 Forum index » Instruments and Equipment » OSX as a music workstation
&#$*%*&!!! DP 4.61 KILLING MY SOUL..please help!
Page 6 of 8 [186 Posts]
Digiton
PostPosted: Sun Apr 15, 2007 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
the project of course is not opening.....
1)do you know what the corrupted file was? I think you said reinstalling might work...
2)if i start a new project, i know how to import the sound files etc. but wouldn't i have to re "edit" and basically resequence the entire song?
Lets get it!
PostPosted: Sun Apr 15, 2007 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
File: "._MOTU PCI Audio Console.rsrc"
Detected that the resource header is damaged
Console.app/Contents/Resources/"
How bad this is depends a bit on how DP or whatever uses that file. In general the death of resource header is not that cool at all. I don´t know Dp, and I have no way to debug this from here.
Can you create and save a new project?
Flickr
PostPosted: Sun Apr 15, 2007 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
FYI:
A .kext file is a kernel extension. They're generally used for device drivers and other things that need to modify the system at the lowest level.
Flickr
Digiton
PostPosted: Sun Apr 15, 2007 4:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
i just created and saved a new project
Lets get it!
EdisonRex
Audio files: 172
a reinstall of DP wouldn't hurt anything.
I don't think it's DP doing it. Make sure your VSTs and everything are happy.
Remember that this was only one project crashing. If it still crashes, we try rescue, as I said, it's a matter of opening a new project and picking stuff out of the old one.
Do, please make sure that other projects work! It'd suck to be thinking we have a good install and a bad project, just to find out that the install is bad.
So yes, a reinstall won't do any harm. But check other projects too. Please.
Garret: It's so retro.
Digiton
sounds bad
Lets get it!
Audio files: 278
PostPosted: Sun Apr 15, 2007 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
elektro80 wrote:
BTW.. the new VDGG reunion is fun.
It was sold out Twisted Evil Evil or Very Mad I knew too late.
Sorry for the interuption.
PostPosted: Sun Apr 15, 2007 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Of what importance this specific .kext file is I simply don´t know. However, this seems at first glance to be your soundcard driver. So.. intuitively this seems to be pretty uncool. This might not be the real problem you are facing here though.
Flickr
EdisonRex
Audio files: 172
try reinstalling the software for the MOTU hardware. It's a 2496 or somesuch?
Digiton
PostPosted: Sun Apr 15, 2007 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok guys, i'm about to call it quits..but another news flash i tried opening an older project as edison suggests and it crashed...it fucking crashed. So I guess this could mean just reinstalling DP 4 could do the trick? Here is the thing, if I reinstall (or upgrade) my DAW will I have to re-enter all the serial numbers of each plugin? I am doubtful that will happen!
Lets get it!
Digiton
PostPosted: Sun Apr 15, 2007 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm unclear here....
Lets get it!
EdisonRex
Audio files: 172
PostPosted: Sun Apr 15, 2007 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
reinstall the hardware's software first, then reinstall DP.
let me know how you get on. i'll check in, in the morning. Good luck.
PostPosted: Sun Apr 15, 2007 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Listen guys, I´ll step back now and let EdisonRex take over the decisionmaking. Instead I´ll practice diversions with Blue Hell.
Flickr
Digiton
ok, so you mean reinstall the software for the sound card? Sorry this is the last post for today i swear
Lets get it!
EdisonRex
Audio files: 172
PostPosted: Sun Apr 15, 2007 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry I keep thinking you have some MOTU hardware too.
If you don't, then reinstall the software for whatever hardware you have, then reinstall your DP, THEN! reinstall your VSTs. Something is fucked up, and a reinstall will probably get it all back in shape. But you need to get all of the bits straight.
Digiton
PostPosted: Sun Apr 15, 2007 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok thanks!
Lets get it!
EdisonRex
Audio files: 172
PostPosted: Sun Apr 15, 2007 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm about to fall over to sleep. I do that from time to time. PM or check in on this thread, please, with progress. I'll be back in 8 hours. Smile
If anybody else can help., feel free. I'm a team player :p
PostPosted: Sun Apr 15, 2007 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sometimes plugns will act up. When loading a certain plugiun the project will crash.. You could try to remove certain VST plugins and see what DP does.
remove? Actually.. you could just try to move the plugins. Do you know where to find them?
Most DAWs will return an error whenever a plugin used in a project is missing.. but still open the project.
Flickr
EdisonRex
Audio files: 172
PostPosted: Sun Apr 15, 2007 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
that was something I was thinking based on his error message. But I think there's something else going on, but I don't see what the "else" is.
He said he tried this and it still crashed. Lets see if after reinstalls, at least the application starts.
PostPosted: Sun Apr 15, 2007 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Path:
/Library/Audio/Plug-Ins/VST
Try moving these to some other folder somewhere. Shut DP down before doing this.
Duplicate your current project file and open the duplicate when debugging this,
Flickr
PostPosted: Sun Apr 15, 2007 4:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, you are still with us! Very Happy Nice!
Flickr
PostPosted: Sun Apr 15, 2007 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
But did he really move the right plugins out....?
I dunno. A reinstall might not hurt.. but it can be just as smart to mess with this before he reinstalls. That way he comes as close to "fresh" as possible.
Flickr
PostPosted: Sun Apr 15, 2007 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can imagine several states a plug-in can be in when being called by the DAW. Plug-ins also often have their own pref files.
One possible move is to try to remember all the plugins used and then open these in a new project and check if any of these are asking for a registration code or something.
Flickr
PostPosted: Sun Apr 15, 2007 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are DP project files really bundles? Any chance there is an xml inside there somewhere with a list of all plug-ins used?
Flickr
PostPosted: Sun Apr 15, 2007 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Digiton, did you ever tell us which sound card you use? Do you have a MOTU device installed?
Flickr
