  bingsatellites Mostly Ambient
How to match transistors?
Page 1 of 2 [49 Posts]
Sebo
PostPosted: Thu May 24, 2007 10:19 am    Post subject: How to match transistors? Reply with quote  Mark this post and the followings unread
Hi:
I want to know if I can match transistor using the Hfe meter of my cheap
multimeter.
If not, can anybody tell me a easy way to do it.
I need to match about 6 transistor for a transistor ladder filter, and I think
it will be useful knowledge for future projects.
Thanks.
Sebo
Sebo
My Music:
www.cosaquitosenglobo.com.ar
Audio files: 116
G2 patch files: 317
PostPosted: Thu May 24, 2007 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did try some googling on this but can't really find what characteristic trannies should be matched on for ladder filters. I'll try to write down what I think to know, that will be a bit general though Very Happy
A multimeter doing Hfe measurement will do so by applying a fixed base current and measuring the resulting collector current. Usually though matching should be checked over a wide range of signal levels. Otoh for filters this is usually considered less important than for oscillators (unless you want to build tracking oscillating filters, but then a ladder filter seems less ideal than let's say a state variable filter).
What can be said is that Hfe matching probably will be a good first order approximation for matching, in that when the Hfe-s differ wildly other parameter will not match good either.
So I guess you can get away with the Hfe measurement on your meter. But I'm not really very sure, as I don't know how important the Vbe vs Ib characteristic is for a ladder filter. to measure that relation Hfe measurement is not directly useful as I think this relation varies with the size of the base emiter junction - I read that somewhere - and that would depend on manufacturing precision ...
Well, maybe someone else has more on this.
Mooger5
PostPosted: Thu May 24, 2007 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are instructions for transistor matching on page 9-3 of the Minimoog service manual.
Funky40
G2 patch files: 5
PostPosted: Thu May 24, 2007 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have two circuits here.
One you should find at:
http://www.oldcrows.net/~patchell/matcher/matcher.html
then the other circuit is the one i built, and have matched Transistors with.
I have no link but its maybe from moog.( yeah, seems to be from moog )
Hey, i found it Cool
http://www.fantasyjackpalance.com/fjp/sound/synth/synthdata/16-minimoog/002/905-matching-transistor.gif
this on is simple.
I was able o use it Wink
Mooger5
PostPosted: Thu May 24, 2007 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the second circuit is taken from the Minimoog manual. I was going to post the page but couldn´t edit my post. Smile
Audio files: 116
G2 patch files: 317
PostPosted: Thu May 24, 2007 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah good practical info Very Happy
That's matching on Vbe vs Ic so on the Vbe vs Ib and Hfe at the same time and so basically for expo converters. Does the Moog manual say this should be used for the ladder filter as well ?
These measurements will be temperature dependent, so maybe pay attention to the notes given by Moog about that.
Mooger5
PostPosted: Thu May 24, 2007 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
"Q26 & Q28 matched at +/-3mV at 20mA" - Q26 is a PNP controlling the cutoff range and is connected to Q28, the NPN at the bottom of the ladder.
AFAIK, they started using CA3046 instead of matched transistors on the Micromoog, for economy reasons.
Audio files: 116
G2 patch files: 317
PostPosted: Thu May 24, 2007 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks !
Mooger5
PostPosted: Thu May 24, 2007 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Again I couldn´t edit my post while you were answering, but here´s the page of the Minimoog filter, togheter with VCA and the famous input overloading preamp. It runs on 10V...
 Filesize:  485.71 KB
 Viewed:  13407 Time(s)
Sebo
PostPosted: Thu May 24, 2007 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks all for the replies !!!!
I gonna try the Moog circuit, seems simple. I hope my multimeter
have enough resolution to do it.
Sebo
My Music:
frijitz
Audio files: 54
PostPosted: Thu May 24, 2007 8:57 pm    Post subject: error in matching schematic Reply with quote  Mark this post and the followings unread
this on is simple.
There is a (well-known) mistake in the second schematic. Add a 10k resistor between the transistors as in the first schematic. Smile
One other point -- if you buy a modern batch of devices they will usually all be matched to within ~2 mV, in my experience. If you get a late array such as the CA3083 matching is usually better than .2 mV.
For accurate matching for critical applications such as roll-your-own OTA's, you can use bridge-type circuits. With care, you can measure within .01 mV.
Pehr
PostPosted: Thu May 24, 2007 10:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know that there is a ery simple schematic for matching npn and pnp transistors on www.headwize.com , but I can't find it...
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
dave_b
PostPosted: Fri May 25, 2007 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps a silly question: Regarding the Moog test circuits, is it necessary to remove power when swapping transistors?
funkyfarm
PostPosted: Fri May 25, 2007 1:43 pm    Post subject: Re: error in matching schematic Reply with quote  Mark this post and the followings unread
Can you explain ?
next to "100uA" ?
I saw 10k on both...
I guess no !
but do it quickly Very Happy
Mooger5
PostPosted: Fri May 25, 2007 5:34 pm    Post subject: Re: error in matching schematic Reply with quote  Mark this post and the followings unread
Can you explain ?
next to "100uA" ?
I think it´s right there by looking at the symmetry of both circuits. In the NPN circuit the reference transistor is between 51k and 10k resistors. In the PNP the 10k is missing.
funkyfarm
PostPosted: Fri May 25, 2007 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ooops, sorry (refering to another source)
Funky40
G2 patch files: 5
PostPosted: Sat May 26, 2007 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
luckily i had to use the upper one.
Thanks for the tip.
No, good question.
I did this things without any knowledge. sometimes thats better, sometimes not Wink.
One should not touch the Transistors by Hand when matching because of heat , so i used a plier.
This tourned out as not so easy and very Timeconsuming. ( really Timeconsuming )
Once i took the Transistor on its legs, crosswise, so i did a short. To be save, i throwed it away.
Next: to allways pull down the Power would be also very Timeconsuming.( The power i use is a long Powercord for Modules, coming from my modularrack )
I did not
Fernando
PostPosted: Sat May 26, 2007 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think I'll use the James Patchell circuit when I need to (simpler), unless someone advise me to use the Moog one for any reason...
Am I right in reading that one can use the Moog matcher at +-15V without changing any resistor?
Audio files: 116
G2 patch files: 317
PostPosted: Sat May 26, 2007 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 100 uA current is determined by the voltage divider at the opamps input and the 51 k resistor going to the neg. supply. The opamps + input is set at -5V for a 10V supply, it will try to regulate it's output in such a way that the - input will also be at -5V. This means there is 5V over the 51 k resistor and that means that about 100 (98) uA will flow.
For a 15 V supply the voltage at the opamp's + input wil be -7.5V resulting in 7.5 V to be present over the 51 k resistor resulting in approx. 150 uA of current to flow. So you'll measure at another set point then.
When you want that 100 uA again the resistor should be around 75 k for a +/- 15 V supply. the current does not really depend on the positive supply voltage, but it's linear with the negative supply.
You could also replace the 10 k resistor going from the opamp + input to the negative supply with a 5V1 zener, that would make the circuit independent from the negative supply voltage as well. A 5v1 zener coincidentally also has a near zero temperature coefficient. In that case keep the 51 k resistor.
Fernando
PostPosted: Sat May 26, 2007 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot. I'll try to digest it and make further questions
frijitz
Audio files: 54
PostPosted: Sun May 27, 2007 12:48 pm    Post subject: Re: error in matching schematic Reply with quote  Mark this post and the followings unread
Yes, right. Sorry not to be clearer. If you look (literally) between the two transistors on the schematic you will see that one circuit has a 10 k resistor and the other one has just a wire. Put the additional 10k where the wire is.
Ian
LetterBeacon
PostPosted: Tue Feb 17, 2009 6:08 am    Post subject: Reply with quote  Mark this post and the followings unread
*bump*
My DMM has a DC voltage range of 200mV to 1000V and a resolution of 1mV, that is what I need for this circuit, right?
Does anyone have a stripboard layout for this circuit at all?
EDIT - Oh yes, can this circuit work on a +/- 9 volt supply?
Audio files: 27
PostPosted: Tue Aug 10, 2010 8:31 am    Post subject: Bump Reply with quote  Mark this post and the followings unread
If you've done any DIY lately you've likely discovered that it is becoming more difficult to find thru-hole matched transistor pairs. The solution is either to use SMT (and the SMT transistor pairs are almost microscopic!) or to resort to hand-matching discreet transistors.
This thread has some test circuits to allow one to match transistors. It will be useful to me and I decided to bump this thread for others to see.
emdot_ambient
PostPosted: Tue Aug 10, 2010 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, it is very useful!
My 52 year old eyes can barely see SMT components, let alone see where I'm supposed to solder them!
adambee7
PostPosted: Tue Aug 10, 2010 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built ray wilsons transistor matching circuit. Pretty good. Just pop over to music from outerspace site and the links on the homepage. Very Happy Very Happy
JuneSolstice2013
