Fernando
Joined: Dec 30, 2006 Posts: 207 Location: Barcelona, Spain
Posted: Tue Mar 13, 2007 6:05 am Post subject:
| well done, thanks a million for working this out!!! |
krisp14u
Posted: Tue Mar 13, 2007 11:16 am Post subject:
| fonik wrote: | PCBs arrived yesterday and i populated and tested one PCB.
Everything is fine, worked instantly.
(only one minor error - i mistyped the web address: fonik.modular instead od modular.fonik ) |
Nice 1 fonik can't wait to get hold of the PCB's you have done a fine job
if any one is needing the VTL5c3/2 to make this pcb I have some spare PM me
they are 2GBP each + postage
cheers paul darlow |
Etaoin
Joined: Jun 30, 2005 Posts: 760 Location: Utrecht, NL
Posted: Wed Mar 14, 2007 3:58 am Post subject:
Great stuff.
You have an LM1448 in the BOM. That probably needs to be the LM1458? |
andrewF
Posted: Wed Mar 14, 2007 6:09 am Post subject:
VERY impressive documentation!!
you deserve a synth-diy medal  |
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Wed Mar 14, 2007 7:53 am Post subject:
Looks great Fonik, top job!
I would get one, but I've just got way too much on my plate right now. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
Fernando
Posted: Wed Mar 14, 2007 10:23 am Post subject:
you are a master! thank you very much!
Etaoin
Posted: Wed Mar 14, 2007 1:06 pm Post subject:
Is there a specific reason you have chosen silver mica caps?
Or more specific, can I use polystyrene there? I have plenty of 1nF polystyrene, but would have to order the (expensive) silver mica ones. |
Etaoin
Posted: Thu Mar 15, 2007 12:23 am Post subject:
Yes, but general poly or ceramic would be less stable I guess. That's why I wondered if silver mica was chosen for a property that polystyrene also has (low leakage, for example).
Ray Wilson still specifies either silver mica or polystyrene for his VCO (where others chose polypropylene, by the way).
Anyway, I'll try polystyrene and see how that sounds. There's only one shop over here that sells 1nF silver mica (at about 3 euros each). I might get them if I need something else from them... |
Funky40
G2 patch files: 5
Posted: Thu Mar 15, 2007 8:10 am Post subject:
sorry,
1.) what is silver mica in german ? Is it Styroflex ?
2.) and polystyrene ? folie ? |
Fernando
Posted: Thu Mar 15, 2007 8:53 am Post subject:
Styroflex = polystyrene, afaik
| Funky40 wrote: | sorry,
jksuperstar
G2 patch files: 18
Posted: Thu Mar 15, 2007 4:33 pm Post subject:
Silver Mica and Polystyrene both have low Dielectric absorption, which isn't just about leakage, it's also about how the cap discharges as well, and the uniformity that the charge is released. Both would be good.
Here's a sticky on the subject (look at the bottom for Blue Hell's link, not the original post).
http://electro-music.com/forum/topic-7474.html
I think DA% is discussed in Part II of the article. Either way, everyone should read both articles on choosing capacitors (as well as the many other papers at that site!)
-Justin |
Funky40
G2 patch files: 5
Posted: Fri Mar 16, 2007 7:09 pm Post subject:
| ok, thank you guys |
sneakthief
Posted: Fri Mar 16, 2007 11:21 pm Post subject:
I just received my PCB in the mail yesterday - looks great
Danke Fonik! _________________ Sneak-Thief - raw electrofunk |
Etaoin
Posted: Sat Mar 17, 2007 9:37 am Post subject:
I have two suggestions for a possible future run:
C16 is a bit too close to U4. 680nF WIMA doesn't fit, for instance. Also, it's useful to have an extra hole at 5mm as well for the larger capacitors.
C7, C9 and C11 could also do with 5mm spacing. The only thing I have that actually fits there is multilayer ceramic, which is of course terrible in the audio path.
Otherwise: great job!
Posted: Sat Mar 17, 2007 11:12 am Post subject:
| Etaoin wrote: | | I have two suggestions for a possible future run: |
wow. do you think there would be this much interest?
| Quote: | | C16 is a bit too close to U4. 680nF WIMA doesn't fit, for instance. Also, it's useful to have an extra hole at 5mm as well for the larger capacitors. |
sure. i had to bend the pins. not beautiful but it works.
| Quote: | | C7, C9 and C11 could also do with 5mm spacing. The only thing I have that actually fits there is multilayer ceramic, which is of course terrible in the audio path. |
WIMA MKS-2-5 would fit. _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
Etaoin
Posted: Sat Mar 17, 2007 1:09 pm Post subject:
| Quote: | | WIMA MKS-2-5 would fit. |
I see WIMA also have 680nF in the MKS02 line so I think I´m off to stock up on MKS02 caps. |
Audio files: 51
Posted: Sat Mar 17, 2007 2:43 pm Post subject:
Very nice looking boards Fonik. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
Posted: Sat Mar 17, 2007 2:53 pm Post subject:
| fonik wrote: | | Etaoin wrote: | | I have two suggestions for a possible future run: |
yes, you are right: the MKS02! that's the one with RM2.5, NOT the MKS-2-5! my fault. _________________
fonitronik at
philpeery
Joined: Nov 08, 2006 Posts: 122 Location: new jersey, usa
Posted: Sun Mar 18, 2007 7:51 pm Post subject:
Fonik, this looks like an awesome project! I missed the original announcement, are there any boards left over? I'd take 2 in a heartbeat! If not, will there be another run?
Regards,
Phil |
Etaoin
Posted: Mon Mar 19, 2007 12:42 am Post subject:
By the way, is the "wet" output supposed to be lower gain than the "dry" output?
I need to have to mix output at about 90% and up to even hear the filtered signal. |
