Posted: Tue Jul 03, 2007 4:47 am Post subject:
A basic flip flop using dual input AND gates? |
Does anyone know how to make a basic flip flop using dual input AND gates? Needs to run at up to about 5Khz. _________________ What makes a space ours, is what we put there, and what we do there. |
EdisonRex
Audio files: 172
Posted: Tue Jul 03, 2007 5:01 am Post subject:
ANDs or NANDs? If I remember my logic correctly you could build damn near anything with NANDs, but it's not so easy with ANDs. _________________ Garret: It's so retro.
EdisonRex
Audio files: 172
Posted: Tue Jul 03, 2007 5:06 am Post subject:
Here's one using NAND gates.
You can lose the clock detector on the bottom if you want a real basic flip flop. _________________ Garret: It's so retro.
Posted: Tue Jul 03, 2007 5:07 am Post subject:
Yeah, it could be NANDs.
I'm only using one AND, so I could replace that with two NANDs and have two left over for the flipflop hey? _________________ What makes a space ours, is what we put there, and what we do there. |
Audio files: 278
Posted: Tue Jul 03, 2007 5:36 am Post subject:
As long as the input pulses don't overlap it will work. _________________ Jan
Posted: Tue Jul 03, 2007 5:45 am Post subject:
They won't overlap.
If they did, would it fry or just get grumpy? _________________ What makes a space ours, is what we put there, and what we do there. |
Dave Kendall
Posted: Tue Jul 03, 2007 5:51 am Post subject:
Hi Uncle.
dunno if this helps, but the "memory module" in this circuit uses a 4081 to give 4 latches.
I built one a while back, and it does work, although the key down reset time may be too slow for your purposes....
It's an interesting circuit though, sort of like a poor man's 74C922 without the "data available" output
(with too much time, and not enough money) |
EdisonRex
Audio files: 172
Posted: Tue Jul 03, 2007 6:08 am Post subject:
Uncle Krunkus wrote: | They won't overlap.
If they did, would it fry or just get grumpy? |
It's just get grumpy. That's the latch circuit there, so you'd get inconsistent states if you overlap the input pulses. _________________ Garret: It's so retro.
doctorvague
EdisonRex
Audio files: 172
Posted: Tue Jul 03, 2007 1:54 pm Post subject:
doctorvague wrote: |
Good link, thanks! |
I can't take credit for that link. I found it within these forums.
But it is a good link _________________ Garret: It's so retro.
Posted: Thu Jul 12, 2007 6:24 am Post subject:
I just learned that you can't use two NAND gates to create an RS Latch unless the inputs are normally "1" and you want it to latch on "0"s
The situation is fixed by using NORs, which, in the same configuration, make an RS Latch which has inputs normally at "0".
This causes me a pain, as I was hoping to create a simple RS Latch and an AND gate from one chip. The numbers just don't add up. Can't be done. _________________ What makes a space ours, is what we put there, and what we do there. |
