  bingsatellites Mostly Ambient
Multistage Envelope
Page 1 of 1 [11 Posts]
FlowerP
G2 patch files: 73
PostPosted: Sun May 13, 2007 12:41 pm    Post subject:  Multistage Envelope
Subject description: An expensive approach...
In the General Discussion thread about a new G2 OS version, I wished for a generic chainable envelope module. Dasz suggested the AD/R module could be used and PM:d me an example. Here is another version of a DIY multistage envelope. The "pre-sustain" stages (Attack-Decay) can be chained in any number (within the limits of patch load and memory). The "post-sustain" stages (Release) can also be chained.
Each stage consists of a simple ASR envelope controlling a crossfade module. When the envelope reaches +1 the next stage is triggered. The crossfader fades between the level from the previous stage and the current stage level.
This patch is of course quite absurd. Its patch load is reasonable, but the memory load is 31 % for just a 6-stage envelope! Not very usable in real life!
DIY MultistageEnv.pch2
 Filename:  DIY MultistageEnv.pch2
 Filesize:  2.79 KB
 Downloaded:  629 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun May 13, 2007 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
The thing I haven't patched would look like this (in series)
1. Level 1 - knob - start level - added to 3. to set output level
2. AD/R (attack stage) - invert it if Level 1 > level 2
3. multipler - modulated by Level 2 - Level1 Depth
4. multiplexer which selects this stage
5. Level 2
Repeat 1..4 for addtional stages. Yes, hard to patch and does take power to accomplish. I suppose you wouldn't need an AD/R Module but a Decay module (since we are inverting each ramp based on which direction it needs to go). Still a lot of hassle.
I did ask for gate out for all env's a long time ago. Especially on the multienv envelope which would be ideal for this ...
/Dasz
http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/
davep
Audio files: 10
G2 patch files: 73
PostPosted: Mon May 14, 2007 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Guys,
Here's an idea for an eight stage envelope. It uses a X-FADE MUX module to sweep through eight DC levels supplied by a set of contant modules. The ADSR below the MUX controls the rate at which it sweeps through the levels, and it also controls which position gets used as the SUSTAIN portion (setting the ADSR sustain level lower causes the mux to sweep through more of the steps and stop on a later step during the sustain).
Of course this one has a few major limitations. Most notably that you don't have individual controls for the individual ramp times, only their levels. I would also like to see a true multistage EG with at least eight steps, with time & level controls for each segment.
A few other ideas - sweep a control sequencer with an EG and send the output through a lag module or lowpass filter to smooth it. You could then modulate this lag or filter module with a SECOND EG or sequencer to vary the smoothness/sudden jumps between steps.
MUX as 8stage EG.pch2
 Filename:  MUX as 8stage EG.pch2
 Filesize:  1.49 KB
 Downloaded:  616 Time(s)
Dave Peck
Audio files: 116
G2 patch files: 317
PostPosted: Mon May 14, 2007 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Made a sketch based on Dave's idea, it would need some additional logic to make it a real EG. It seems not too expensive for 16 stages, so maybe it has some potential.
e-m-s-e.pch2
experimental-multi-stage-envelope
 Filename:  e-m-s-e.pch2
 Filesize:  1.69 KB
 Downloaded:  801 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Mon May 14, 2007 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another idea:
What about using an LFO to control the steps on the control seq, that way you can have the envelope tempo locked. My lack of logic skills mean i can't work out how to disengage the lfo after one loop but i presume it can be done. (trying now)?
R.
Worked it out:
EDIT: Oh sorry Jan, i see you had already done that. Doh!
LFO 16 ENV.pch2
 Filename:  LFO 16 ENV.pch2
 Filesize:  1.73 KB
 Downloaded:  687 Time(s)
iP (Ross)
Audio files: 116
G2 patch files: 317
PostPosted: Mon May 14, 2007 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah well it needs some work still Very Happy
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon May 14, 2007 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
that's funny, I just added the value switch to my patch for gating the patch with a midi note (stereo pair, thus the need to double the toggle button functionality without needing to toggle 2 buttons). A handy module indeed.
/Dasz
FlowerP
G2 patch files: 73
PostPosted: Wed May 16, 2007 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a slightly revised version of my MultistageEnvelope. Using an inverted keyboard gate signal as trigger for the release stages caused those stages to activate immediately on loading the patch. By adding a RS-flip-flop and gating the keyboard gate signal, the envelope release stage can not be triggered before the first keypress.
DIY MultistageEnv2.pch2
 Filename:  DIY MultistageEnv2.pch2
 Filesize:  2.85 KB
 Downloaded:  578 Time(s)
FlowerP
G2 patch files: 73
PostPosted: Wed May 16, 2007 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Some rapid changes are taking place with this patch. This is yet another revision. A few redundant modules have been deleted. Now the memory load is down to 28 % for this 6-stage envelope.
DIY MultistageEnv3.pch2
 Filename:  DIY MultistageEnv3.pch2
 Filesize:  2.72 KB
 Downloaded:  608 Time(s)
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Thu May 24, 2007 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Régardez ici Smile
http://electro-music.com/forum/post-121585.html#121585
beer
Audio files: 116
G2 patch files: 317
PostPosted: Fri May 25, 2007 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
and here : http://electro-music.com/forum/post-121884.html
AmbiphonicDSP
