  bingsatellites Mostly Ambient
Controlling Chaos for evolving patterns
Page 2 of 3 [51 Posts]
iPassenger
G2 patch files: 78
PostPosted: Thu May 03, 2007 11:52 am    Post subject:  3 demo compositions built on the no sequencer concept Reply with quote  Mark this post and the followings unread
All purely G2 with no external or internal sequencer (with the exception of the kick drums, which are being event triggered)
Big thanks to Jan for getting me rolling on this concept, if you wanna hear what I have come up with follow the links:
http://www.fileden.com/files/2006/6/15/69966/Boodle%20Noodle.mp3
http://www.fileden.com/files/2006/6/15/69966/Standard%20Wonk.mp3
http://www.fileden.com/files/2006/6/15/69966/Sub-Due.mp3
Ross.
iP (Ross)
Audio files: 116
G2 patch files: 317
PostPosted: Thu May 03, 2007 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's some nice patterns you got ! And some nice sounds are used as well.
Audio files: 107
PostPosted: Fri May 04, 2007 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, nice tracks. Very Happy
iPassenger
G2 patch files: 78
PostPosted: Sun May 06, 2007 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your comments, glad u like em.
Seriously tho, I have never in my life written as much music as I do now I have my G2. Wish i bought one years ago.
iP (Ross)
lcvl
PostPosted: Tue May 15, 2007 3:13 am    Post subject: Controlling chaos
Subject description: The Random Trig approach
Hi everybody!
My first post to the electro-music.com forum. Very Happy
I'm a long time NM user, just got a G2 Engine for an incredibly low price and I'm really amazed by the number of improvements Clavia introduced with the new model.
Regarding this specific topic, I was wondering if anyone has used the following approach. It's very simple and quite un-sophisticated but I seem to get pretty good musical results out of it.
(I'm not in the studio right now, so I patched it from memory. It should work, but you never know...)
Basically I'm using the Random Trig module to create random rhythms/triggers for my sound sources (in this patch case a simple Osc Perc, playing against a steady kick drum simply used as a rhythm reference).
As expected the Prob knob controls the complexity of the pattern/number of triggers, and the lenght of the pattern is determined by the "Sync Every x" value in the Clock Generator.
Now the more interesting part: a constant value lets you decide the starting index point in the random triggers sequence of the Random Trig module so the musical result sounds a bit like repeating programmed patterns, instead of just a sequence of random values.
Any change to the constant value (pattern "number") gets triggered only at Rst points: I think that kind of regularity helps as well, musically.
This should already work pretty well by itself but I wanted to add some variation in the form of a really slow, unipolar, ascending LFO (reset at every Rst point, so it creates an always repeatable curve) that slowly increases the Prob value (through its modulation input) as the pattern is getting toward its end.
In musical terms that should create the effect of a "fill": the pattern gets busier toward the end of the pattern. You probably need to tweak the values a bit for the most convincing effect, mostly the balance between Prob, its modulation attenuator and the phase of the LFO (so its initial value after every Rst is not too high).
As I alreayd said, I'm totally new to the G2 so I'm completely open to suggestions about how to improve this method.
thanks
leo
Random Rhyhtms LCVL.pch2
 Filename:  Random Rhyhtms LCVL.pch2
 Filesize:  1.7 KB
 Downloaded:  603 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Tue May 15, 2007 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome leo, will check your patch later when I get home, but reading you I get the idea that this a very usable strategy for patterns on the edge of order and chaos - and that's where the interesting stuff happens Very Happy
lcvl
PostPosted: Tue May 15, 2007 10:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Jan!
iPassenger
G2 patch files: 78
PostPosted: Fri May 18, 2007 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice patch.
One thing i don't get and not specific to yr patch, is what the Seed input actually does. N i have read the manual several times.
Anyone can explain in explain english?
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Fri May 18, 2007 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scrub that i have just worked it out.
Blimey i am thick sometimes!
R.
iP (Ross)
lcvl
PostPosted: Fri May 18, 2007 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi
Thanks for the nice words.
Most of the time digitally calculated randomness is not really a random thing.
In the case of the G2 it's more like a reaaaaly long string of values that simply sound/look random to us.
The Seed input allows you to point to a different starting point on that sequence/string.
Resetting the sequence of triggers every x bars makes sure that the random sequence keeps repeating itself, ending up sounding like a programmed pattern.
Sorry for the quick and poor explanation but I'm cooking dinner!!!! Smile
iPassenger
G2 patch files: 78
PostPosted: Fri May 18, 2007 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers dude.
iP (Ross)
mother misty
G2 patch files: 130
PostPosted: Wed May 23, 2007 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
All good patches and all demonstrating their purpose, and all good in their way, but still all those damned sequencers, get rid of 'm Laughing
I love that drummies patch, great sound!
Add some drums and you have a banging jeff mills tune! Smile
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Wed May 23, 2007 6:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
lcvl wrote:
hi
I am now listening closely to this thread.
No, a good description is what I needed, thanks. Makes total sense.
I want to be more random. And this patch is cool for what I like to do (sequencing). It's a random pattern based envelope the way I look at it -- not a string of values
I am going to meet Jan Punter in person this summer, I look forward to some great discussions and demos.
/Dasz
ps.: a few minutes earlier I finished this g2 performance witch a snappy patch called DutchClock_DZ -- love those snappy g2 envelopes.
http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/
Audio files: 116
G2 patch files: 317
PostPosted: Thu May 24, 2007 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bluf Laughing
Erm, I meant to say of course that I'd love to hear what you meant exactly Very Happy
(probably not like attached, which adds a bovine sequencer rather)
07-029-004.prf2
herbivore sequencers
 Filename:  07-029-004.prf2
 Filesize:  10.54 KB
 Downloaded:  788 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Thu May 24, 2007 6:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
dasz wrote:
DutchClock_DZ
Shocked do you have an example for that ?
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri May 25, 2007 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
dasz wrote:
DutchClock_DZ
as a matter of fact, my friend, I do.
http://electro-music.com/forum/post-121909.html#121909
To you, I think the 3rd time (wow, even more than for Rob H.).
Hope you can help me to add some more motion to this kind of stuff. See ya!
/Dasz
iPassenger
G2 patch files: 78
PostPosted: Mon Jun 04, 2007 10:01 am    Post subject:   Reply with quote  Mark this post and the followings unread
In relation to this just added this strange noodle machine:
http://electro-music.com/forum/post-123175.html#123175
Cheers to Rob and his wonderful guide for getting me thinking on how to do this one.
R.
iP (Ross)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Jun 08, 2007 9:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys,
I have been traveling on Vacation A this week - traveling from Vancouver Canada to Yellowstone park, and then to Oregon coast.
And I have had some time to patch while at 120km/h on the road in the motor home (no, I was not the one driving it, at the same time).
I have decided to try more random stuff (explore more modules), as I have been mainly focusing on sequencer/groove stuff in my explorations, as you may know ...
so here is a patch (on the G2 demo, make sure to run it slow at 84BPM) which I created while crossing from Idaho through Oregon sate (heading towards the beautiful Oregon coast). Bear with me, I am just beginning to use the rnd modules, and have not established a solid set of tricks yet.
So what I am exploring is not to throw the sequencer away, but rather use it to control the random modules and selecting how often the notes get played (thus the 1,2,3,4 clock dividers being selected with a random modulated mux).
Now, this patch does not evolve, and this, I gather involves thinking at even higher levels of abstraction (I'm thinking of slow moving LFO's or sequencers which control randomness, or envelopes which slowly open up and close certain parts.)
Any suggestions are very welcome. Any thoughts on the patch as well.
/Dasz
ps.: Vacation B is the European Modular Event!!!
RNDOregonHill3_DZ.pch2
 Filename:  RNDOregonHill3_DZ.pch2
 Filesize:  4.16 KB
 Downloaded:  585 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Jun 10, 2007 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
holy cow, I must admit I've been bad. I didn't really read all the posts in detail in this topic nor check out any of the patches prior to my patch experiment. I guess I tend to get the gist of what is being attempted and then I go with it.
And coincidentally the ideas I was trying are along the lines of what other tried. We are all so similar... us Nordists... except for Jan ...
I am learning...
/Dasz
Audio files: 116
G2 patch files: 317
PostPosted: Mon Jun 11, 2007 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
dasz wrote:
except for Jan ...
Rolling Eyes Laughing
Nice patch, but erm I ran it at 24 BPM, with two voices, american high ways are sloow with many lanes Cool
Audio files: 116
G2 patch files: 317
PostPosted: Mon Jun 11, 2007 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Correction, 6 BPM Shocked
With an FM clarinet along that's doing a solo dance, and some more stuff I borrowed around.
edit: added mp3, playing are patches by Dasz (rndoregonhill3), Antimon (sbt_plant_nation), Tim (fm_klarinet_tk) and me (Initpatch1). All patches modified a bit to go together better.
slow.mp3
some patches I borrowed around thrown together
 Filename:  slow.mp3
 Filesize:  1.69 MB
 Downloaded:  573 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Mon Jun 11, 2007 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
People in the Chuck corner of this forum are working on interesting random as well : http://electro-music.com/forum/post-124121.html
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Jun 11, 2007 6:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
dasz wrote:
except for Jan ...
that was a compliment, I hope that is how you took it. Your grasp of noodles sets you apart.
/Dasz
Audio files: 116
G2 patch files: 317
PostPosted: Tue Jun 12, 2007 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Dasz I know you meant it that way, but it felt a bit lonely as well.
Audio files: 218
G2 patch files: 93
PostPosted: Tue Jun 12, 2007 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fiddled around some with cross modulated lfos. Cross modulated oscillators usually gives chaotic but nice results. It has 8 variations, and the rythm will often (but not always!) be different when you revisit a variation. Change phase modulation amp and phases for new rythms.
/Stefan
sbt_crosslfos.pch2
 Filename:  sbt_crosslfos.pch2
 Filesize:  2.75 KB
 Downloaded:  658 Time(s)
JuneSolstice2013
