thermionicjunky
Joined: Dec 07, 2006 Posts: 65 Location: san francisco
Posted: Sat Apr 21, 2007 2:07 pm Post subject:
| P.S. , you could also obtain the vector fade function with Doepfer , using the voltage controlled mixer , joystick and dual inverter. The most expensive thing about them is the rack , but now they will be offering mini cases. The modules above occupy more space than one moni case , but you could fill out two cases by adding some Plan B or Livewire modules. |
erich
EdisonRex
Joined: Mar 07, 2007 Posts: 4448 Location: London, UK
Audio files: 168
Posted: Sun May 06, 2007 2:06 pm Post subject:
this happens when you connect the Moog to the Wretch, but not any other time? It's a pretty high pitched (and yes, very obnoxious) component, but I'm trying to reproduce it here with my equipment so I need as much detail as I can get. Normally my Wretch and my Voyager cooperate.
Do you have a favorite patch you use on the Voyager? Just curious. _________________ Garret: It's so retro.
erich
Posted: Sun May 06, 2007 3:52 pm Post subject:
Unfortunatly, I hear this out of ALL metasonix products when I use CV from the vx351 or cp251.
Minor Glider is probably my favorite preset on the voyager. Love the lower register sounds. I'm figuring out how to make lead sounds I like, I really don't like traditional moog leads at all. |
EdisonRex
Audio files: 168
Posted: Sun May 06, 2007 4:05 pm Post subject:
| erich wrote: | Unfortunatly, I hear this out of ALL metasonix products when I use CV from the vx351 or cp251.
well, we are still learning then. By the way, I am pretty tired of old Moog patches too, but that's besides the point. Hit that manual button, set those knobs free.
Is it that all the Metasonix boxes reproduce that tone, or does anything else?Do all the metasonix modules only reproduce it? Nothing else?
The details are really helpful. Saving a trip to your house (which for me is a long and expensive one) is only part of this now.
I am so curious especially after hearing the sound. It sounds like an open sound source. I am sure it isn't. But that is what it sounds like. _________________ Garret: It's so retro.
erich
Posted: Sun May 06, 2007 6:42 pm Post subject:
| It is everyone of my metasonix modules and the Wretch. But this is all I have that use cv signals. Just the voyager and all the metasonix stuff. So I don't know whether using the vx351 and cp251 with other modules would be the same. I have a cyndustries module, but haven't sprung for the power supply. Metasonix has made me poor. I have a ton of it. If I want to use the voyager to control ANY cv in ANY of my metasonix stuff, I have to deal with that noise. I didn't think about it before, but I guess it could be the moog stuff. I don't know. I hope that sound isn't going to be there with every module. I really can't use any of this expensive ass gear in recordings if that is there. I don't know what other details to give you, please ask specific questions if need be, I don't know what else to say at this point. Thanks again so much for the help. |
thermionicjunky
Posted: Mon May 07, 2007 9:14 am Post subject:
| I suspect that it's the Moog gear. Try patching a cv out from the Moog into your sound system. If that sound is there , that's your answer. I had a much lower frequency coming out of Frostwave MIDI converter. The designer was just as stumped as I was. This solid state gear is typically much more complicated than tube circuits. Much can go wrong. |
erich
Posted: Mon May 07, 2007 11:47 am Post subject:
| After all this, you are right. It's the damn moog gear. I was right though, thousands of posts ago, when I said I was screwed. I got the moog stuff on ebay and just used it with the voyager which this isn't a problem with. I have a zeroscillator and a couple cyndustries modules coming, and I thought I had a way to control them, which I guess I don't, that tone ruins recordings. Moog wont help me I'm guessing, since I bought it on ebay, I already gave the guy on ebay his good feedback since it worked fine for what I tried it wth when I first bought the two pieces. Any suggestions? I was thinking of getting a midi to cv converter, but I liked combining the moog and the other gear. This is quite a blow, it takes away ALOT of my options as far as using this stuff. Thanks again. |
EdisonRex
Audio files: 168
Posted: Mon May 07, 2007 12:53 pm Post subject:
| erich wrote: | | After all this, you are right. It's the damn moog gear. I was right though, thousands of posts ago, when I said I was screwed. I got the moog stuff on ebay and just used it with the voyager which this isn't a problem with. I have a zeroscillator and a couple cyndustries modules coming, and I thought I had a way to control them, which I guess I don't, that tone ruins recordings. Moog wont help me I'm guessing, since I bought it on ebay, I already gave the guy on ebay his good feedback since it worked fine for what I tried it wth when I first bought the two pieces. Any suggestions? I was thinking of getting a midi to cv converter, but I liked combining the moog and the other gear. This is quite a blow, it takes away ALOT of my options as far as using this stuff. Thanks again. |
Send an email to moog. I had really good dealings with Heidi Bucher, the office manager. They are very good and caring people, it's a very good company. If you explain the situation, perhaps they can help you. I bought the Voyager V3 upgrade as a field replacement, they checked back to make sure I was OK and everything. Really nice folks. I was really impressed with them. _________________ Garret: It's so retro.
erich
Posted: Mon May 07, 2007 7:56 pm Post subject:
I'll talk to them. That is good to hear.
Thanks again |
mee3d
Posted: Wed May 09, 2007 12:08 pm Post subject:
Just received my TM-3 and TM-5 today and had some problems setting up the TM-3 (pitch tracking) which I worked out thanks to some pointers in this thread and noticed the thread about a high pitched whine.
I had this with the 351/251 combo and discovered that if you have these racked using the power link cable that moog supplies you often get a whine becuase of a shielding problem between the two units. Not sure if this is your problem but unplug everything from the 251/351 and see if the whines there... then switch off the Voyager and unplug the 25 pin D connector connecting the 251/351 and switch back on the Voyager - if the whine has gone you need to power up the 251 seperatly as well (just plug in the PSU that came with it) and that should fix the problem.
Naturally it could be something completely different but I thought I would share.
Got my TM-3 running through my Voyager just fine... sounds very vintage.
Mal |
EdisonRex
Audio files: 168
Posted: Wed May 09, 2007 1:06 pm Post subject:
There's a power link cable for the 251? Huh. Well that makes sense why I can't reproduce the problem. I run the 251 off it's own supply, there is no electrical common between the Voyager and the 251. But I don't have TM modules, just the S-1000, so I was getting pretty sure it was a TM gain thing, but there you have it.
Very good comment, very helpful, thanks (even if it isn't my problem, I've been feeling bad for erich). _________________ Garret: It's so retro.
mee3d
Posted: Wed May 09, 2007 2:18 pm Post subject:
If you have both the 251 and 351 you can either power them both via the Voyager by using the supplied power link cable that comes with the rack accessory (this routes the power from the Voyagers D cable through the 351 and into the 251) or you can power each unit seperatly with individual PSUs...
The common thing to do is to just use the power from the Voyager but this causes the sound - like a very high pitched whistle. I think it's documented on the moog forum as I was the first to come accross it back in 2003! |
EdisonRex
Audio files: 168
Posted: Wed May 09, 2007 3:12 pm Post subject:
Well, you would probably recognise the sound which I could only suspect was coming from the Moog.
Very glad to know this is a known problem. I'll be even more happy to hear from erich that this is his setup.
By the way, welcome to the forums here. _________________ Garret: It's so retro.
erich
Posted: Wed May 09, 2007 11:33 pm Post subject:
| That was exactly the problem. I just started using the power supply for the cp251 and that is it. No whine. I got the 251 and 351 together on ebay and just plugged in the 351 to the voyager and let the 251 get power from that. I am kind of upset that something so simple was the problem the whole time, but that is how it goes. A whole new world is in front of me with that sound gone. I'm glad it happened though because there is so much info in these posts that I'm glad to see a little bit about. This is kind of new to me. I just need a few more cyndustries modules, some modcan or synthesizers.com stuff for utility and routing and such, about 4 food pedals, and I will never see any of my friends again. I can't wait. |
mee3d
Posted: Thu May 10, 2007 2:31 am Post subject:
Great...It's always worth checking the moog forum as well as the Voyager is not without it's own issues.
Mal |
