  bingsatellites Mostly Ambient
About the clock
Page 1 of 1 [3 Posts]
Tool
PostPosted: Sun Mar 25, 2007 7:51 am    Post subject: About the clock Reply with quote  Mark this post and the followings unread
I notice that when I use the clock internal signal of the clock module in the lfo section, the tempo is not exactly the same that in my nuendo... 120 bpm are not exactly the same in the module that in nuendo or other sequencer... but when you use the master tempo in the clavia then is just the same tempo than in nuendo...
How can I do to resolve that?
Thanks
slave to this
G2 patch files: 7
PostPosted: Sun Mar 25, 2007 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
set the clock generator in your patches to master instead of internal. then go into your synth settings and make sure that you have it set up to receive external clock. you'll be able to tell if its in sync with your computer if, in the g2 editor, it says "Ext" at the top left portion by "Master clock." It will also be red instead of the normal color.
You will probably need to make sure nuendo is sending some sort of clock output via your midi connection too. I'm not a nuendo user, so I can't exactly give you any suggestions with that part.
Tool
PostPosted: Sun Mar 25, 2007 5:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks again slave to this
emSynth
