  bingsatellites Mostly Ambient
Monophonic random-LFO
Page 1 of 1 [11 Posts]
torsig1967
PostPosted: Thu Apr 19, 2007 9:58 am    Post subject: Monophonic random-LFO
Subject description: Where's the mono version of random generator
I wanted to make a monophonic LFO modulating a polyphonic patch - vintage polyphonic synthesizer style that is.
No problem with the usual wave forms and S/H but I found no way to make noise modulation monophonic. There's a nice LFO random generator but that one has no "mono" button.
Any solutions?
Falk
G2 patch files: 29
PostPosted: Thu Apr 19, 2007 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Might this work?
Picture of possibly mono random LFO
 Filesize:  12.27 KB
 Viewed:  2212 Time(s)
torsig1967
PostPosted: Fri Apr 20, 2007 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Falk wrote:
Might this work?
Yes, it does. But that is S/H, not noise.
PostPosted: Fri Apr 20, 2007 2:36 am    Post subject: Re: Monophonic random-LFO
Confused Confused Confused
Eh???
Why on earth do you want to do this??? Shocked Laughing
Noise is noise. Polyphonic or monophonic noise??? Why? Please explain.
ACHTUNG!
Falk
G2 patch files: 29
PostPosted: Fri Apr 20, 2007 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi torsig.
If you clock a S/H high enough, isn't that noise?
Is there something that I am missing?
torsig1967
PostPosted: Fri Apr 20, 2007 6:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Falk wrote:
Hi torsig.
Ahh, maybe you're right. If I clock it at a very high frequency (from an osc that is) it might "sound" like noise. I'll try that when I get home.
"Noise is noise. Polyphonic or monophonic noise??? Why? Please explain."
v-un-v: You're right in a way that noise is noise. But I want to use the noise as a modulator and I want all voices to be modulated exactly the same. Therefore I want all voices to be modulated by the same noise source. This does not sound the same as letting them be modulated by different and independent noise sources.
Falk
G2 patch files: 29
PostPosted: Fri Apr 20, 2007 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok torsig.
This is what you want then. An inverter connected to itself gives the fastest clock that will reliably clock the ClkRndGen module.
Hopefully it is noisy enough for you.
 Filesize:  5.44 KB
 Viewed:  2177 Time(s)
torsig1967
PostPosted: Sun Apr 22, 2007 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, but what I really was looking for was a monophonic version of the random generator. Maybe it's not right to call that noise. it's not S/H either.
Sounds to me that the closest I get is to use a monophonic S/H and then send that to a smooth module. It has to be manually tuned to the frequency of the S/H though.
Falk
G2 patch files: 29
PostPosted: Sun Apr 22, 2007 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Either the glide module or a low pass filter (static ones are not that expensive).
Also try out pressing the Col button on the ClkRndGen module. That makes a large difference as wel.
Off to bed for me ....
davep
Audio files: 10
G2 patch files: 73
PostPosted: Wed May 02, 2007 10:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well THAT's strange - it looks like the MONO button on the ClockRand module doesn't work! Regardless if the mono buttton is depressed or not, the ClockRand module generates a DIFFERENT random value for each voice, even when it is clocked from a MONO LFO square wave.
But here are a few workarounds. The basic idea is to create a complex control signal by combining & processing a few simple waveforms from LFOs in MONO mode. technically, the signal isn't random, but when you add three LFOs at different rates & levels, and start runnign them through Ring Mods or WaveWrappers (that are in turn modulated by another MONO LFO) it starts to sounds pretty random, yet it retains the MONO behavior across all voices. Try different waveforms & different ways of combining & processing them for different behaviors.
I started using this idea out of necessity when I was making giant sweeping pads with fifteen LFOs and started running out of DSP. I discovered that two slave triangle LFOs at different rates combined in a Control Mixer sounded quite random and used a lot less DSP than the slave random LFO.
BTW, in these examples, the MasterOsc2 is used to provide a single-knob master rate control for the complex LFO signal. If you do this, be sure to turn the KBD tracking OFF or it won't be a MONO signal.
These examples all use three LFOs, but they are combined & processed in different ways to give an idea of the different types of 'behavior' that are possible. For example, the control signal behaves differently depending on whether you simply add the LFOs together with mixers (first example) or if you multiply them together using VCAs (second example) or do something more complex with wavewrappers & ring mods (third example). You can also use things like static shapers and KYBD/VEL scalers to alter the response.
MonoRandom1.pch
 Filename:  MonoRandom1.pch
 Filesize:  1.7 KB
 Downloaded:  94 Time(s)
MonoRandom2.pch
 Filename:  MonoRandom2.pch
 Filesize:  1.68 KB
 Downloaded:  83 Time(s)
MonoRandom3.pch
 Filename:  MonoRandom3.pch
 Filesize:  1.68 KB
 Downloaded:  85 Time(s)
Dave Peck
Falk
G2 patch files: 29
PostPosted: Thu May 03, 2007 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Well shame on me for not testing. I just assumed it would work.
Nice to see alternatives davep!
/Falk
JuneSolstice2013
