seraph
Editor
Joined: Jun 21, 2003 Posts: 12010 Location: Firenze, Italy
Audio files: 31
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Sat Apr 24, 2004 7:19 am Post subject:
Great movie, Carlo. Thanks for pointing this out.
Carlo, you use this, don't you?
Do they give you Mac and PC software and allow you to use it on either platform? |
seraph
Editor
Audio files: 31
Posted: Sat Apr 24, 2004 8:46 am Post subject:
| mosc wrote: | | Carlo, you use this, don't you? |
I do but not as much as I would like
| mosc wrote: | | Do they give you Mac and PC software and allow you to use it on either platform? |
Live 3 is the real-time audio production solution that eliminates the
boundaries between composition, performance, recording and sound
design.
Combine loops, phrases, complete songs and audio recordings of any tempo in a single Live Set.
Experiment with sound files in the uniquely interactive and nonlinear Session View.
Capture every detail of your nonlinear experiments as a linear arrangement that can be edited to perfection in the Arrangement View.
Modify grooves and correct timing using Warp Markers.
Modulate pitch, timing, volume and effect parameters for individual notes or parts of a sound file using Clip Envelopes.
Use any of the 17 acclaimed built-in effects and have access to endless expansion via VST Plug-in support.
Gain unprecedented real-time control by assigning all mixer, transport and effects parameters to computer keys and MIDI.
Record multi-track audio at 24-bit/192kHz.
Freely experiment and try new ideas with Live's non-destructive editing and sample manipulation, including unlimited Undo/Redo.
Run Live in Mac OS 9, Mac OS X or Windows.
Seamlessly integrate Live with your favorite ReWire-compatible applications as either a ReWire master or slave. _________________ homepage - blog - forum - youtube
| Quote: | | Politics is the entertainment division of the military industrial complex - Frank Zappa |
Johan Zwart
Joined: Mar 26, 2004 Posts: 448 Location: Utrecht, Netherlands
Posted: Mon Apr 26, 2004 1:16 am Post subject:
| I wandered if it is useful in experimental non loop based, music. |
seraph
Editor
Audio files: 31
Posted: Mon Apr 26, 2004 3:46 am Post subject:
| Blanomus wrote: | | I wandered if it is useful in experimental non loop based, music. |
well..it's very a loop based application but that does not mean you can not play experimental music with it. It has a very creative approach to electronic music, especially for LIVE (as the name appropriately implies) applications.
It's a way cool piece of software  _________________ homepage - blog - forum - youtube
Audio files: 107
Posted: Mon Apr 26, 2004 5:34 am Post subject:
How does it handle midi? Can you do midi loops? Can you play loops, midi and audio, backwards?
Way cool is probably true, but not very descriptive.
And welcome to the electro-music.com forum, Blanomus. Glad to have you here.  |
seraph
Editor
Audio files: 31
Posted: Mon Apr 26, 2004 7:49 am Post subject:
| mosc wrote: | | How does it handle midi? Can you do midi loops? Can you play loops, midi and audio, backwards? |
it's not a midi sequencer, you do not record midi note events, you use midi to control audio sequences. _________________ homepage - blog - forum - youtube
Audio files: 107
Posted: Mon Apr 26, 2004 8:30 am Post subject:
Ahhh... No MIDI.
That's why you use Logic, isn't it? |
seraph
Editor
Audio files: 31
Posted: Mon Apr 26, 2004 8:41 am Post subject:
| mosc wrote: | Ahhh... No MIDI.
Midi is my middle name  _________________ homepage - blog - forum - youtube
Johan Zwart
Posted: Mon May 03, 2004 2:45 am Post subject:
| seraph wrote: | | mosc wrote: | | How does it handle midi? Can you do midi loops? Can you play loops, midi and audio, backwards? |
it's not a midi sequencer, you do not record midi note events, you use midi to control audio sequences. |
Oke thanks. I'll better stick to Cubase SX in combination with sample players or a (sw)sampler than. |
Posted: Mon May 03, 2004 3:17 am Post subject:
I got limited version of Live with my Firewire 410 interface. I just checked it out some more some days ago.. and it can be used for pretty spaced out stuff.. great for performances. This one should be very useful for experimental live music. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
seraph
Editor
Audio files: 31
Posted: Mon May 03, 2004 7:22 am Post subject:
Reason to Live
The nice people at Ableton have been kind enough to send us a pdf of their "tips and tricks" series that covers using Reason and Live together. Get it here. _________________ homepage - blog - forum - youtube
