   while(min2.recv(msg2))
      <<<msg2.data1, msg2.data2, msg2.data3, "MIDI 1010!">>>;
I can compile this, but after moving one MIDI control knob, the program freezes. When I query chuck [chuck ^] it tells me that the shred has been blocked. What does this mean? What can I do to get this thing up and running? Is there a more efficient way to write this (if that is what my problem is)?
Help?
jack Shocked
spencer
PostPosted: Wed Feb 28, 2007 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey jack,
I think your problem here is that you are running the code for your two MIDI controllers alternating in sequence, when you probably want to be running them in parallel. To do this, you have to separate the code for the two controllers into two functions, one for each controller, and then spork those functions into new shreds. See below for a short outline. You can still access all of your ugens and variables from within the functions, so you can pretty much just copy and paste your current code into the function bodies without too much editing.
Itd definitely be worth reading the relevant portions of the language specification, also:
http://chuck.cs.princeton.edu/doc/language/func.html
http://chuck.cs.princeton.edu/doc/language/spork.html
Code:
// setup variables, ugens, patches, etc. here
spork ~ oxygen8();
spork ~ fcb1010();
// this is needed to keep the current shred from exiting.
// if the current shred exits, it takes down all the shreds it sporked with it
while( true )
    1::day => now;
fun void oxygen8()
   // oxygen8 code goes here
fun void fcb1010()
  // fcb1010 code goes here
Kassen
PostPosted: Thu Mar 01, 2007 12:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Jack, will you be recording this "sampling and messing around"? Or maybe this station has a online presence?
"crash & burn", if I remember corectly they say that in this movie called "robojox" for good luck. Wink
Kassen
sir honey
PostPosted: Thu Mar 01, 2007 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it will be webcast from www.wdst.com. That's the woodstock radio station. And this just in....
the gig got moved to the following weekend March 10th. So log on if you'd like to check it out. Time TBA.
I'm glad I've got an extra week to put something together in ChucK. I sure need the practice!
Thanks for the help Spencer.
Jack
BTW- I might use Chuck to program some pieces of an art installation for a rather large public piece that's coming up. If I get the gig, I'll be sure to fill y'all in. I can't divulge anything yet, but it seems like it's going to be totally amazing.
Kassen
PostPosted: Thu Mar 01, 2007 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think I have to play on the 10th myself.
...90% ChucK, of cource. Not all finished yet, of cource Smile
Kassen
sir honey
PostPosted: Thu Mar 01, 2007 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
but i'm in the states....
so you might be done when I'm shreduled to start my sporkin' gig.
I think it'll get recorded anyway.
I'd like to hear what kinda chucKles you're doing live Very Happy
any Mp3's of your stuff?
you can hear some of my music @ www.myspace.com/sirhoney.
jack
sir honey
PostPosted: Thu Mar 01, 2007 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
spencer,
I thought I had been a good chuck student by reading the whole manual that is distributed with the chuck download. I didn't know about all the online stuff (lang. specif.). It seems like the online references are a bit richer in content, too. Maybe the manual should be updated to include the material that is posted on the web?
just a suggestion.
thanks anyhow,
jack
sir honey
PostPosted: Thu Mar 01, 2007 7:52 pm    Post subject: aaarrghh!!! Reply with quote  Mark this post and the followings unread
I've gotten a bit further with this project. But, even after following spencer's advice and reading the doc, I can't this thing to work properly.
I'm still getting blocked shreds.
Here's the code:
Code:
//jack ryon 2007
//-----------GLOBAL PARAMETERS/UGENS/ETC.----------//
SndBuf s => dac;
spork ~ oxygen();
spork ~ fcb();
while(true) 1::day => now;
//----------------OXYGEN 8 FUNCTION---------------//
fun void oxygen()
   MidiIn min1;
   MidiMsg msg1;
   if(!min1.open(2)) me.exit();
   min1 => now;
      <<<msg1.data1,msg1.data2,msg1.data3,"OXYGEN8">>>;
//--------------FCB1010 FUNCTION----------------//
fun void fcb()
   MidiIn min2;
   MidiMsg msg2;
   if(!min2.open(1)) me.exit();
   min2 => now;
      <<<msg2.data1,msg2.data2,msg2.data3,"FCB1010">>>;
when I run this, I actually get the desired 3 shreds up and running. But again when queried, tell me that they've been blocked by the VM.
Code:
[chuck](VM): sporking incoming shred: 1 (rev.ck)...
[chuck](VM): status (now == 0h1m6s, 2940672.0 samps) ...
    [shred id]: 1  [source]: rev.ck  [spork time]: 10.44s ago
    [shred id]: 2  [source]: spork~exp  [spork time]: 10.44s ago (blocked)
    [shred id]: 3  [source]: spork~exp  [spork time]: 10.44s ago (blocked)
what's even more frustrating, is the fact that precisely 1 MIDI message is sent from my controller and registers in chuck.
Code:
176 16 65 OXYGEN8
192 6 0 FCB1010
then if I query chuck again, the child shreds have disappeared, and only the parent is present.
what is wrong here?
thanks for any input,
jack Confused
moudi
PostPosted: Fri Mar 02, 2007 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
hi jack
the sporked function just finishes after receiving the first message, because there is no endless loop for the receiver.
the code needs to look like the following.
Code:
fun void oxygen()
   MidiIn min1;
   MidiMsg msg1;
   while(true)
     min1 => now;
        <<<msg1>>>;
notice the endless loop starting before the wait for a next event.
i just started with my daily work at office. i will post my personal midi implementation when i return in the evening...
jassas
/moudi
Kassen
PostPosted: Fri Mar 02, 2007 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
I didn't record any of my ChucK stuff yet; there didn't seem much of a point yet (but this"ll change!)
Here's some previews of my last record thingy
http://clone.nl/item6736.html
It's kinda acoustical-inspirered but nearly all of it is pure electronics.
I'll check out your tracks later today; now I have to go on a expedition for some strange ingredients that are only to be found in a asian supermarket Smile
Kassen
sir honey
PostPosted: Fri Mar 02, 2007 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
oh yeah,
I had the endless loop in previous incarnations of this program. I become sort of blind to these subtle differences when
a) I become slightly frustrated,
and
b) up against a deadline.
I thank you for your help, hope to be able to return the favor once I get a little more programming experience!
best,
jack
I'd sure like to see your MIDI program, just for the sake of comparison.
cheers.
sir honey
PostPosted: Fri Mar 02, 2007 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Kassen,
what're you cooking?
I'll make empeethrees of the gig and share, provided everything goes relatively well.
It's going to be an ambient set. I play saxophone and electronics, and I'm joining a rock band called Mercury Rev. They're great.
enjoy!
jack
spencer
PostPosted: Fri Mar 02, 2007 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Jack/all,
With regards to the manual and documentation in general, lack of documentation is definitely one of the major weak points of ChucK right now. I think in general the web page is slightly more up-to-date, but some parts (specifically the UGen page) need some serious fixing. Anyways documentation is at the "working on it right now" priority level, and we plan to have it in decent shape before the upcoming release.
Shreds that are "blocked" by the VM are by no means a bad thing. A "blocked" shred is just a shred that is waiting on an event (e.g. input from MIDI, HID, OSC, etc.). (The term is a holdover from operating system design, where being "blocked" does in fact have a negative connotation.)
Also, sounds awesome about the gig. Definitely post some mp3s!
spencer
sir honey
PostPosted: Fri Mar 02, 2007 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks spencer.
I figured out that [blocked] shreds were not my problem when I eventually fixed the infinite loop problem I was having (courtesy of moudi).
Better doc would certainly help those of us (hmm hmm) who are lacking in real programming expertise.
jack
moudi
PostPosted: Sat Mar 03, 2007 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers.
ok, here we go...
the implementation is especially for my old PocketControl http://www.doepfer.de/pc.htm and i mostly use it for controlling volume of different shreds.
in generally, i made a public class with static variables to hold the values sent by the device. the watcher is running the whole time, captures the data and writes the values to the static variables.
to make use of them, you only need to write something like this in your shred:
Code:
 ... => Gain g => dac;
//add this wherever you want to set the volume
g.gain(PocketC.Vol01);
any thoughts about it?
regards
/moudi
PocketC.ck
 Filename:  PocketC.ck
 Filesize:  1.24 KB
 Downloaded:  248 Time(s)
PocketC_Watcher.ck
 Filename:  PocketC_Watcher.ck
 Filesize:  1.57 KB
 Downloaded:  231 Time(s)
sir honey
PostPosted: Sat Mar 03, 2007 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey All,
Thanks for all of the engaging posts and help with this project of mine! There's no way I'd be able to pull this off without all of the great tips, and helpful advice! Very Happy
Now I'm really close to having a great Live Chuck program, and I'm really excited to be able to bust it out on the air next weekend. One thing that is crucial to the live functionality of this thing is to be able to update the sample in the shred that's running in the VM when I hit my MIDI foot controller. Right now it writes a new sample to disk, but the buffer goes un-updated.
My thoughts on this were that I might be able to use Machine.replace(1,"rev.ck") after the sample is recorded, and that would update the wave file, and re-spork the program.
I could live with the fact that all of my MIDI controls would be re-initialized, if I could just get Machine.replace() to work! Right now it tells me that there is no shred with id 1 (even though [chuck ^] tells me that there is). Is it possible to replace a sporked shred from the code contained within it? I'm guessing that this is a possibility.
Any other thoughts on how to refresh the buffer to reflect a newly recorded sample would be a big help!
thanks
jack Smile
spencer
PostPosted: Sun Mar 04, 2007 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jack,
have you considered rechucking the name of the WAV file to your SndBuf's .read parameter? That should be sufficient to reload the file into memory, assuming that the associated WvOut has been closed.
spencer
sir honey
PostPosted: Tue Mar 06, 2007 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
spencer,
Basically that was the solution I arrived at. Only I built a Machine.replace() into the record method. I eventually got Machine.replace() to work correctly.
I'm going to give your solution a try though, Then my other effect parameters won't get reset with the re-sporking of the shred!
Cheers!
jack
