Piezo soldering
Page 1 of 1 [2 Posts]
Ciniath
PostPosted: Wed Jul 04, 2007 1:29 pm    Post subject: Piezo soldering Reply with quote  Mark this post and the followings unread
I've been trying to use piezo disks in guitars, but I've been coming up against a problem: I can't get the solder to stick on the center of the disk. As soon as the solder cools and I pick up the disk, the wire soldered in the center falls off. The other wire, soldered to the edge is fine, but it's getting annoying. I'm using a 50 watt soldering iron, with generic lead-free solder.
jksuperstar
G2 patch files: 18
PostPosted: Wed Jul 04, 2007 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like you needs some flux! 50W is a bit excessive, but should work ok. If you have some flux-core solder, it usually helps even more. But in general, lead-free solder is a PAIN to rework manually, since it doesn't flow very well (and hence, as you see, doesn't stick too well either). It was mainly developed for mass production.
