kragg
Posted: Tue May 08, 2007 2:40 pm Post subject:
a trigger IN midi OUT gear ? Subject description: looking for some gear with midi out and trig IN |
Hi
I am looking for some hardware gear which would be equipped with midi out port and a trigger IN port.
I have several midi gear, and also some drum machines with trig out, but nothing with trig in to make it all play together.
Would you have any advice of such a thing ?
THanks ! |
seraph
Editor
Audio files: 33
kragg
Posted: Tue May 08, 2007 3:39 pm Post subject:
Hi
Thank you for your quick answer !
The purpose is mainly syncing (more than triggering), i would like to send a constant trig note that could be understood as a midi tempo signal by my daw.
Would you know if there is there any specific module dedicated to this task ?
Or could i go for the cheapest one to do that job ?
thanx |
seraph
Editor
Audio files: 33
kragg
Posted: Wed May 09, 2007 10:17 am Post subject:
I don't get it : I think i have understood what i've read, but what's the relation with the thread ?
I mean : my drum machine is PRE-midi, so it doesn't send any miodi clock message, it can only send trig OUT, so, to use it as a master tempo, i have to find a way to convert trig out to midi clock. As some daw/plugin can convert midi messages to tempo messages, i need to convert trig OUT to any message.
Does this make sense ? |
seraph
Editor
Audio files: 33
Posted: Wed May 09, 2007 11:27 am Post subject:
kragg wrote: |
it does, I had not understood your drum machine was pre-midi. _________________ homepage - blog - forum - youtube
Quote: | Don't die with your music still in you - Wayne Dyer |
kragg
Posted: Wed May 09, 2007 12:51 pm Post subject:
ok ! |
BoomBoxJohnny
Posted: Sun May 27, 2007 12:29 pm Post subject:
Hi! I have a similar question
i own a Korg Rhythm 55 drum machine, a Roland MC202 sequencer and a Korg KMS-30 Midi synchronizer and would like to sync the drum machine with the sequencer. is it possible?
here is some pics i have of the back views of said equipment
any help would be very much appreciated!
thanks!
kragg
Posted: Sun May 27, 2007 12:48 pm Post subject:
AS your drum machine only have trigger out, i think it is the only gear able to act as "master" clock, and you have to get the mc-202 be the slave and receive a constant trigger from the korg55.
Beware with the 24/48ppqn conversion. |
BoomBoxJohnny
Posted: Sun May 27, 2007 1:13 pm Post subject:
yeah, you're right. what i don't know is how to connect them. the korg rhythm55 has a JACK-type output and the roland mc202 has a DIN-type input
that's what confuses me
kragg
Posted: Sun May 27, 2007 1:57 pm Post subject:
din is din
midi is midi
and jack is fro triggering, you can use any audio cable
you can't connect trig to din or din to midi or whatever else. |
