  Muied Lumens Frequencies
weird event timing issue
Page 1 of 1 [3 Posts]
gotascii
PostPosted: Thu Apr 26, 2007 8:27 am    Post subject: weird event timing issue Reply with quote  Mark this post and the followings unread
In the attached code I have a shred and the parent shred both waiting on an event signaled in another shred. Yet for some reason they appear to be signaled not at the same time. Can anyone explain why they aren't picking up the event at the same time? Thanks!
ClockTest.ck
 Filename:  ClockTest.ck
 Filesize:  231 Bytes
 Downloaded:  238 Time(s)
gotascii
PostPosted: Thu Apr 26, 2007 8:41 am    Post subject: signal vs broadcast... Reply with quote  Mark this post and the followings unread
I realized right after I posted this that I should be using e.broadcast no e.signal so all shreds waiting on the event get triggered...rtfm Wink
Kassen
PostPosted: Sat Apr 28, 2007 5:07 am    Post subject: Re: signal vs broadcast... Reply with quote  Mark this post and the followings unread
gotascii wrote:
rtfm Wink
Smile
Don't feel too bad, you solved your own problem so that's cool.
Actually you gave me a idea; I've been thinking about how to make all instances of a certain class do something at once (for example resetting them all) and that would be quite easy to acomplish using "signal" and I missed that entirely.
Kassen
