 Forum index » How-tos
samples synthesis
Page 1 of 1 [14 Posts]
aquanaut
PostPosted: Sun Apr 25, 2004 5:19 pm    Post subject: samples synthesis Reply with quote  Mark this post and the followings unread
hi everybody...first post here
does somebody know if it's possible to synthesis 2 samples together using FM. i'd like to go beyond either a simple mix or the mutation fonction that soundhack provides.?
Nicholas
Audio files: 147
PostPosted: Sun Apr 25, 2004 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, Nicholas. Welcome to electro-music.com.
I'm not sure what you are asking. Do you want to frequency module one sample with another?
PostPosted: Mon Apr 26, 2004 2:58 am    Post subject: Reply with quote  Mark this post and the followings unread
You are talking morphing and or true resynthesis here?? You are using mac or pc?
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Apr 26, 2004 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
maybe through the Fourier Transform:
The Fourier transform, in essence, decomposes or separates a waveform or function into sinusoids of different frequency which sum to the original waveform. It identifies or distinguishes the different frequency sinusoids and their respective amplitudes.
http://aurora.phys.utk.edu/~forrest/papers/fourier/
http://en.wikipedia.org/wiki/Fast_Fourier_transform
Idea Very Happy
PostPosted: Mon Apr 26, 2004 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
THX Carlo!
aquanaut
PostPosted: Mon Apr 26, 2004 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply
yes i'd like to mosc. but it also seem that this method will create an effect.
i want to blend a violin and a cello. maybe a resynthesis would do the trick but i don't want an approximation done with an oscillator.
i have a mac.
thanks seraph for the links. that's too far out for me.
Nicholas
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Apr 26, 2004 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
do not worry, you are in good company Shocked dunno
paul e.
PostPosted: Mon Apr 26, 2004 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
'Metasynth' is a great app for FFT...made simple....
http://www.uisoftware.com/PAGES/products.html
some other great little apps too...
Spiral Recordings
aquanaut
PostPosted: Mon Apr 26, 2004 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
some other great little apps too...[/quote]
May i dare ask what are those?
right now i'm using
-Cecilila
-Soundhack
-Marcohack
-Metasynth
-SonicWorx artist
-Turbosynth and Lemur Pro
Nicholas
paul e.
PostPosted: Mon Apr 26, 2004 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah sorry...what i meant was, that software company [u and i software] has a few other cool apps as well..like artmatic etc
anyway, once thing you might be interested in is SuperCollider
http://www.audiosynth.com
it's free and is very powerful synth, fx machine etc etc etc
there are lots of good tutorial patches.
HIGHLY recommended... since you mentioned you use things like Lemur etc
Spiral Recordings
paul e.
PostPosted: Mon Apr 26, 2004 9:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
come to think of it...in metasynth there is 'cross convolve'...that would do it...
or..'formants filter'...oooohhh..that is fun stuff
all under the 'Morph' menu
Spiral Recordings
aquanaut
PostPosted: Tue Apr 27, 2004 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
in Metasynth 2.7 you have also spectrum analysis/resynthesis.
i feel a bit stupid saying that.
i think i might be able to blend those strings samples with that process.
Anig Browl
PostPosted: Wed May 05, 2004 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, you could get hold of Reaktor, tht allows sample FM. The thing is, if you use a sample of a cello (say), because it is a recording of an oscillating string rather than an oscillator per se, FMing it will basically be like super-fast scratching. Negative FM values will make the sample play backwards and FM values lower than the sample rate will cause the pitch of the sample to fall. Now this is all to the good - I built a DJ thing in Reaktor ages ago to emulate vinyl scratching, cutting power to the turntable etc., and there is a much more powerful implementation of the same idea that ships with the product nowadays (and the demo I think). If you can get near a Kurzweil K2xxx synth, that also allows you to do FM on samples which can create some wicked textures, though you will be restricted to things like LFOs, envelopes and FUNs for the FM modulator sources.
But if you FM a cello sample with a flute sample, well you will certainly get some interesting noises but they will probably be pretty harsh and unmusical, not what you are expecting. If you want to do weird things with samples, I suggest playing different sampler channels into the G2 and then using filters and envelope followers on one sample to fiddle with the dynamics of the other, as a starting point.
play
PostPosted: Thu May 06, 2004 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
if u use an app that allows simple math on audio streams (a la reaktor, maxmsp) you can just multiply the two signals. that's the simplest modulation possible. It won't give that weird resynthesized quality that inevitable occurs when using fft, sine wav modulation, etc. It might be really quiet though, or really loud, or on an extreme end of the frequency spectrum. when I do simple modulation like that I usually do some post limiting and maybe pitch shifting as well.
maxmsp has some great fft objects if you can force yourself to spend a couple days understanding them. there's also the oft-overlooked plogue bidule (http://www.plogue.com/forums.html?option=content&task=view&id=11&Itemid=28)
happy mangling ::)
