Aesoteric
Posted: Fri Apr 06, 2007 3:57 pm Post subject:
How best to build a clock synced audio slicer/recycler? Subject description: Converting an MSP idea into a G2 patch... |
Hey all,
My first post...I'm a long time MicroModular user and brand new G2 Engine owner (she moved in today..!)
I'm utterly loving it.
I mostly use my Micro for audio processing and mangling, and the lovely new G2 is going to be paired with my Electrix Repeater for looping/processing fun....I'm going to run inputs 1-2 in the FX loop of my amp into the Repeater's inputs, and then have inputs 3-4 of the G2 in the FX loop of the Repeater...that way I can loop the G2 and, or use it to process loops...ultimate, beautiful flexibility. Anyways, enough excitable gushings...
I'm hoping someone can give me a few tips on a processing patch I'm working on...its something I originally built in Max/MSP and use as an AudioUnit inside Live 5 (I tried to attach a mini-standalone version of the Max patch for anyone to try but I keep getting an error when I try to post)
Basically what the Max patch does is realtime recycling of loops...it splits a loop up into a set number of slices and then re-orders them (user definable using a multi-slider object) on the fly. Its great for Reich-esque melodic phrases and breaks.
I've built a few approximations on the G2 today, one based on two quad delays, clock synced to different beat divisions and run into a 8-1 multi and another based on Tim's Elastic Audio looper, using a step sequencer to control the Scrub parameter. Neither of these are entirely perfect, and neither really work tightly enough to use with rhythms - has anyone built anything similar to this in the past...I've searched the patches but can't find anything...if anyone can give me any pointers I'd be really grateful. A way of running the delay based system so that its not behind the clock (because of the delay!)??! Thats why I thought Tim's system might be the way to go, but unfortunately I'm not quite at a stage where I can easily reverse engineer his patch to my own ends...
Anyways, this is turning into the War and Peace of 1st posts, so I'll shut up...my only excuse is my excitment at my sexy new 1U rackable friend....
Cheers in advance for any help,
Aes (Tim) |
Joined: Apr 03, 2004 Posts: 19595 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Fri Apr 06, 2007 4:11 pm Post subject:
Tim and congrats with the G2.
For help I was going to point you to that other Tim, but well, you already found it
How long should the swappable audio bits be ? I can imagine this to eat memory very fast. _________________ Jan |
Aesoteric
Posted: Fri Apr 06, 2007 4:29 pm Post subject:
Hey Blue Hell,
Cheers for getting back to me, and for the warm welcome...
The audio fragments only have to be fairly short...imagine a one bar drum loop with all 16th notes...each slice is only one beat long.
I've got a few approximations, but none that sound as defined and tidy as the Max version.
One other question, is it possible to upload Max patches and apps?
Tim |
Audio files: 116
G2 patch files: 317
Posted: Fri Apr 06, 2007 5:05 pm Post subject:
| Aesoteric wrote: | | One other question, is it possible to upload Max patches and apps? |
You tried, so apparently not ... maybe mosc could allow for it, what file extensions would you need ? _________________ Jan |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Fri Apr 06, 2007 5:32 pm Post subject:
.pat .mxb and .mxt are enabled on this forum.  _________________ --Howard
my music and other stuff |
Tim Kleinert
Joined: Mar 12, 2004 Posts: 990 Location: Zürich, Switzerland
Audio files: 6
G2 patch files: 201
