MIDI implementation
dp
PostPosted: Thu Apr 12, 2007 11:02 am    Post subject: MIDI implementation
Subject description: adding midi to an existing chuck patch
greetings
my name is david. i use chuck with my monome (actually a custom monome; i built two monomes into a single enclosure for a 8x16 button grid...http://dnphipps.mailcan.com/CIMG0834_2.jpg).
chuck is working great for me, using the monogrid patch kassen helped edit. the chucklife patch has also given me great source material for new compositions. chuck rocks!
i've attached an example that is on the monome wiki...follow40h. here's the description:
"treats the 40h as a x-y trackpad. the current illuminated square is the nearest integer point to the current value which returns to the center if left alone. if you press a button, the point heads over to there, leaving a short-live light trail."
i'd love to add midi cc data to the output of this app. more specifically, diffferent cc for x and for y. i'm going to read throught the manual again and look at some more examples...any insight or direction would be greatly appreciated.
best!
dp
follow40h.ck
 Filename:  follow40h.ck
 Filesize:  1.53 KB
 Downloaded:  152 Time(s)
Niio1
