 Forum index » Instruments and Equipment » MAX/MSP - Pd
Median impossible between 0 and 1
Page 1 of 1 [7 Posts]
badiou
PostPosted: Fri Apr 27, 2007 1:20 pm    Post subject: Median impossible between 0 and 1 Reply with quote  Mark this post and the followings unread
Hello,
I try to use a median patch as sort to calculate a median for 7th last values entered.
My problem is that under 1 and between 0 and 1, all decimal values are not taken (my patch is linked here)...
It's really obstructing because datas I need to send are decimals...
Anyone has an idea ?
moyenneur.pat
 Filename:  moyenneur.pat
 Filesize:  1.12 KB
 Downloaded:  174 Time(s)
EdisonRex
Audio files: 171
PostPosted: Sun Apr 29, 2007 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
At the bottom, you have two integer operations. One divides by integer 7, and below that you multiply by integer 100.
When I change those values to floating point operations
[/7.]
[* 100.]
I get floating point numbers in the bottom results.
Remember that if you are looking for fractions you cannot do any integer math in the calculations.
Garret: It's so retro.
badiou
PostPosted: Mon Apr 30, 2007 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks !
I understand now... It was so evident...
EdisonRex
Audio files: 171
PostPosted: Mon Apr 30, 2007 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
badiou wrote:
Many thanks !
One of the problems with Max, which all programming languages share, is that one frequently misses the simplest of bugs. They are always simple when you see them. They aren't so simple when you are looking for them.
Have fun. I'd like to see what you do with the construction.
sohcahtoa
PostPosted: Mon Apr 30, 2007 9:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
After about 8 hours trying to figure out why my program was not sending binary data, I can concur with the above statement. My program was interpreting what I thought was binary as decimal, because I never told the program it was binary data.....ahhhhh Shocked , feels good to get it fixed though
badiou
PostPosted: Tue May 01, 2007 6:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure, We'll keep in touch !
badiou
PostPosted: Tue May 01, 2007 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi edison rex,
here's the continuation , a little more complex :
http://electro-music.com/forum/topic-17826.html
