APC space wired 1.0
Page 1 of 1 [13 Posts]
dnny
PostPosted: Mon Apr 09, 2007 2:48 am    Post subject: APC space wired 1.0
Subject description: Atari Punk Console inside bulb
Hi All,
It's been a long time since my last post and i must say that i haven't forgotten you nor this forum, just too much work these days.
How are You, any new projects Smile ?
I had some extra time during Easter holidays, so i fitted space wired APC inside a Osram Centra bulb (diameter 80mm and length 160mm).
It's controlled whit two LDR's they need to be at very dark to start oscillating at audio frequency, so it's kind of optimised for gigs at dark places. It has also microphone stand adapter.
some pics and video:
more pictures
www.koelse.org
flickr: cable porn group
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Apr 09, 2007 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
you're brilliant!! awesome work man!! it reminds me of those little ships build inside of a bottle Smile keep it up (thumbz up)
dnny
PostPosted: Mon Apr 09, 2007 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, i got the idea of those ships in a bottle. I have some huge bulbs that are waiting for me... I'm thinking of WSG in a bulb. Smile
if anyone has any suggestions of some other simple circuits please advice me.
www.koelse.org
bugbrand
PostPosted: Mon Apr 09, 2007 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, that is absolutely fantastic - really lovely object design mmmmm!
(& a big warm hello too!)
Are there any spare gates left over in the APC circuit? (its based on a 40106 isn't it?) -- if so then maybe you'd be interested to add a couple more oscs, but at slower rates to modulate LEDs - I did this sort of thing for a proto-wierdy BoardWeevil where there were two LEDs to position over an array of LDRs (inc one for power starve) so it became a chaotic feedback system (also it had to be played in the dark for best results) (there's a youtube here:::: http://www.youtube.com/watch?v=H9SD5Ous-lY)
http://www.bugbrand.co.uk
dnny
PostPosted: Mon Apr 09, 2007 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tom,
The APC is actually based on the dual timer 556 chip or two 555 timers.
Mims schem
kaustic schem
i will try on the WSG, its based on 40106 and has some free gates.. the BoardWeevil sounded great... lets see what comes up.
www.koelse.org
Audio files: 278
PostPosted: Mon Apr 09, 2007 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Idea Is beautiful Very Happy
How did you get into the bulbs without breaking them ? I mean there is the inside piece of glass holding the filament originally, but you had to cut that at the lamp's base I guess scratch the dremel will just do that for you ?
Clack
PostPosted: Mon Apr 09, 2007 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah how did you prevent it from shattering when you released its pressure?
PostPosted: Mon Apr 09, 2007 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dnny! You're back home! Very Happy Very Happy Very Happy Very Happy !!
welcome back to electro-music old chum Cool
Lightbulb???? Shocked
It's BEAUTIFUL!! Cool Cool Cool
ACHTUNG!
PostPosted: Mon Apr 09, 2007 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
A work of art! Shocked
well-done well-done well-done well-done
Flickr
After watching the viddy, I reckon you need some gloves (and a suit?!) stuffed with LED's Cool
ACHTUNG!
dnny
PostPosted: Mon Apr 09, 2007 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the warm welcome,
Now, how did i get the bulb open without breaking it?
Short answer is dremel and cut-off wheels, but as always there is a neat how to, Light Bulb Opening Construction Article Part II by John Fox III see also the attached Part I
( isn't Internet great?)
I did my cut a bit higher than John advices to keep the glass stem in place. then i inserted the APC module into the bulb and casted the metal screw cap back to its place whit epoxy.
here is a closeup on the cut's
Be careful, some bulbs contain very high pressure and will explode if you want to cut them. Try to avoid HID (High Intensity Discharge) bulbs, xenon arc lamps, High pressure sodium lamps, Metal halide lamps and High pressure mercury vapor lamps... The local lighthouse might have the perfect bulb in shape and size to fit a real modular inside, but those bulbs are not the ones to cut.
Stick whit low pressure Incandescent lamp, if you are not sure of your lamp/bulb type don't cut it.
Daniel ... soon wearing a LED-costume Smile
light bulb part 1.zip
Light Bulb Opening Construction Article Part I by John Fox III
this first part of the article is not online so if you want to read it, download the zip.
 Filename:  light bulb part 1.zip
 Filesize:  363.49 KB
 Downloaded:  674 Time(s)
www.koelse.org
Wild Zebra
PostPosted: Tue Apr 10, 2007 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Sweet Dnny, You can teach an old dog new tricks. Wink Very nice indeed.
"your stripes are killer bro"
Audio files: 278
PostPosted: Tue Apr 10, 2007 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I liked the long answer Very Happy
Thanks !
