Rob
Joined: Mar 29, 2004 Posts: 578 Location: The Hague/Netherlands/EC
G2 patch files: 109
Posted: Thu Apr 29, 2004 3:37 pm Post subject:
The Muse pattern generator |
Here is an emulation of The Muse, a pattern generator from way back. I used the schematic that is in Hal Chamberlin's book.
On the original there are some binary counters and a 31 stage bit shift register. Then there are four long sliders that select one of the outputs each and together form a four bit binary code. From this code a parity bit is generated which is fed back into the input of the shift register. Using parity has one drawback, when all four sliders take input from the shift register and having them all to the same output of the array will quickly force all states to all zeros. So, that should be in general avoided, unless one wants one single note that lasts forever.
In the G2 implementation four clocked delay lines are used that each shift one of the four bits. This way each bit slider can be made with an eight way selector, seven inputs from seven outputs of the counters and the eight input from the output of a clocked delay line. Setting the length of the delayline will set the amount of shift for the particular bit.
Instead of using parity it works out very well to use the event bar on a CtrlSeq. This allows for interactive control on the feedback rule.
Anyway, the Muse is able to create continuously evolving correlated patterns that can be quite long. Especially as on the G2 the bit delay can be up to 128 clock ticks.
The counters make repititive patterns and the shifters do variate on these patterns. Thats what is to be kept in mind by playing with the patterns. The patterns can be controlled by eight knobs from one single parameter page.
So, here are two patches, the second one has a switch for either parity or the CtrlSeq for feedback. Additional use of the CtrlSeq is as a list for the possible notes to play.
The pattern generator generates sixteen values between 0 and 64, just the proper range for a CtrlSeq.
And additionally a link to a mp3 for those that do not yet have a G2 but are interested in the sound and pattern play possibilities. Its at http://www.xs4all.nl/~rhordijk/G2Pages/B-Mused.mp3
Note that when setting the patterns I didn't exactly compose, so it all has a bit a 'free' feel.
| Again The Muse, but with a lookup table for pattern feedback and notes to play. |
 Download |
| Filename: |
B-Mused lookup.pch2 |
5.32 KB |
| Downloaded: |
1205 Time(s) |
| A model of The Muse, a pattern generator from way back. |
 Download |
| Filename: |
B-Mused basic.pch2 |
4.88 KB |
| Downloaded: |
1186 Time(s) |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Thu Apr 29, 2004 8:55 pm Post subject:
Holly shit! I built a Muse way back in the 70s. Amazing. I'd forgotten completely about it. Of course the origial didn't sound as good, but this really is a great memory jogger.
Thanks for posting this. It's my birthday, for 5 more minutes. This is a great present.  |
Rob
G2 patch files: 109
Posted: Fri Apr 30, 2004 1:37 am Post subject:
The Muse |
Happy birthday to you Howard
Btw, I'm looking for pictures of original Muses, anyone any links? |
Joined: Apr 03, 2004 Posts: 19583 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Fri Apr 30, 2004 2:47 am Post subject:
Re: The Muse |
| Rob wrote: | Happy birthday to you Howard :D
Happy birthday Howard !
| Quote: | | Btw, I'm looking for pictures of original Muses, anyone any links? |
http://www.synthmuseum.com/triad/trimuse01.html ?
the description looks a lot like what you wrote, the picture can be clicked to enlarge it but it's not too good a picture unfortunately. And the Paul Geffen link leads into nothing ...
Jan. |
Audio files: 107
Posted: Fri Apr 30, 2004 6:11 am Post subject:
Thanks for the B'day greets.
Now that I see this picture. I realize I didn't own one but played with one. Someone who did own one loaned it to me for a period of several months. He was a rich guy and bought it because it looked cool. I think there was a lengthy article in Popular Electrnics magazine about the Muse, complete with circuit diagrams. Anyway, Rob, this is amazing. |
Rob
G2 patch files: 109
Posted: Sun May 02, 2004 6:47 am Post subject:
I'm especially looking for a picture that shows the front in a way that it is possible to read the texts on the box. These pictures are all a bit vague. |
