  Muied Lumens Frequencies
 Forum index » Instruments and Equipment » OSX as a music workstation
&#$*%*&!!! DP 4.61 KILLING MY SOUL..please help!
Page 1 of 8 [186 Posts]
Goto page: 1, 2, 3, ..., 6, 7, 8 Next
Digiton
PostPosted: Sun Apr 15, 2007 9:18 am    Post subject: &#$*%*&!!! DP 4.61 KILLING MY SOUL..please help! Reply with quote  Mark this post and the followings unread
i am running mac os x 10.4.9 with DP 4.61
it is acting UP son!
The biggest concern i'd like some possible help with is that i am working on a rather long piece (17 minutes plus) with max (8.) stereo tracks going at once etc....now, i don't know if this is part of the problem but as of yesterday I CANNOT OPEN THESE FILES WITHOUT DP IMMEDIATLY CRASHING UPON LOADING plugins!!!!!! Now, the glimmer of hope is that when i launched up tiger in safe mood, although i couldn't hear anything, the digital performer file DID load.
Now, other projects can load. It seems just this one crashes. This has happened once before that a project would fail to open, but it wasn't of concern to me because it sucked. This is different. Lastly, in this project, i have saved many different copies of the DP 4 project. Earlier versions DO open...just not the most recent 3. And alot of work was in those recent files........Thanks guys.
-max Mad
The crime of humanity is signature foul play
PostPosted: Sun Apr 15, 2007 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Drop whatever you are holding!
Don´t touch anything..
Breathe...
A list of what I could come up with:
1. Updating the OS and/or QT is not recommended unless you know your DAW software will handle it.
2. It might not be this though.. but..
3. I don´t use or own DP so I simply doesn´t know much about it. Sorry.. Smile
4. Have you checked your disk for directory errors? Latest Diskwarrior is good.
Hmm..
Don´t start using Onyx for killing stuff just yet. check your disk with DW first.
EdisonRex
Audio files: 171
PostPosted: Sun Apr 15, 2007 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Check your sound files and make sure that none of the sound files in the project is corrupted. Use quicktime or something like that to check it.
If you find it, delete it or replace it with a working copy. You might be able to fix it, although I've never had good luck with corrupted sound files.
In some cases the project itself gets corrupted. I've had this happen from time to time. It's why I make backups of important checkpoints.
But I'd lay odds it's either a soundfile or analysis file.
Garret: It's so retro.
PostPosted: Sun Apr 15, 2007 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Good advice.
I would suggest he checks his HD before he does anything more though.
Digiton
PostPosted: Sun Apr 15, 2007 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks yalll.....it will take my longer to go through checking soundfiles than it did to write this piece thus far...but i guess if i view them by date added it shouldn't take too long..appreciate the fast response time. Thanks alot guys.,,,EMT squad for the electronic musician Smile
EdisonRex
Audio files: 171
PostPosted: Sun Apr 15, 2007 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Hint - in OSX, startup a terminal.
Then in the terminal (it's Unix, remember) cd your way to your project, and find the soundfiles folder.
$ ls -al | more
and look for zero length files.
I don't know if you're any good with terminal mode, but the other way is to browse it with Finder and show full details.
If OSX gives you a box with gibberish when DP crashes, can you copy the contents of the box and post it here. Might give a clue. Details help.
Digiton
PostPosted: Sun Apr 15, 2007 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks
yeah i noticed that all my corrupt soundfiles were only and exactly 4 KB.
but i can tell you right now i Put all the analysis, audio, undo, and fade folders onto my external hard drive. I then trashed all the files that were on my hard drive. ALL OF THEM! And guess what? Still crashed.
you said i could post the list of gibberish i get upon crashing? Seriously? Its very long, but it starts of with a mighty promising "unknown disk fragment" Surprised
ok, i'll dump into a seperate post
thanks again, and i will contact motu on monday Exclamation
EdisonRex
Audio files: 171
PostPosted: Sun Apr 15, 2007 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
One other tip.
You can create a new project, and load all of your sequences and songs, and import audio files. This might be a method of last resort to rescue a corrupted project.
Digiton
PostPosted: Sun Apr 15, 2007 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Date/Time: 2007-04-15 13:13:33.131 -0400
OS Version: 10.4.9 (Build 8P135)
Report Version: 4
Command: Digital Performer
Path: /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/Digital Performer
Parent: WindowServer [111]
Version: 4.61 (4.61)
PID: 875
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
Thread 0 Crashed:
0 MaxPPC3.1 0x0bff8318 0xbfa0000 + 361240
1 <Unknown> 0x0aae0980 vstplug_load + 228
2 mode.bang-delay 0x021d99a8 IntoVstPlugLib + 520
3 mode.bang-delay 0x021d93a8 main + 792
4 com.cycling74.PluggoAU 0x0acc5c24 PluggoAUEntry + 12592
5 com.cycling74.PluggoAU 0x0acc2e50 PluggoAUEntry + 860
6 com.cycling74.PluggoAU 0x0acc2534 dyld_stub_memchr + 181011732
7 com.cycling74.PluggoAU 0x0acdc358 PluggoAUViewEntry + 78896
8 ...ple.CoreServices.CarbonCore 0x90bdec60 CallComponent + 260
9 ...apple.audio.units.AudioUnit 0x942f5854 AudioUnitGetPropertyInfo + 56
10 com.MOTU.MAS.AudioUnitWrapper 0x08b7c120 AudioUnits::GetPropertyInfo(ComponentInstanceRecord*, unsigned long, unsigned long, unsigned long, unsigned long&, unsigned char&) + 84
11 com.MOTU.MAS.AudioUnitWrapper 0x08b7cfd0 AudioUnits::Base::getParameterInfo(int, unsigned long, AudioUnitParameterInfo&) + 76
12 com.MOTU.MAS.AudioUnitWrapper 0x08b8461c MasAUSupportClass::GetPublicSettingInfo(long, MotuString*, short*, short*) + 164
13 com.motu.DigitalPerformer 0x001f5b64 0x1000 + 2050916
14 PerfEngine.dylib 0x12e0f77c DP0000000000000000000000000000000000000000000000000000000000000000000096 + 1096
15 PerfEngine.dylib 0x12e110ac DP0000000000000000000000000000000001d6 + 212
16 PerfEngine.dylib 0x12e114fc DP000000000000000000000000000000000021f + 116
17 PerfEngine.dylib 0x12e7a88c DP000000000000000000000000000000000000000000000018f + 64
18 PerfEngine.dylib 0x12e7a0cc DP0000000000000000000000000000000000000000000000000000010c + 272
19 com.motu.DigitalPerformer 0x0026bc94 0x1000 + 2534548
20 com.motu.DigitalPerformer 0x00268a48 0x1000 + 2521672
21 com.motu.DigitalPerformer 0x00269080 0x1000 + 2523264
22 com.motu.DigitalPerformer 0x00268098 0x1000 + 2519192
23 com.motu.DigitalPerformer 0x0010dbb8 0x1000 + 1100728
24 com.motu.DigitalPerformer 0x0010c3d0 0x1000 + 1094608
25 com.motu.DigitalPerformer 0x0010c6c8 0x1000 + 1095368
26 com.motu.DigitalPerformer 0x004289e8 0x1000 + 4356584
27 com.motu.DigitalPerformer 0x00428584 0x1000 + 4355460
28 com.motu.DigitalPerformer 0x00623054 0x1000 + 6430804
29 com.motu.DigitalPerformer 0x00009460 0x1000 + 33888
30 com.motu.DigitalPerformer 0x00009a68 0x1000 + 35432
31 com.motu.DigitalPerformer 0x00005400 0x1000 + 17408
32 com.motu.DigitalPerformer 0x00004db4 0x1000 + 15796
33 com.motu.DigitalPerformer 0x00004be4 0x1000 + 15332
Thread 1:
0 libSystem.B.dylib 0x900412f8 mach_wait_until + 8
1 libSystem.B.dylib 0x900410c4 nanosleep + 388
2 libSystem.B.dylib 0x90044898 usleep + 88
3 MSL_Perf.dylib 0x137254f4 DP000000000000000000000000000000000000000186 + 108
4 MSL_Perf.dylib 0x13725928 DP000000000000000000000018f + 32
5 libSystem.B.dylib 0x9002be88 _pthread_body + 96
Thread 2:
0 libSystem.B.dylib 0x9000b4c8 mach_msg_trap + 8
1 libSystem.B.dylib 0x9000b41c mach_msg + 60
2 PerfFoundation.dylib 0x11f52da0 DP00000000000000000000002d5 + 120
3 PerfFoundation.dylib 0x11f52d14 DP0000000000000000000000000000000374 + 20
4 libSystem.B.dylib 0x9002be88 _pthread_body + 96
Thread 3:
2 com.apple.audio.midi.CoreMIDI 0x96b92ac8 XServerMachPort::ReceiveMessage(int&, void*, int&) + 84
3 com.apple.audio.midi.CoreMIDI 0x96b85c80 MIDIInPortThread::Run() + 64
4 com.apple.audio.midi.CoreMIDI 0x96b89f44 XThread::RunHelper(void*) + 28
5 com.apple.audio.midi.CoreMIDI 0x96b9387c CAPThread::Entry(CAPThread*) + 96
6 libSystem.B.dylib 0x9002be88 _pthread_body + 96
Thread 4:
2 com.apple.CoreFoundation 0x907deba8 __CFRunLoopRun + 832
3 com.apple.CoreFoundation 0x907de4ac CFRunLoopRunSpecific + 268
4 com.apple.CoreFoundation 0x907ed90c CFRunLoopRun + 52
5 com.apple.DVCPROHDMuxer 0x0721b1ac AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 404
Thread 5:
4 com.apple.audio.CoreAudio 0x9145863c HALRunLoop::OwnThread(void*) + 264
5 com.apple.audio.CoreAudio 0x914583dc CAPThread::Entry(CAPThread*) + 96
Thread 6:
2 MotuAudioSystem 0x1198b01c DP00000000000000000000004a + 128
3 MotuAudioSystem 0x1198af84 DP000000000000000000000000000000081 + 44
Thread 7:
0 libSystem.B.dylib 0x9002c638 semaphore_wait_trap + 8
1 MotuAudioSystem 0x11984dd4 DP000000000000000000003f + 20
2 MotuAudioSystem 0x1197cf24 DP00000000000000000000000000000000000000072 + 384
3 MotuAudioSystem 0x1197ebac DP00000000000000000000000000060 + 356
Thread 8:
0 libSystem.B.dylib 0x90055468 semaphore_timedwait_signal_trap + 8
1 libSystem.B.dylib 0x90071be8 pthread_cond_timedwait_relative_np + 556
2 ...ple.CoreServices.CarbonCore 0x90bf948c TSWaitOnSemaphoreCommon + 176
3 ...ple.CoreServices.CarbonCore 0x90c01428 TimerThread + 60
Thread 9:
3 ...ple.CoreServices.CarbonCore 0x90c04f9c DeferredTaskThread + 56
Thread 10:
2 MotuAudioSystem 0x119a98dc DP00000000000000000000000000054 + 468
3 MotuAudioSystem 0x119a96f4 DP0000000000000000000000000000005d + 16
Thread 11:
Thread 12:
2 com.apple.audio.CoreAudio 0x91469794 CAGuard::WaitFor(unsigned long long) + 204
3 com.apple.audio.CoreAudio 0x914696a4 CAGuard::WaitUntil(unsigned long long) + 304
4 com.apple.audio.CoreAudio 0x914678e8 HP_IOThread::WorkLoop() + 852
5 com.apple.audio.CoreAudio 0x91467580 HP_IOThread::ThreadEntry(HP_IOThread*) + 16
6 com.apple.audio.CoreAudio 0x914583dc CAPThread::Entry(CAPThread*) + 96
7 libSystem.B.dylib 0x9002be88 _pthread_body + 96
Thread 13:
0 PerfEngine.dylib 0x13059b1c DP00000000000000019a + 8
1 PerfEngine.dylib 0x13059ff8 DP000000000000000000000000000351 + 348
2 libSystem.B.dylib 0x9002be88 _pthread_body + 96
Thread 0 crashed with PPC Thread State 64:
srr0: 0x000000000bff8318 srr1: 0x100000000000d030 vrsave: 0x0000000000000000
cr: 0x24022414 xer: 0x0000000000000000 lr: 0x000000000bfb2b78 ctr: 0x000000000bfb2b60
r0: 0x000000000aae0980 r1: 0x00000000bfffcb20 r2: 0x000000000aeb7920 r3: 0x0000000000000090
r4: 0x000000000aebebf8 r5: 0x0000000000000000 r6: 0x00000000bfffcef8 r7: 0x00000000bfffc630
r8: 0x00000000bfffc4d0 r9: 0x0000000000000000 r10: 0x0000000090bb060c r11: 0x00000000a174dc34
r12: 0x0000000000000000 r13: 0x0000000000000000 r14: 0x0000000000000000 r15: 0x0000000000000000
r16: 0x0000000000000000 r17: 0x00000000bfffd2c0 r18: 0x000000000ace403c r19: 0x0000000001965e00
r20: 0x00000000bfffd140 r21: 0x00000000bfffcef8 r22: 0x00000000021b9a14 r23: 0x0000000000000001
r24: 0x00000000021de19c r25: 0x00000000021df024 r26: 0x00000000021df268 r27: 0x00000000021defa8
r28: 0x00000000021df201 r29: 0x00000000021df288 r30: 0x00000000021df26e r31: 0x00000000000001e1
Binary Images Description:
0x1000 - 0x97bfff com.motu.DigitalPerformer 4.61 /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/Digital Performer
0xd05000 - 0xdbcfff com.motu.DAE DAE™ 1.0 (1.0) /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/Frameworks/DAE.framework/Versions/A/DAE
0x21d8000 - 0x21d9ff3 mode.bang-delay PEF binary: mode.bang-delay
0x3e8a000 - 0x3e8cfff com.apple.textencoding.unicode 2.0 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x693c000 - 0x6951fff com.MOTU.plugin.AudioExport.CoreAudio Core Audio Export version 1.3, 9/1/04 (1.0) /Library/Audio/Plug-Ins/MOTU Audio Export/Core Audio Export.bundle/Contents/MacOS/Core Audio Export
0x69f5000 - 0x6a00fff com.apple.LiveType.component 2.0.2 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x6a06000 - 0x6ae6fff com.apple.audio.codecs.Components 1.4.7 /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x6d72000 - 0x6d90fff com.MOTU.plugin.AudioExport.LAME LAME Audio Export version 1.0, 9/27/04 (1.0) /Library/Audio/Plug-Ins/MOTU Audio Export/LAMEAudioExport.bundle/Contents/MacOS/LAMEAudioExport
0x6df1000 - 0x6e09fff com.MOTU.plugin.AudioExport.QT QuickTime Export version 1.0, 1/18/05 (1.0) /Library/Audio/Plug-Ins/MOTU Audio Export/QuickTime Export.bundle/Contents/MacOS/QuickTime Export
0x70fb000 - 0x7134fff com.apple.audio.SoundManager.Components 3.9.1 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x7152000 - 0x71d1fff com.apple.DVCPROHDAudio 1.2 /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
0x71fe000 - 0x72a4fff com.apple.DVCPROHDMuxer 1.2 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0x739b000 - 0x739cfff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0x739f000 - 0x73defff com.apple.QuickTimeFireWireDV.component 7.1.5 /System/Library/QuickTime/QuickTimeFirewireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x7506000 - 0x751afff com.MOTU.MAS.plugin.InvertPhase InvertPhase version 1.0.2, 11/11/04 (1.0.1) /Library/Audio/Plug-Ins/MAS/InvertPhase.bundle/Contents/MacOS/InvertPhase
0x7584000 - 0x75d1fff com.MOTU.MAS.plugin.DCNotch 4.2 /Library/Audio/Plug-Ins/MAS/DCNotch.bundle/Contents/MacOS/DCNotch
0x7705000 - 0x7819fff com.MOTU.MAS.plugin.ArcPan 2.3 /Library/Audio/Plug-Ins/MAS/Arc Panner.bundle/Contents/MacOS/Arc Panner
0x7884000 - 0x79a5fff com.MOTU.MAS.plugin.Auralizer 2.3 /Library/Audio/Plug-Ins/MAS/Auralizer.bundle/Contents/MacOS/Auralizer
0x7a11000 - 0x7abefff com.MOTU.MAS.plugin.AutoPan 4.2 /Library/Audio/Plug-Ins/MAS/AutoPan.bundle/Contents/MacOS/AutoPan
0x7b06000 - 0x7ba7fff com.MOTU.MAS.plugin.BassManager 2.2 /Library/Audio/Plug-Ins/MAS/Bass Manager.bundle/Contents/MacOS/Bass Manager
0x7be8000 - 0x7c46fff com.MOTU.MAS.plugin.Buffy 2.3 /Library/Audio/Plug-Ins/MAS/Buffy.bundle/Contents/MacOS/Buffy
0x7c74000 - 0x7d32fff com.MOTU.MAS.plugin.Calibration 2.2.1 /Library/Audio/Plug-Ins/MAS/Calibration.bundle/Contents/MacOS/Calibration
0x7d7f000 - 0x7e08fff com.MOTU.MAS.plugin.Chorus 3.2 /Library/Audio/Plug-Ins/MAS/Chorus.bundle/Contents/MacOS/Chorus
0x7e48000 - 0x7f5cfff com.MOTU.MAS.plugin.Delay 3.2 /Library/Audio/Plug-Ins/MAS/Delay.bundle/Contents/MacOS/Delay
0x7fc0000 - 0x8055fff com.MOTU.MAS.plugin.Dynamics 3.2 /Library/Audio/Plug-Ins/MAS/Dynamics.bundle/Contents/MacOS/Dynamics
0x8097000 - 0x811cfff com.MOTU.MAS.plugin.Echo 3.2 /Library/Audio/Plug-Ins/MAS/Echo.bundle/Contents/MacOS/Echo
0x815d000 - 0x8259fff com.MOTU.MAS.plugin.eVerb 4.3 /Library/Audio/Plug-Ins/MAS/eVerb.bundle/Contents/MacOS/eVerb
0x8312270 - 0x8312322 CFMPriv_CoreFoundation PEF binary: CFMPriv_CoreFoundation
0x83128f0 - 0x8312967 CFMPriv_System PEF binary: CFMPriv_System
0x8312be0 - 0x8312cb0 CFMPriv_CarbonSound PEF binary: CFMPriv_CarbonSound
0x8312d20 - 0x8312df3 CFMPriv_CommonPanels PEF binary: CFMPriv_CommonPanels
0x8312ec0 - 0x8312f7b CFMPriv_Help PEF binary: CFMPriv_Help
0x8312f80 - 0x831304a CFMPriv_HIToolbox PEF binary: CFMPriv_HIToolbox
0x83130c0 - 0x8313196 CFMPriv_HTMLRendering PEF binary: CFMPriv_HTMLRendering
0x8313200 - 0x83132d3 CFMPriv_ImageCapture PEF binary: CFMPriv_ImageCapture
0x8313350 - 0x8313435 CFMPriv_NavigationServices PEF binary: CFMPriv_NavigationServices
0x83134a0 - 0x8313576 CFMPriv_OpenScripting&#63743;MacBLib PEF binary: CFMPriv_OpenScripting&#63743;MacBLib
0x8313640 - 0x83136fe CFMPriv_Print PEF binary: CFMPriv_Print
0x8313710 - 0x83137dd CFMPriv_SecurityHI PEF binary: CFMPriv_SecurityHI
0x8313850 - 0x8313932 CFMPriv_SpeechRecognition PEF binary: CFMPriv_SpeechRecognition
0x83139a0 - 0x8313a73 CFMPriv_CarbonCore PEF binary: CFMPriv_CarbonCore
0x8313ae0 - 0x8313bb3 CFMPriv_OSServices PEF binary: CFMPriv_OSServices
0x8313c80 - 0x8313d42 CFMPriv_AE PEF binary: CFMPriv_AE
0x8313d50 - 0x8313e15 CFMPriv_ATS PEF binary: CFMPriv_ATS
0x8313e80 - 0x8313f57 CFMPriv_ColorSync PEF binary: CFMPriv_ColorSync
0x8313fd0 - 0x83140b3 CFMPriv_FindByContent PEF binary: CFMPriv_FindByContent
0x8314120 - 0x83141fa CFMPriv_HIServices PEF binary: CFMPriv_HIServices
0x8314260 - 0x8314340 CFMPriv_LangAnalysis PEF binary: CFMPriv_LangAnalysis
0x83143c0 - 0x83144a6 CFMPriv_LaunchServices PEF binary: CFMPriv_LaunchServices
0x8314570 - 0x8314647 CFMPriv_PrintCore PEF binary: CFMPriv_PrintCore
0x8314650 - 0x8314712 CFMPriv_QD PEF binary: CFMPriv_QD
0x8314800 - 0x83148e9 CFMPriv_SpeechSynthesis PEF binary: CFMPriv_SpeechSynthesis
0x8405000 - 0x84a1fff com.MOTU.MAS.plugin.Flanger 4.2 /Library/Audio/Plug-Ins/MAS/Flanger.bundle/Contents/MacOS/Flanger
0x84e7000 - 0x8733fff com.motu.MachFive 1.2.3 (1.0) /Library/Audio/Plug-Ins/MAS/MachFive MAS.bundle/Contents/MacOS/MachFive MAS
0x8a61000 - 0x8a6afff com.MOTU.MAS.plugin.Reverse Reverse version 1.0.1, 8/10/03 (1.0.1) /Library/Audio/Plug-Ins/MAS/Reverse.bundle/Contents/MacOS/Reverse
0x8ab7000 - 0x8ac9fff com.paceap.iokit.iLokSupport 5.4.1 /Library/Application Support/PACE Anti-Piracy/iLokSupport.bundle/Contents/MacOS/iLokSupport
0x8ad8000 - 0x8ae6fff com.apple.iokit.IOUSBLib 2.5.9 /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x8b78000 - 0x8bd0fff com.MOTU.MAS.AudioUnitWrapper 1.5.alpha3 /Library/Audio/Plug-Ins/MAS/MAS AudioUnit Support.bundle/Contents/MacOS/MAS AudioUnit Support
0x8c23000 - 0x8cbbfff com.MOTU.MAS.plugin.MWCompressor 3.3 /Library/Audio/Plug-Ins/MAS/MasterWorks Compressor.bundle/Contents/MacOS/MasterWorks Compressor
0x8d04000 - 0x8e14fff com.MOTU.MAS.plugin.MWEQ 1.1 /Library/Audio/Plug-Ins/MAS/MasterWorks EQ.bundle/Contents/MacOS/MasterWorks EQ
0x8e6f000 - 0x8f15fff com.MOTU.MAS.plugin.MWGate 2.2 /Library/Audio/Plug-Ins/MAS/MasterWorks Gate.bundle/Contents/MacOS/MasterWorks Gate
0x8f62000 - 0x904afff com.MOTU.MAS.plugin.MWLimiter 4.2 /Library/Audio/Plug-Ins/MAS/MasterWorks Limiter.bundle/Contents/MacOS/MasterWorks Limiter
0x90af000 - 0x9113fff com.MOTU.MAS.plugin.MSDecoder 2.2 /Library/Audio/Plug-Ins/MAS/MS Decoder.bundle/Contents/MacOS/MS Decoder
0x9143000 - 0x91fdfff com.MOTU.MAS.plugin.MultiModeFilter 2.2 /Library/Audio/Plug-Ins/MAS/Multimode Filter.bundle/Contents/MacOS/Multimode Filter
0x9253000 - 0x9349fff com.MOTU.MAS.plugin.MultiPan 2.3 /Library/Audio/Plug-Ins/MAS/n-Panner.bundle/Contents/MacOS/n-Panner
0x93b3000 - 0x93d5fff com.audioease.VSTWrapper VST WrapperX version 4.1.3 (1.0) /Library/Audio/Plug-Ins/MAS/VST Wrapper/VST WrapperX.bundle/Contents/MacOS/VST WrapperX
0x9505000 - 0x9611fff com.MOTU.MAS.plugin.ParaEQ 4.2 /Library/Audio/Plug-Ins/MAS/ParaEQ.bundle/Contents/MacOS/ParaEQ
0x9668000 - 0x9702fff com.MOTU.MAS.plugin.PatternGate 1.0 /Library/Audio/Plug-Ins/MAS/PatternGate.bundle/Contents/MacOS/PatternGate
0x974f000 - 0x97e6fff com.MOTU.MAS.plugin.Phaser 4.2 /Library/Audio/Plug-Ins/MAS/Phaser.bundle/Contents/MacOS/Phaser
0x982a000 - 0x98ccfff com.MOTU.MAS.plugin.Plate 2.2 /Library/Audio/Plug-Ins/MAS/Plate.bundle/Contents/MacOS/Plate
0x991a000 - 0x99cefff com.MOTU.MAS.plugin.Preamp 3.2 /Library/Audio/Plug-Ins/MAS/PreAmp-1.bundle/Contents/MacOS/PreAmp-1
0x9a25000 - 0x9a90fff com.MOTU.MAS.plugin.QuanJr 2.2 /Library/Audio/Plug-Ins/MAS/Quan Jr.bundle/Contents/MacOS/Quan Jr
0x9ac2000 - 0x9b29fff com.MOTU.MAS.plugin.Reverb 3.2 /Library/Audio/Plug-Ins/MAS/Reverb.bundle/Contents/MacOS/Reverb
0x9b59000 - 0x9be5fff com.MOTU.MAS.plugin.RingMod 2.2 /Library/Audio/Plug-Ins/MAS/RingMod.bundle/Contents/MacOS/RingMod
0x9c28000 - 0x9d00fff com.MOTU.MAS.plugin.SonicModulator 3.2 /Library/Audio/Plug-Ins/MAS/Sonic Modulator.bundle/Contents/MacOS/Sonic Modulator
0x9d6c000 - 0x9dfafff com.MOTU.MAS.plugin.Tremolo 4.2 /Library/Audio/Plug-Ins/MAS/Tremolo.bundle/Contents/MacOS/Tremolo
0x9e3c000 - 0x9ec7fff com.MOTU.MAS.plugin.Trigger 2.2 /Library/Audio/Plug-Ins/MAS/Trigger.bundle/Contents/MacOS/Trigger
0x9f09000 - 0x9fbbfff com.MOTU.MAS.plugin.Trim 4.2 /Library/Audio/Plug-Ins/MAS/Trim.bundle/Contents/MacOS/Trim
0xa009000 - 0xa151fff com.MOTU.MAS.plugin.TriPan 2.3 /Library/Audio/Plug-Ins/MAS/TriPan.bundle/Contents/MacOS/TriPan
0xaadf000 - 0xaaf79de <Unknown> PEF binary: <Unknown>
0xacb6000 - 0xace3fff com.cycling74.PluggoAU 3.5.3 (3.5.3 (Panther)) /Library/Audio/Plug-Ins/Components/Pluggo.component/Contents/MacOS/Pluggo
0xaced000 - 0xacf7839 MaxAudioLib PEF binary: MaxAudioLib
0xbe3b000 - 0xbe64fff com.MOTU.plugin.ControlSurface.HUI 1.2 (1.0) /Library/Audio/Plug-Ins/MOTU Control Surface/HUI.bundle/Contents/MacOS/HUI
0xbe8c000 - 0xbeb9fff com.MOTU.plugin.ControlSurface.MackieControl 1.2 (1.0) /Library/Audio/Plug-Ins/MOTU Control Surface/MackieControl.bundle/Contents/MacOS/MackieControl
0xbee2000 - 0xbf15fff com.MOTU.plugin.ControlSurface.SAC_2_2 3.1 (1.0) /Library/Audio/Plug-Ins/MOTU Control Surface/SAC DP Driver.bundle/Contents/MacOS/SAC DP Driver
0xbf35000 - 0xbf843c7 CarbonLibpwpc PEF binary: CarbonLibpwpc
0xbfa0000 - 0xc001f19 MaxPPC3.1 PEF binary: MaxPPC3.1
0x10000000 - 0x1002ffff net.sourceforge.LAMEframework 3.95 (1.0.2) /Library/Frameworks/LAME.framework/Versions/A/LAME
0x11000000 - 0x11012fff AllUtilitiesLib.dylib /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/AllUtilitiesLib.dylib
0x11100000 - 0x11102fff PerfErrorLib.dylib /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/PerfErrorLib.dylib
0x11200000 - 0x11208fff FileSystemLib.dylib /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/FileSystemLib.dylib
0x11300000 - 0x11350fff PureDSP.dylib /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/PureDSP.dylib
0x11600000 - 0x11699fff OMF_AAF.dylib /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/OMF_AAF.dylib
0x11800000 - 0x11805fff MotuPublicObjects /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/Frameworks/MotuPublicObjects.framework/Versions/A/MotuPublicObjects
0x11900000 - 0x119b1fff MotuAudioSystem /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/Frameworks/MotuAudioSystem.framework/Versions/A/MotuAudioSystem
0x11c00000 - 0x11c90fff MidiSystem /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/Frameworks/MidiSystem.framework/Versions/A/MidiSystem
0x11e00000 - 0x11e1dfff XMLLib.dylib /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/XMLLib.dylib
0x11f00000 - 0x11f8ffff PerfFoundation.dylib /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/PerfFoundation.dylib
0x12100000 - 0x12134fff GenericPanes.dylib /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/GenericPanes.dylib
0x12600000 - 0x12629fff DPBasicUI.dylib /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/DPBasicUI.dylib
0x12800000 - 0x1299afff DPPart2.dylib /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/DPPart2.dylib
0x12e00000 - 0x131b4fff PerfEngine.dylib /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/PerfEngine.dylib
0x13700000 - 0x1372cfff MSL_Perf.dylib /Applications/MOTU DP4.6 Folder/Digital Performer 4.61/Contents/MacOS/MSL_Perf.dylib
0x70000000 - 0x700fcfff com.apple.audio.units.Components 1.4.5 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8668e000 - 0x866f6fff com.apple.LiveType.framework 2.0.2 /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x8fe00000 - 0x8fe52fff dyld 46.12 /usr/lib/dyld
0x90000000 - 0x901bdfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90215000 - 0x9021afff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x9021c000 - 0x90269fff com.apple.CoreText 1.0.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90294000 - 0x90345fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90374000 - 0x9072ffff com.apple.CoreGraphics 1.258.61 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x907bc000 - 0x90895fff com.apple.CoreFoundation 6.4.7 (368.2Cool /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x908de000 - 0x908defff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x908e0000 - 0x909e2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a3c000 - 0x90ac0fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90aea000 - 0x90b5cfff IOKit /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90b72000 - 0x90b84fff libauto.dylib /usr/lib/libauto.dylib
0x90b8b000 - 0x90e62fff com.apple.CoreServices.CarbonCore 681.9 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90ec8000 - 0x90f48fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f92000 - 0x90fd3fff com.apple.CFNetwork 129.20 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90fe8000 - 0x91000fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91010000 - 0x91091fff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x910d7000 - 0x91100fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91111000 - 0x9111ffff libz.1.dylib /usr/lib/libz.1.dylib
0x91122000 - 0x912ddfff com.apple.security 4.6 (29770) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913dc000 - 0x913e5fff com.apple.DiskArbitration 2.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913ec000 - 0x91414fff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91427000 - 0x91432fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x91437000 - 0x9143ffff libbsm.dylib /usr/lib/libbsm.dylib
0x91443000 - 0x914befff com.apple.audio.CoreAudio 3.0.4 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x914fb000 - 0x914fbfff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x914fd000 - 0x91535fff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91550000 - 0x91622fff com.apple.ColorSync 4.4.9 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91675000 - 0x91706fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9174d000 - 0x91804fff com.apple.QD 3.10.24 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91841000 - 0x9189ffff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x918ce000 - 0x918effff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91903000 - 0x91928fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9193b000 - 0x9197dfff com.apple.LaunchServices 182 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x91999000 - 0x919adfff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x919bb000 - 0x91a01fff com.apple.ImageIO.framework 1.5.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91a18000 - 0x91adffff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91b2d000 - 0x91b42fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91b47000 - 0x91b65fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b6b000 - 0x91c22fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91c71000 - 0x91c75fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91c77000 - 0x91cdffff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91ce4000 - 0x91d21fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91d28000 - 0x91d41fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91d46000 - 0x91d49fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91d4b000 - 0x91e29fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x91e49000 - 0x91e49fff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91e4b000 - 0x91f30fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91f38000 - 0x91f57fff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91fc3000 - 0x92031fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9203c000 - 0x920d1fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x920eb000 - 0x92673fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x926a6000 - 0x929d1fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92a01000 - 0x92aeffff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92af2000 - 0x92b7afff com.apple.DesktopServices 1.3.6 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x92bbb000 - 0x92de6fff com.apple.Foundation 6.4.8 (567.29) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92f13000 - 0x92f31fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92f3c000 - 0x92f96fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92fb4000 - 0x92fb4fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92fb6000 - 0x92fcafff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92fe2000 - 0x92ff2fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92ffe000 - 0x93013fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93025000 - 0x930acfff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x930c0000 - 0x930cbfff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x930d5000 - 0x93102fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9311c000 - 0x9312bfff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x93137000 - 0x9319dfff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x931ce000 - 0x9321dfff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9324b000 - 0x93268fff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9327a000 - 0x93287fff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x93290000 - 0x9359efff com.apple.HIToolbox 1.4.9 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x936ee000 - 0x936fafff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93772000 - 0x93772fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93774000 - 0x93da7fff com.apple.AppKit 6.4.7 (824.41) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94134000 - 0x941a6fff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x941df000 - 0x942a3fff com.apple.audio.toolbox.AudioToolbox 1.4.5 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x942f5000 - 0x942f5fff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x942f7000 - 0x944b7fff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94501000 - 0x9453efff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x94546000 - 0x94596fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9459f000 - 0x945b3fff com.apple.CoreVideo 1.4 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9475c000 - 0x9476bfff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x94773000 - 0x94780fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x947c6000 - 0x947dffff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x947e6000 - 0x94abbfff com.apple.QuickTime 7.1.5 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94b7f000 - 0x94bf0fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x94c63000 - 0x94c85fff libmx.A.dylib /usr/lib/libmx.A.dylib
0x96b85000 - 0x96bc4fff com.apple.audio.midi.CoreMIDI 1.5 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x96f8c000 - 0x96fabfff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x977b1000 - 0x977befff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x98c7e000 - 0x9982bfff com.apple.QuickTimeComponents.component 7.1.5 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x9a772000 - 0x9a773fff com.apple.iokit.dvcomponentglue 1.7.9 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
Model: PowerMac7,3, BootROM 5.1.8f7, 2 processors, PowerPC G5 (2.2), 1.8 GHz, 1.25 GB
Graphics: GeForce FX 5200, GeForce FX 5200, AGP, 64 MB
Memory Module: DIMM0/J11, 128 MB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM1/J12, 128 MB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM2/J13, 512 MB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM3/J14, 512 MB, DDR SDRAM, PC3200U-30330
AirPort: AirPort Extreme, 405.1 (3.90.34.0.p18)
Modem: MicroDash, UCJ, V.92, 1.0F, APPLE VERSION 2.6.6
Network Service: Built-in Ethernet, Ethernet, en0
Serial ATA Device: Maxtor 6Y080M0, 76.33 GB
Parallel ATA Device: PIONEER DVD-RW DVR-117D
USB Device: MobilePre, M Audio, Up to 12 Mb/sec, 500 mA
USB Device: Hub, Up to 480 Mb/sec, 500 mA
USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
USB Device: Microsoft ® Laser Mouse 6000, Microsoft Corporation, Up to 1.5 Mb/sec, 100 mA
USB Device: iLok, iLok, Up to 1.5 Mb/sec, 100 mA
USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
USB Device: Apple Cinema Display, Up to 1.5 Mb/sec, 500 mA
USB Device: Deskjet D4100 series, HP, Up to 480 Mb/sec, 500 mA
FireWire Device: LaCie d2 Extreme LUN 0, LaCie Group SA, Up to 400 Mb/sec
FireWire Device: unknown_device, unknown_value, Up to 400 Mb/sec
HAHAHAHA oh man that sunglasses icon is painfully ironic! THERE IS NOTHING COOL ABOUT THIS OK?! haha...nevermind its not there anymore.
PostPosted: Sun Apr 15, 2007 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you boot from another drive and checked the disk with Alsoft Diskwarrior?
EdisonRex
Audio files: 171
PostPosted: Sun Apr 15, 2007 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Digiton wrote:
thanks
Electro80's comment about checking your disk and doing a repair PRONTO is looking like a very pertinent comment right now.
Digiton
PostPosted: Sun Apr 15, 2007 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
in terms of booting from another drive, if this is what you mean, i dumped all of my project info/files onto my external hard drive and tried opening it up from there. Same bullshit. excuse my french. I have not tried diskwarrior. I guess i should purchase? that. ho hum
EdisonRex
Audio files: 171
PostPosted: Sun Apr 15, 2007 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
It is, as you noted, crashing on a VST plugin load. You might wish to remove the VST plugins (forcibly) from their directory, you should know which plugin as it is one you are using in this project (assuming no other projects are crashing too)
Digiton
haha, damn at least you guys know how to turn tragedy into comedy. Props on the usage of bold typeface. OK, so look, when you say doing a repair, are you just talking about opening up disk utilities? I've done that and clicked repair permissions, and you know what? It doesn't seem like much is getting fixed. Only few things (usually .framework i think) appear on the log. .....is this not all i should be doing? I will now get that diskwarrior thing.....but i would like to know what you mean by checking/repairing disk. Sorry, but I wish i knew more about hardcore computer nuts and bolts. Thanks yall
EdisonRex
Audio files: 171
PostPosted: Sun Apr 15, 2007 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Diskwarrior rocks. You should spend the money on it. I did and it saved my ass once.
If your external drive is bootable (you can make it so), you boot from the external drive and then you can repair the primary. You can just use the Apple Disk Doctor, but it isn't as good as Disk Warrior. It might fix the problem though.
At least you have the audio and the project. It is probably repairable, from what it looks like here. What VST did you load into this project?
EdisonRex
Audio files: 171
PostPosted: Sun Apr 15, 2007 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
oh yeah, that's a Pluggo VST you got there? Make sure you also talk to Cycling74 then too. MOTU will send you to them anyway.
Which Pluggo have you got loaded? I have Pluggo here.
PostPosted: Sun Apr 15, 2007 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Try booting off a system DVD. Run the Disk Utility app and check the drive.
This app does only minor checks and repairs. It catches some really nasty stuff and some light shit. how well it actually repairs any and all of these well is something else. DiskWarrior is a must.
My 3 standard tools are
iDefrag
DiskWarrior
Datarescue
I use iDefrag not only for defragging.. which is not that often really.. but mainly for checking which ifles are ragged and where they actually are on the disk.
DiskWarrior.. a great tool
I use Datarescue for getting stuff off damaged drives and for undelete stuff and such.
If I were you, I wouldn´t use that partition where you have DP and / or your DP files until it has been checked.
Uh.. and.. ALWAYS have a drive around somewhere with a basic system installed + various serious tools for system maintenance and system repair.
Uh... strike that.. ALWAYS have a bunch of drives around just in case.. Shocked Laughing
Digiton
PostPosted: Sun Apr 15, 2007 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
i use vst wrapper and it seems to load every vst i have into the project. So, i doubt that removing the .vst documents from their location would fix anything, because as i said, most/all other projects open fine and they all load the same (meaning all) vsts plugins. If i am at least correct here, the loading of vsts on my part doesn't seem to be a manual thing. It just happens automatically in one fell sweep before loading the actual project................in terms of having the vst's active as virtual instrument or effect on an audio track, maybe thats it what it/you is/are referring to? But I KNOW i didn't have any effects on the mixing board, and there is no midi whatsoever on this particular project...anyway i'm going to try removing the vst's and loading....here we go again
Digiton
PostPosted: Sun Apr 15, 2007 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
well, i removed the vst folder from my library and same old stuff. Ok, i will invest in disk warrior and see what happens. I am so past the point of being mad I just don't give a fuck what happens. But i'm hoping for the best
PostPosted: Sun Apr 15, 2007 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
A disk has a directory. Actually, a disk has several. These can become fucked up. Sometimes this is caused by minor crashes.. stuff so minor you don´t even actually notice.. some shit is caused by bad software/incompatabilities... other shit just happens.. digital erosion.. sunstorms.. you know.. Sometimes the disk might even be bad.. bad blocks.. the drive is failing.. A disk drive is like a 60s french car.
You can be sure of one thing.. it will happen and it always happens.
You need tools for checking and fixing.
Datarescue is cool for actually getting stuff off sick drives.
When you see weird crashes, always check the drive first.
Anyways.. http://www.alsoft.com/
You should have these too:
http://www.prosofteng.com/products/data_rescue_info.php
http://coriolis-systems.com/iDefrag.php
If you don´t quite know how to use such tools, get back to us and ask for more help. Very Happy
EdisonRex
Audio files: 171
PostPosted: Sun Apr 15, 2007 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
try starting a new project and importing what you can to it. Sorry to keep throwing different ideas but that's how it is with these things. Crying or Very sad
But do what elektro80 says first. Boot off the system CD/DVD and run disk doctor. At least you can see if there is a disk problem.
Digiton
PostPosted: Sun Apr 15, 2007 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
YOU GUYS ROCK!!!! okay, i will take some time and just try and figure this all out. I mean, i think its a mistake to get overly precious about one particular work, but this is goddamn 17 minute long non-looping (but with recurring them and variance) electronic piece of music and i'm just trying to get the produce on the truck, if u catch my drift.
PostPosted: Sun Apr 15, 2007 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
The Disk Utility app in Applications/Utilities will not catch ALL errors. Idea
OK.. perhaps this track is not worth rescuing or whatever.. but still.. this is not only about the track and the related files.. but about the integrity of the whole drive.
Always check for the nasty stuff first.
Digiton
PostPosted: Sun Apr 15, 2007 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
i don't recall breaking any mirrors lately...but WHAT IS GOIN ON WITH MY LUCK!
ok, so i ran disk repair on my HD drive (booting off the os x DVD) like you guys said. I was hoping it would say it needed something to repair so i could at least feel something was working. It jovially told me that everything was ok. I checked my external hard drive just for shits and cackles and it was "fine" as well.
Ok, next step, I downloaded Disk Warrior. Site wasn't looking so robust, but i'll take both your words for it. And if you've seen my site I shouldn't talk (html skills lacking).
Point of the story is is that I donwloaded it from the site after payment and when the .zip document was unstuffing "Stuffit" crashed on me. Aint life grand? I'm sure this is not the end of the world, but like i always say, what is?
-i have a powerpc mac not the intel kind....does the .hqx "argument" (max msp talking here) to the zipped file mean its for intel computers? I doubt it but i am just flummoxed at the nature of my day thus far.
PostPosted: Sun Apr 15, 2007 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
.hqx means binhexing.. which means that a file or whatever has been encoded into a "text" file. It should unstuff with the latest stufit expander. See if you find it at versiontracker.com
Trivia: it is smart to turn off that "will open trusted files" thing in Safari.
Please work from another partition ( with a bootable system ) or from another drive altogether.. ( yeah.. another drive.. I see you have a lacie there )
You MUST run DW from another drive anyway.. so .. Very Happy
BTW: It is time to say that stuffit deluxe is kinda dead. The full suite is flaky on DAWs. You can use other tols for compression. You will however still need Stuffit Expander.
