Midi-Latency
Page 1 of 1 [25 Posts]
mother misty
G2 patch files: 130
PostPosted: Tue Feb 27, 2007 3:04 am    Post subject: Midi-Latency Reply with quote  Mark this post and the followings unread
Hi all,
I've been experimenting with G2-sequencers to control external gear lately.
But everytime I've have a big latency when I try to send midi-notes to
external gear.
In this particular case I've tried a simple event sequencer connected
to a midi note send module to trigger samples on a kaosspad 3.
The kaoss pad is connected directly to the G2 with a midi cable
and still I've a huge latency. Is this normal?
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Tue Feb 27, 2007 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
The total transmission time of a three byte note on message is about 1ms. The receiving device then needs a little time to process, then make the sound. What sort of delay are we talking about?
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Feb 27, 2007 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've noticed latency when controlling my dave smith evolver (cutoff) with g2 envelopes which connect to cc send. I think the problem is the dave smith's reaction time to control changes.
I'll look into this (sending midi notes to external stuff) when I get home.
/Dasz
http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/
Audio files: 116
G2 patch files: 317
PostPosted: Tue Feb 27, 2007 5:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
When sending continuously changing data it's easy to exceed the MIDI bandwidth. This can be avoided for example by inserting a s&h triggered from an LFO just before the blue input of the CC send module. Set the LFO to a speed that has to be a compromise between hearing steps and hearing latency.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Feb 27, 2007 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah ... i was thinking of this too. i need to spend more time at home than on the road ...
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Feb 27, 2007 6:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
you know, we should really use avatars based in MRI scans of our brains with some visualization which represents how much overlap we have between each other ...
ok -- just going on a silly tangent here Wink
/Dasz
Audio files: 107
PostPosted: Tue Feb 27, 2007 7:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mother, I've done lots of MIDI sequence generation for external synth voices and haven't seen any objectionable latencies. I could see that some rapidly changing CCs would choke the MIDI stream. In cases where that is necessary, I try to chop the signal with the slowest clock rate I can get away with.
But you say it's MIDI Notes.
mother misty
G2 patch files: 130
PostPosted: Wed Feb 28, 2007 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the replys guys!
Well, the latency is pretty big (check the attached MP3 for an example,
the kick is a machinedrum, the dub skank a kaoss pad 3.
The dub skank is placed on the beat but it doesn't sound like that...)
I've attached the patch aswell. Any idea's?
[Blue Hell: there is a better version of the patch here]
Latency.mp3
audio example
 Filename:  Latency.mp3
 Filesize:  196.85 KB
 Downloaded:  325 Time(s)
KP3Seq.pch2
 Filename:  KP3Seq.pch2
 Filesize:  1.46 KB
 Downloaded:  729 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Wed Feb 28, 2007 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Nothing wrong with the patch ... got a MIDI loop somewhere maybe ?
Audio files: 116
G2 patch files: 317
PostPosted: Wed Feb 28, 2007 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh wait, the seq mod will give notes (trigs) at ranndom times I guess. Could that be it ?
mother misty
G2 patch files: 130
PostPosted: Wed Feb 28, 2007 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, the midi out from the G2 goes directly to the KP3 midi in.
The KP3 midi out is not connected.
mother misty
G2 patch files: 130
PostPosted: Wed Feb 28, 2007 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm, what do you mean with notes at random times?
(there's a RND trigger in the patch, but this shouldn't do more than let the trigger trough or not)
Audio files: 116
G2 patch files: 317
PostPosted: Wed Feb 28, 2007 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm in the patch as you sent it does nothing, but when you use that switch mechanism by opening the mod pot in the switcher it might switch off from a note that is off to a note that is on (in the other event qequence) and this will happen at a random moment, unsynced to the beat.
3phase
G2 patch files: 138
PostPosted: Thu Mar 01, 2007 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I havent had a look to the patch...it sounds way to early to me.
I think you have to delay the G2 triggers...
what bluehell said might sounds like more weard patching...maybe your sequencers trigger on the falling edge of the pulse making them way off...
its defenetly not so much midilatency in the nord...
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Mar 01, 2007 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
try taking out the rnd module -- is this still happening then?? I'd patch a 2 way switch to take the signal directly to the note out or through the rnd instead ...
/Dasz
mother misty
G2 patch files: 130
PostPosted: Mon Mar 05, 2007 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
/Dasz
Even if I connect the sequencer directly to a midi note send module, the timing still isn't tight Sad
Have you tried to sequence external gear with the G2 dasz?
Audio files: 107
PostPosted: Mon Mar 05, 2007 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried your patch and it plays one note on my Kurzweil PC2x synced perfectly to the light on the sequencer. I'm not sure what your problem is so I modified your patch to play an internal perc osc in sync with the external synth. In my setup, they play consistently at the same time.
mother-latent.pch2
A test patch for latency when driving an external sequencer with MIDI
 Filename:  mother-latent.pch2
 Filesize:  1.61 KB
 Downloaded:  965 Time(s)
mother misty
G2 patch files: 130
PostPosted: Mon Mar 05, 2007 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks mosc, I'll have a look at your patch tonight.
One more question, how is your kurzweill connected,
with a midi cable directly from the G2 or not?
Audio files: 107
PostPosted: Mon Mar 05, 2007 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I go though this ancient beast called a Unitor8. Essentially it is an 8 in by 8 out MIDI router connected to the computer with a RS232 cable. The way I use it is pretty lame. I route everything into the computer and do the routing with MIDIOX. The Unitor8 has its own software that can do the routing internally, but I like the MIDIOX software better and haven't noticed any objectionable latency.
mother misty
G2 patch files: 130
PostPosted: Tue Mar 06, 2007 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Damn...
The starting points of my samples in my kaoss pad3 are a bit fucked up,
that's why everything sounds out of sync, I feel so stupid!! Embarassed Embarassed
I've changed the samples and it works fine now.
Thanks for your time anyway guys, this G2>KP3 combo is serious fun and gives alot of new options! Very Happy
Audio files: 116
G2 patch files: 317
PostPosted: Tue Mar 06, 2007 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
At least you found it.
grimley
G2 patch files: 9
PostPosted: Tue Mar 06, 2007 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Couldn't agree more ... I recently upgraded from a KP2 and I'm addicted. I also love using the KP3 as a controller for the G2, especially the pad mode where you have 4 CCs.
-grimley
iPassenger
G2 patch files: 78
PostPosted: Wed Mar 07, 2007 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
mother misty wrote:
Damn...
Doh! how annoying.
It's like when you repatch yr studio to find out why a drum machine isn't producing audio, only to find that you have the channel muted.
iP (Ross)
GovernorSilver
PostPosted: Wed Mar 07, 2007 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
-grimley
Our guitarist introduced his KP3 to us last weekend and we all had a hilarious good time sampling our voices and mucking with the samples.
How is the MIDI CC resolution on the Kaoss pads? Is both the LSB and MSB of the CC message supported?
mother misty
G2 patch files: 130
PostPosted: Mon Mar 12, 2007 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
-grimley
I've always wanted a joystick on my G2 but your solution sounds like a very good alternative! Smile
