  Muied Lumens Frequencies
I'm cleaning my D-50 and need help
Page 1 of 4 [89 Posts]
Goto page: 1, 2, 3, 4 Next
Gothboy
PostPosted: Thu Apr 26, 2007 12:29 pm    Post subject: I'm cleaning my D-50 and need help Reply with quote  Mark this post and the followings unread
I have a Roland D-50 and it has one G key in the middle of the keyboard that makes no sound. I had the same problem with the lowest D but after spraying solvent cleaner between the keys I was able to get that one working again. I need to get at the rubber contact pad underneath this G key and clean it with some denatured alchohol. I've opened up the bottom and now have to remove the two computer cards to get to the keys. There's a small one on the left and the Roland D-50 Main board on the right(see photo). How do I remove these.....just like any computer board? Question
Paging Dr. Krunkus!
 Filesize:  542.64 KB
 Viewed:  630 Time(s)
Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Novation SL49/Remote Zero
Mopho Desktop, Nord Lead 2, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland D-50, Alesis QS6, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE
Dymaxion Vehicle Music at www.dymaxionvehicle.com/
Audio files: 218
G2 patch files: 319
PostPosted: Thu Apr 26, 2007 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are you sure you need to remove those boards ... to me it looks more like there is a contact PCB under the keys for which the keys have to be removed in order to reach it. Do the keys have springs to hold 'm at the back side ?
Gothboy
PostPosted: Thu Apr 26, 2007 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
The whole metal part that you see there under the boards is the keyboard assembly. It's screwed to the chassis and there are no springs.
This is what I can tell so far. The board on the left....the small one...stays there but gets disconnected from the main board. It's actually attatched to the keyboard assembly. The main board is unscrewed and can be lifted up....but I'm not sure if all the cables to it are disconnected or not. AND, I don't know if I have to disattatch the cables that go to the power supply. Confused
Plus I've reached a new impasse......there are cables that reach up and over to the display that are bundled to the back of the keyboard assembly, preventing me from pulling it out(see photo) so I'm wondering if I have to completely remove the main board and then flip the keyboard assembly over while it stays attatched to work on the keys. Otherwise I'd have to cut the ties that bundle the cables.....which I don't want to do.
16 GB Ram
10.8.5/El Capitan
PostPosted: Fri Apr 27, 2007 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
From memory I think we need to disconnect enough of the main board to move it out of the way. Then the entire keyboard assembly will come out from under it.
Don't worry, I'm going in tonight!
PostPosted: Fri Apr 27, 2007 2:17 am    Post subject: Reply with quote  Mark this post and the followings unread
While I'm here, does anyone know the chances of reversing the Musitronics expansion, so I can go back to the original D50 configuration.
The expansion itself involves a small board which plugs into the socket for the original UV EPROM. The original EPROM then plugs into the board, which has another separate EPROM on it. There is one wire which is added from the new board to the old one. I assume this would have something to do with addressing the extra chip on the new board. Nothing has been cut on the original board.
If I just put the original EPROM straight into the original socket, and remove the address wire, will it revert back to the original setup? What are the chances that something will go wrong?
Audio files: 218
G2 patch files: 319
PostPosted: Fri Apr 27, 2007 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
If it is the way you wrote it's reversible - with the usual respect for the component pins of course etc.
Except maybe for the original EPROM socket which might have been stretched/bent out by the pins of the expansion board a bit more than good for it (depending on what type it is). If so, just buy a new socket (preferably the kind with the round/gold pins) and insert that one inbetween.
PostPosted: Fri Apr 27, 2007 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan,
your nod of approval is actually very reassuring. Smile
I've just begun the process of cleaning the keys/switches. Shocked
By comparison, getting rid of the expansion will be a piece of cake!
Photos following shortly.
Gothboy
PostPosted: Fri Apr 27, 2007 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
My problem isn't the removal of the board but the bundled cables that are strapped to the backside of the key assembly...preventing me from moving the key assembly out of the D-50(see the photo in the upper post).These cables are on the top right to the left of the Main board and one of them runs to the display buttons on the front....so you can't access the other end. This is the thing that perplexes me......is the keyboard assembly supposed to pull completely away from the main housing or just enough so it can be flipped over and worked on? Is it just this version of the D-50 that is like that? Confused
AFAIK the whole board has to come out, that's what the instructions I have tell me. Mainly because you want that delicate Main board out of the way to prevent any damage to it. Exclamation Must be very careful with it and use a grounding wrist strap when you go in to move it. Wink
I have a 4-page instruction in text form that a nice person from vintagesynth.com sent me last night. If you PM me I'll send them to you so we're working off the same page as it were. Wink
Unfortunately it makes no mention of the bundled cables in question. Rolling Eyes Take a look at these cables when you go in there and let me know what you think.
16 GB Ram
10.8.5/El Capitan
PostPosted: Fri Apr 27, 2007 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay,
All the keys have been cleaned.
To sort those cable bundles out you'll need to cut 6 cable ties along the back. Not the far left one, it's actually part of a clip which will let go when you remove the screw that goes through it. Don't worry about cutting the other 6, I put a little black cross on the metalwork to remind me where to put one back, but they stay together fairly well anyway.
The rubber contacts under the keys need to go back the same way around, (this is the key to your velocity sense) Exclamation
I actually removed the clear plastic strips which he talks about pushing out of the way. They don't hold the keys in (the springs do that) and they don't help stop dust. I think they are part of the manufacturing process, ie; they hold the keys in place until the springs get put on. Not needed, and heaps easier without them in the way. I won't throw them away just yet though. Wink
I cleaned out heaps of dust and crap from mine. Don't forget to take the opportunity to clean the actual keys as well. It comes up looking new if you do.
I've got some photos if you want them to look over.
Got to get some sleep now. Took about 3 hours all up.
Gothboy
PostPosted: Fri Apr 27, 2007 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
WOW! That was fast. Shocked I had to submit a mix today and was then going to get to this cleaning. I hoped we could work side by side and was told it takes a long time to do. I guess I'll have to work at my own speed then...... Rolling Eyes
So you actually cut the cable ties I was referring to? Did you re-bundle and attatch the cable ties that you cut when you put everything back together? I'll have to go to Radio shack to find some small white ties. Confused I wouldn't mind seeing those photos.
16 GB Ram
10.8.5/El Capitan
PostPosted: Sat Apr 28, 2007 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I knew I had three shifts on, so I did it last night. I thought three hours was a long time. It wasn't that hard though. Just take your time and be gentle. The only keys which could get mixed up, the G,A&D keys are labelled anyway. Very Happy
I actually only put back 2 of the six cable ties I cut. The other ones were under the main board. I s'pose I might go back in.
Hey Jan, I'm afraid your reassurance didn't cut it. When I fired it up, minus the expansion card, it was dead. The screen flashed and there was a pop in the headphones, but then the screen stayed blank, no sound. I wondered whether my lack of ESD precautions had finally caught up with me! Shocked But I decided to put the expansion back, and now it's running okay again. I think I'll leave it there, at least until I find out a bit more about it. (which I may never do now, depending on whether anyone from Musitronics still remembers how it works! Laughing )(or if Musitronics still exists?) Maybe the original EPROM is rendered un-bootable by the process of initializing the expansion? Maybe I could get a copy of the original ROM from Roland etc? I need a new ROM for my GS6 anyway. I might look into it.
BTW Photo's are coming soon.
Audio files: 218
G2 patch files: 319
PostPosted: Sat Apr 28, 2007 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry about that.
Unless a programmer is built in ... which is unusual but not impossible ... an application should not be able to write it's own EPROM.
Maybe it's not the original EPROM, or maybe traces were actually cut ?
Edit :
I found http://www.musitronics.de/german/produkte/d50_d550_mex.html in which it is explained that apart from the expansion it is also possible to install a "speed enhancement" option (Sped system). For that the original chrystal must be changed for a new one, probably a faster one (although the page doesn't ay that) and that might cause problems with wait states on the original EPROM.
PostPosted: Sat Apr 28, 2007 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's okay Jan,
I still trust you. Laughing
I took a closeup photo which I'll post later tonight when I get back from work. The crystal hasn't changed, cos the value is the same as what's printed on the PCB overlay. I'm keen to investigate this a bit further before I close up.
Audio files: 218
G2 patch files: 319
PostPosted: Sat Apr 28, 2007 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thx Very Happy .. but maybe I don't Laughing
Anyway, please let me know when you find out. I don't know the synth, but now I really want to know what's going on Very Happy
PostPosted: Sun Apr 29, 2007 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, here's the first pic. 20 screws, the back comes off and you can see the main board. On mine you can see the expansion board roughly in the middle with the orange backup battery holder. There are 15 connectors of different sizes which need to be removed. Putting them back in the right place is very easy.
 Filesize:  220.96 KB
 Viewed:  15836 Time(s)
PostPosted: Sun Apr 29, 2007 2:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Next pic,
with the keyboard removed. There are two screws on either end and 4 across the back of the keyboard assembly. You also need to cut 6 cable ties. I always use those plastic compartment boxes so my sets of screws go back in the right place. You can also see some of the other tools I used. Here I've already taken out three keys. Note the precision foot in the bottom left. It's used for standing on things. Smile
 Filesize:  188.63 KB
 Viewed:  15696 Time(s)
PostPosted: Sun Apr 29, 2007 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Pic three!
Here's a closeup of one of the rubber switch membranes. It has two contacts, which are at different heights. The time between them closing gives the velocity value. So make sure they go back the right way. Little 'u' shaped cutout to the front.
You can also see the clear plastic strip which I decided to remove completely. It makes getting the keys out heaps easier.
 Filesize:  129.32 KB
 Viewed:  15687 Time(s)
PostPosted: Sun Apr 29, 2007 2:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Number four,
whew!
Now we have a nice little collection of springs. I don't need to tell you how frustrating it would be to lose one. Shocked
 Filesize:  189.09 KB
 Viewed:  15637 Time(s)
PostPosted: Sun Apr 29, 2007 2:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Next!
The amount of crap which builds up over twenty years is amazing.
 Filesize:  134.81 KB
 Viewed:  15630 Time(s)
PostPosted: Sun Apr 29, 2007 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
And the 'after' shot,
This is after I cleaned all the dust and crap off, but the cleaning of the rubber membranes is still to be done. You can actually clean these by putting them in a sink of warm soapy water if you like. Rinse well, and dry thoroughly. I scrubbed mine with electronic cleaning solvent instead. The aftertouch strip is under that felt strip at the top of the picture. I haven't found any way of adjusting it's sensitivity yet.
 Filesize:  114.9 KB
 Viewed:  15616 Time(s)
PostPosted: Sun Apr 29, 2007 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Last one,
this one is specially for Jan. It's a hi-res close up of the expansion board. The only connections to the main board are the original locations of the UV-EPROM pins. (On the board, pin 20 is hung out wider so it's connection changes.) And the red wire, which connects to a different chip on the main board.
 Filesize:  736.81 KB
 Viewed:  15626 Time(s)
PostPosted: Sun Apr 29, 2007 4:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, I've just checked under the main board again, and there are no cut traces. The red wire connects to pin 27 of a HM62256LP-12 which is under the expansion board. I checked both backup batteries, and they both have 3V+. I also put back another two cable ties. I closed it all up, plugged the headphones in and had a good little tinkle.
I must say that the action of the keys both feels and sounds cleaner and more responsive. Seeing as how I didn't actually have any dead keys, like Gothboy has, I'd say that makes it a very worthwhile bit of maintenance to do. All you need is a D50, a few tools, a steady hand, 3 hours and an ESD wrist-strap. Wink
Audio files: 218
G2 patch files: 319
PostPosted: Sun Apr 29, 2007 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting Very Happy
You mean the EPROM pins go straight through to the original socket that is directly under it ? (except for the bent out pin 20 ( ! CE I guess, for a 27c512 EPROM ... not too readable but would make sense)).
The red wire seems to go to the reset circuit (around the 7705) ? I had expected a high addres line would be brought in to select between the EPROM and the RAM.
A pitty the ID's were filed off of the dils just above O.K.
What is the empty DIL 28 socket supposed to hold ?
PostPosted: Sun Apr 29, 2007 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, very interesting.
Yep, straight through except for pin 20.
Yeah, and the other end of the red wire on pin 27 of what I've worked out is a static RAM chip.
Yeah, what's the point in hiding the chips you use? I hate that.
And the empty 28 pin socket. I was hoping you were going to tell me about that one! ? Laughing
Oh well, maybe someone will give us both some enlightenment now that this thread is here.
Audio files: 218
G2 patch files: 319
PostPosted: Sun Apr 29, 2007 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, and when putting the EPROM back into its original socket you did bend pin 20 back into place ?
