larns
Posted: Sat May 12, 2007 11:13 am Post subject:
setting up supernova in sequencer (logic) |
my friend has lent me a novation supernova, i have used it with my midi controller fine so i know it works. but when i try to set it up to sequence in logic, i get no sound.
i'm not used to hardware synths, so i know i'm missing something basic here, i have tried everything i can, i have set the novation to midi 1 and this is the same on instrument 1 on the sequencer. i have connected the supernova's midi in/out to my interface out/in and i have the supernova's main 1&2 output going into my interface and obviously i am outputing to my monitors.
my question is, how do i tell logic about the supernova? thanks |
Joined: Apr 03, 2004 Posts: 24075 Location: The Netherlands, Enschede
Audio files: 277
Posted: Sat May 12, 2007 12:09 pm Post subject:
Is the problem in the synth not acting on the MIDI data or is it the sound that does not get routed through the computer ? _________________ Jan
larns
Posted: Sat May 12, 2007 12:13 pm Post subject:
i dont think the sound gets to the computer, on the transport bar, it says no in / no out. so there is no midi data, when i hit a key in the matrix editor nothing happens, its like there is no communication at all |
Audio files: 277
Posted: Sat May 12, 2007 12:30 pm Post subject:
does the synth have an LED or something to show if it's receiving MIDI ? Might be something to look up in the manual. _________________ Jan
larns
Posted: Sat May 12, 2007 1:07 pm Post subject:
no im not sure, i will read the manual again and see if i can figure this out. thanks |
Audio files: 277
Posted: Sat May 12, 2007 1:21 pm Post subject:
I just found a remark in the manual suggesting that the part light should flash when MIDI comes in :
Quote: | The Part is Muted / No response at all - If the Part light flashes steadily, even with no MIDI input, the Part is Muted.
The Part is Muted / No response at all - Does the Part light flash when MIDI is sent? - Yes - The Assigned outputs may be different to the ones connected, check the setting of the Outputs menu for the offending Part. |
larns
Posted: Sat May 12, 2007 1:42 pm Post subject:
thanks, il have a look now, i appreceite that |
larns
Posted: Sat May 12, 2007 2:02 pm Post subject:
the light is not flashing, i have no idea what to try next |
Audio files: 277
Posted: Sat May 12, 2007 2:08 pm Post subject:
Probably it's something in the logic setup then, I don't know that software though, so I hope someone else will step in.
The manual thing was no problem, I'm editing and warping some music in a wave editor, so I have "natural breaks" _________________ Jan
Audio files: 277
Posted: Sat May 12, 2007 2:09 pm Post subject:
It could also be a defect cablle of course, can you try another ? _________________ Jan
seraph
Editor
Audio files: 33
Posted: Sat May 12, 2007 3:19 pm Post subject:
Re: setting up supernova in sequencer (logic) |
larns wrote: |
the supernova is a rack module, right? or the keyboard version? _________________ homepage - blog - forum - youtube
Quote: | Don't die with your music still in you - Wayne Dyer |
larns
Posted: Sun May 13, 2007 6:12 am Post subject:
its the rack version |
seraph
Editor
Audio files: 33
Posted: Sun May 13, 2007 10:05 am Post subject:
larns wrote: | its the rack version |
OK, so, play something from your master keyboard. do you see midi coming in to Logic?
if yes, create a midi track on the environment, open it on the arrange window, select the midi port to which your supernova is connected. does midi signal goes thru the synth?
if no (to the 1st question), check the physical input (on the environment) to make sure it is connected to the sequencer input.
let me know _________________ homepage - blog - forum - youtube
larns
Posted: Sun May 13, 2007 12:07 pm Post subject:
I have got it to work now, for some reason there is no signal coming form the main output, its coming from an aux output, i dont know why. also i had to make a GM midi track and have it on all midi channels, thanks for the help |
larns
Posted: Tue May 15, 2007 10:24 am Post subject:
hi, im back again with another question. seraph you are right about creating a midi instrument in the environment window. the thing is the supernova is set to global on every instrument preset, so for it to work i have to change it to midi 1 every time. this is a real pain. i have set the midi instrument as all ports/ all channels. but the supernova will not accept that data in global mode, i have to keep changing it to midi 1. any ideas? |
seraph
Editor
Audio files: 33
Posted: Tue May 15, 2007 12:35 pm Post subject:
try creating a multi instrument in the environment
and select/activate only the midi channels you are going to use (leave the supernova as it is) and see if it works for you. _________________ homepage - blog - forum - youtube
larns
Posted: Wed May 16, 2007 4:33 am Post subject:
I tried that, but if the instrument preset is on global i still get nothing. in the supernova, if i cycle through the options for midi, i get channels 1 to16 omni and global. every intrument is set to global by default. it works when set to omni or if i select a midi channel and select the same channel in logic. so i have to either setup logic so it can talk to the supernova in global mode, or change teh supernova so that every instrument is set to omni.
i appreciate your help here,
larn |
seraph
Editor
Audio files: 33
Posted: Wed May 16, 2007 5:07 am Post subject:
usually polyphonic synths have 2 operation modes: one of them is a multitimbral one called multi, performance, whatever.
There must be a way to set the supernova this way in order to play more than one instrument, each one of them independently from the other ones, on different midi channels. _________________ homepage - blog - forum - youtube
