disablek
Joined: May 11, 2007 Posts: 10 Location: disablekville
Posted: Tue May 22, 2007 12:55 am Post subject:
Problems with miniAudicle, Chuck & Jack |
I've compiled miniaudicle with jack enabled, and i get this message while trying to run a chuck script.
[fm.ck]:line(4): ugen's of type 'DAC' have no input - cannot => from another ugen...
Is there any reason i'm getting this? Also I've tried miniaudicle alsa, and it occasionally displays a rtpapialsa callback error or just hangs on adding a shred. Incidentally is there any reason why the commandline switch bufnum isn't ever passed to the chuck vm? I've found that using chuck on the commandline, i needed to specify the number of buffers to be 4 for it to work, which doesn't work in miniaudicle.
There's a possibility that it's my sound drivers that are a problem. I'm running ubuntu studio 7.04 on an alc888 on board sound.
Edit: Just in case someone reads this in the future, miniAudicle version is 0.1.3.7 (alpha) which comes with chuck 1.2.0.8 (dracula) |
disablek
Posted: Tue May 22, 2007 1:00 am Post subject:
Looks like the oss version works though. |
kijjaz
Joined: Sep 20, 2004 Posts: 765 Location: bangkok, thailand
Posted: Tue May 22, 2007 3:37 am Post subject:
i was using chuck and miniAudicle in debian/ubuntu linux on some older laptop computers also.
and had the same problem.
so i had to use OSS then.
the way to solve problem might be around ALSA and the soundcard.
(i'm still very confused with alsa and incoporating soundcards and audio interface -_-) |
disablek
Posted: Tue May 22, 2007 4:11 am Post subject:
Somehow i think it's just a question of configuration of the soundcard. The only problem is how to do it, so that sucks |
kijjaz
Posted: Tue May 22, 2007 8:48 am Post subject:
is "sudo alsaconf" and using "asoundconf" works for you?
(for choosing a default card & and preparing a driver for it) |
disablek
Posted: Tue May 22, 2007 10:01 am Post subject:
I'll try that some other day, i'm booted into windows at the moment, which incidentally has miniaudicle running perfectly... hahahhahahha ...... that's hysterical laughter btw.
Anyhow the last time round i checked on my other version of ubuntu, alsaconf seemed to think my soundcard was the alc883 and not the 888.
But i would really like a technical explanation for this
when using jack, since jackd seems to be running all well and good. |
kijjaz
Posted: Thu May 24, 2007 11:34 am Post subject:
dac has no input?
for me it means jack can't find a way to output to the soundcard. hmm..
(i once got that..) |
Kassen
Posted: Thu May 24, 2007 2:42 pm Post subject:
Now I'm lost, I thought "dac" *wasn't* a Ugen and so doesn't follow the Ugen's style of capitalised naming (it's instead a class that abstracts the sound-driver, seems like subtle difference to me...).
"[fm.ck]:line(4): ugen's of type 'DAC' have no input - cannot => from another ugen... " is quite a strange message then.
Maybe it's time for a mail to Ge. _________________ Kassen |
kijjaz
Posted: Sat May 26, 2007 3:17 am Post subject:
It's not so strange to me.
I've got that quite a few times.
it's just when the sound system isn't set to the dac with "output"
for example.. failed initialization of ALSA..
and it happened that way also if i use 'Digital Camera' (with microphone) as DAC
(surely it doesn't have a sound output)
so it's just because the program can't connect to a right dac
or the system is not correctly configured. |
