EdisonRex
Joined: Mar 07, 2007 Posts: 4449 Location: London, UK
Audio files: 168
Posted: Sun Mar 18, 2007 12:00 pm Post subject:
A Saturday Mix Subject description: So I could use another ear or two. |
I've been busy in the studio trying to get used to some of my newer kit. So I put together another study. I've made three separate mixes, and I'd like some comments, if anybody would be kind enough to comment. I've chosen the last mix I did.
This was produced using:
Pad - Hartmann Neuron (modified Fatpad 2)
Bass - Moog Voyager
Bass 2 - Poly Evolver (it goes with the pad)
Arpeggiated - Studio Electronics SE1-X
"lead" - Metasonix S-1000
Percussion - Akai S-6000 with some sampled percussion
I played the arpeggios, and the drums are sequenced but not programmed either. So there's some imperfection in both. I haven't hunted it all down yet. The Wretch is very cantankerous, and will drift during a mix, so you kind of have to pay attention to it if you are trying to stay melodic. The SE1-X tends to drift a lot, but not like the S-1000.
Anyway, I tried to make it all sound kind of dark, like a rainy saturday.
 Download |
| Filename: |
153-Saturday-Mix.mp3 |
7.01 MB |
| Downloaded: |
1250 Time(s) |
_________________ Garret: It's so retro.
Home,My Studio,and another view Last edited by EdisonRex on Thu Oct 18, 2007 3:20 pm; edited 1 time in total |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Sun Mar 18, 2007 12:17 pm Post subject:
Sounds good to me. You are off to a good start.  _________________ --Howard
my music and other stuff |
EdisonRex
Audio files: 168
Dovdimus Prime
Joined: Jul 26, 2004 Posts: 664 Location: Bristol, UK
Audio files: 6
Posted: Sun May 20, 2007 1:26 pm Post subject:
First one does sound good - rainy day description is apt.
Second one is a bit daytime TV for my liking to be honest. But still way better music than I can write! _________________ This message was brought to you from Beyond The Grave. |
EdisonRex
Audio files: 168
Posted: Sun May 20, 2007 1:43 pm Post subject:
| Dovdimus Prime wrote: | First one does sound good - rainy day description is apt.
Second one is a bit daytime TV for my liking to be honest. But still way better music than I can write! |
Daytime TV?
I don't watch TV. But I think I know what you're getting at. I was more aiming for Lyle Mays than Oprah. Well that gives me something to think about for the next mix! Thanks, truly, for the comment.
Oh and thanks about the first Saturday mix. I didn't actually change the mix since then. I had a lot of positive responses. Just not as responses in this thread  _________________ Garret: It's so retro.
Audio files: 107
Posted: Mon May 21, 2007 12:31 pm Post subject:
Yes the second one sounds very professional. It could well be the theme for a daytime soap. Good job.  _________________ --Howard
seraph
Editor
Joined: Jun 21, 2003 Posts: 12010 Location: Firenze, Italy
Audio files: 31
Posted: Mon May 21, 2007 1:47 pm Post subject:
nice mood but the timing could be tighter (at least for my taste).
I think you also need a bridge to move somewhere else. you can not stay too long on that chord progression (at least for my taste). _________________ homepage - blog - forum - youtube
| Quote: | | Politics is the entertainment division of the military industrial complex - Frank Zappa |
EdisonRex
Audio files: 168
Posted: Mon May 21, 2007 2:18 pm Post subject:
| mosc wrote: | Yes the second one sounds very professional. It could well be the theme for a daytime soap. Good job.  |
Why, thank you! (why not thank you?)
I forgot to say what I used.
The piano is from, of all things, my P-55 Sound Canvas. With some close echo and reverb to make a room sound I think it sounds just fine. It's some Euro Piano patch. Patch 09 if you're wondering. I think the close room echo is about 50ms or so, and the reverb is "Large Room", but fairly dry in the mix.
Drums are a sampled set from the Akai S-6k. I am finding myself using the Procussion less and less now. I used a jazz set. It is tapped in, each part, for the length of the piece. I tend to do my drums that way, I tap in the parts. There is a set of shakers from the TS-12, I like them for their stereo goodness, for a 90s workstation there are still good sounds from that keyboard. Although it's my master keyboard anyway, these piano velocity recordings are from the keyboard of the TS-12.
The bass is a manual patch on the SE-1X. I really like this instrument, but it is pretty unstable. I think I am going to open it up and figure out why the oscillators can work their way whole semitones apart in the course of a day. It worked out okay on the mix, but I had to readjust it big time about 3 times during the session. We're on 3 oscillators for bass, lots of low saw and triangles doing the 3rd harmonic. Filter was at 24db. Heavily influenced by envelope.
The "ethereal" arpeggio is the Nord in manual mode, played with liberal Effectron, to get me the echo. I played the arpeggio myself thank you. Many times. I do not like cut and paste, I find it tends to homogenate the production.
The pad is the Neuron, one of the weirder patches, which I have modified anyway, its a evolutionary thing (it changes as you play it). I used it sparingly, because you should use all strongly odd patches sparingly. It's one of my rules.
First solo is a manual patch on the Voyager. VCO1 is in the squarer region, the other two are in the more triangular region. Dual Lowpass, chocked down but with envelope goosing it, they are all 4' voices, so we're tuned on some higher harmonics.
Second solo is the Poly Evolver. Mostly triangular and overdriven.
The Moogerfoogers got used for effects, at least the phaser did.
I think that's most of it. No quantizing, very little clam editing right now, and as I said, I need to do some dynamic editing still. Mostly that's the mixing, which I did not automate for this take.
So I had this piano riff going through my head all week at work. I sat down with my M-Audio 24/96 and did a raw capture on Thursday off the piano/Pianobar downstairs to listen to, listened Thursday and Friday, actually laid down tracks on Sunday. So the production was mostly a Sunday. We were all dragged out Sunday in the house, so it was a good time to go for it. We sieze our days.
I don't see a lot of people talking about how they do things. I thought it might be nice to share. If I'm in the wrong place, as I am good at, let me know. _________________ Garret: It's so retro.
EdisonRex
Audio files: 168
Posted: Mon May 21, 2007 2:22 pm Post subject:
| seraph wrote: | nice mood but the timing could be tighter (at least for my taste).
I think you also need a bridge to move somewhere else. you can not stay too long on that chord progression (at least for my taste). |
You missed the "bridge" at the end of the second solo? I should have taken it out of the progression
yeah I am thinking about that. And the timing has a LOT of work to do. It's what you get when you manually play something - as I said, it's a work in progress, no excuses, and you are right. Thanks for listening, actually
This one will get more work. It's hardly done. My saturday one earlier in the thread, I should work on, too, but my head is in this one. _________________ Garret: It's so retro.
Dovdimus Prime
Audio files: 6
Posted: Tue May 22, 2007 3:21 am Post subject:
| EdisonRex wrote: | | No quantizing, very little clam editing right now |
Clam editing?
Does such a thing exist? Say it ain't so!
Not the bearded variety I trust? _________________ This message was brought to you from Beyond The Grave. |
EdisonRex
Audio files: 168
Posted: Tue May 22, 2007 10:03 am Post subject:
| Dovdimus Prime wrote: | | EdisonRex wrote: | | No quantizing, very little clam editing right now |
Clam editing?
Not the bearded variety I trust? |
Perhaps an English vs. American thing... definitely not the bearded variety
A "clam" would be a bad note. like when I hit two notes instead of one. I tend to edit those out of a track when I hear them. _________________ Garret: It's so retro.
Dovdimus Prime
Audio files: 6
Posted: Wed May 23, 2007 4:23 am Post subject:
Are we not both staunch Englishmen, true to our teacakes and warm beer? _________________ This message was brought to you from Beyond The Grave. |
EdisonRex
Audio files: 168
Posted: Wed May 23, 2007 5:27 am Post subject:
| Dovdimus Prime wrote: | | Are we not both staunch Englishmen, true to our teacakes and warm beer? |
I like teacakes, and warm ale, but not warm lager.
As I said once, in my introduction, I'm an American expat, enjoying paying more taxes and NI, now 9 years here in London. So I usually just say I'm an ethnic American to those who ask. My friends all make fun of my accent. Considering I'm originally from New England, though, my accent was weird to begin with. So I also usually say I am bi-lingual, I speak both English and American. That way nobody can figure out what I'm talking about.
