matej
G2 patch files: 4
Posted: Thu Jun 14, 2007 4:12 am Post subject:
sostenuto pedal Subject description: and note stealing problems |
Hi everybody!
I want to use sostenuto pedal function with G2 (piano middle pedal- it sustains notes which are already depressed at the time the pedal is depressed)
I tried to do it in the same patch where the sound is, but then sustained voices are stolen, when you play too many other notes.
I also tried to do it in another patch, and send note on messages to the sound. But when you play and release the same key, that is already being held, the held note is cut too.
Sustained voices are also stolen when too many other notes are played - but this doen't happen often, because midi patch has more polyphony then sound patch.
Do you have any suggestions?
 Download |
| Filename: |
sostenuto1.pch2 |
1.19 KB |
| Downloaded: |
547 Time(s) |
| sending note-on messages to the patch |
 Download |
| Filename: |
sostenuto midi.prf2 |
4.13 KB |
| Downloaded: |
547 Time(s) |
Audio files: 215
G2 patch files: 92
Audio files: 215
G2 patch files: 92
Posted: Thu Jun 14, 2007 11:01 am Post subject:
I don't feel like there's a way around this. The voice allocation method in the G2 has been complained about a bit here - or at least that you aren't able to configure it.
By the way, I'm assuming that in your first patch, you simply want the first four notes to keep on ringing, and the fifth note to be ignored by the synth.
@soundcloud @Flattr @myspace A blog home - you can't explain music |
matej
G2 patch files: 4
Posted: Thu Jun 14, 2007 12:36 pm Post subject:
Thanks for your response.
I don't want normal sustain pedal, I want sostenuto pedal:
If you press a key, then press the pedal and then release a key, the note should be sustained until you release the pedal - this is the same as sustain pedal.
But if you press a key, when the pedal is already down, the pedal shouldn't affect that note.
Example: play a chord, press the pedal, release the chord, play a melody - you should still hear the chord, but the notes from the melody shouldn't be sustained.
3 notes chord + monophonic melody -> 4 voices should be enough, but they aren't enough in my patch.
Sorry, if I wasn't clear in my first post.
Matej |
Audio files: 215
G2 patch files: 92
matej
G2 patch files: 4
Posted: Sat Jun 16, 2007 12:41 pm Post subject:
I can't figure it out either, but it looks promising.
I will try to make it work, when I have some time.
Btw, I connected voice number output from status module and control sequencer control input, to see which voice is being triggered.
But I guess you already know such tricks. |
