Easy PCB making
Page 1 of 1 [23 Posts]
gubbeper
PostPosted: Wed Nov 23, 2005 12:40 pm    Post subject: Easy PCB making Reply with quote  Mark this post and the followings unread
I've put some pictures and text here that show how I make my own PCB:s in my own kitchen, with no special tools and no chemistry degree. It's not a detailed instruction but more of a way to inspire fellow Sound Labers who might think this is more complicated than it is. Hope you enjoy it! Smile
 Filesize:  44.35 KB
 Viewed:  10709 Time(s)
/Per
I'm on Twitter
Wild Zebra
PostPosted: Wed Nov 23, 2005 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work and your kitchen looks very clean too. I've made all my pcbs
using Press and Peel Blue for my guitar FX, but haven't tackled the larger boards.
I don't know if you meant this
Only a few hundred tiny hoes left to be drilled.
yep I know I'm juvenile hehehehe
I want to build the sequencer this winter. Keep me posted on how it goes.
"your stripes are killer bro"
deknow
PostPosted: Wed Nov 23, 2005 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
....it looks like you get excelent results (by doing careful work, no doubt). i have to say, however, that given the hole drilling operation, and the fact that adding legending on the other side is a pain, i've opted for mail order houses when i've needed custom boards.
deknow
PostPosted: Wed Nov 23, 2005 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey very good work! I've never used photoresist, I've just did the "iron on" method by printing special paper through a laser printer. But photo resist looks much cleaner, and doesn't seem to need any touch up at all!
Unfortunately, most of the parts I use now have shrunken into TQFP and other surface mount packages, so going to board houses are sometimes the only choice. But I'll have to try out the photoresist next time I play with something like through-hole dips, or maybe even SSOP type packages.
Thanks for the post!
[edit : jk* - I moved this to the How To/Developer's Corner from the SoundLab forum so other's can find this info when making boards!]
gubbeper
PostPosted: Wed Nov 23, 2005 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oops Embarassed Thanks Zebra for the correction! Smile
About drilling hoLes I must say it is WAY easier than you might think. I would say it took about 20 minutes to do both these boards!
When it comes to legending I've noticed that if you use glass fibre based PCB:s they become semi transparent after the etching. That means you can see the PCB artwork through the board when looking at the component side. If you have the component layout in front of you on paper or on the computer screen, it's easy to find the same place on the board! The same is NOT true if you use PCB:s of the cheaper material that you can't see through.
DrJustice
PostPosted: Wed Nov 23, 2005 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey gubbeper,
Excellent documentary. Time to be proud indeed! Gotta love that exposure unit Very Happy Are you using natriumpersulfat (en. spelling?) for the etching there?
It's so cool to make your own PCBs, I've done it some times too. I find the drilling to be the hard part, usually wearing out drill bits really fast, at least on epoxy boards, even using supposedly very tough bits.
Next up is double sided then? Idea Smile
DJ
gubbeper
PostPosted: Fri Nov 25, 2005 12:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Dr: Thanks! And yes it says Natriumpersulfat on the package. I haven’t tried double sided yet but I don’t think it would be that hard. I read an other article about how to do it and basically you just tape the to negatives together and then, somehow, fix the board in between them. Didn’t look that complicated. Actually one of the boards on the pictures is double sided but the other side is simple enough that I decided to try and wire it by hand.
About drill bits, I’ve bought some, supposedly, professional ones from this guy that I’m eager to try out on the next board. I hope they’ll last a bit longer. - Pun intended Very Happy
DrJustice
PostPosted: Fri Nov 25, 2005 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Natriumpersulfat is nice to work with. When I was a kid we used jernklorid (en. sp. Ferite Chloride ?) - that was extremely messy - everything became rusty red!
I did some double sided boards by drilling guide holes in the board and the films, then using alignment pins through it all to hold it in position. Worked fine. The idea is that the board can then be handled somewhat and the films perhaps applied/reapplied for two single sides exposures etc., with repeatable alignment. But it is simpler and probably just as effective to use the tape method.
Still got a couple of makes of drill bits lying around to try out. Even though the likeliness of using a board house even for hobby projects is on the rise, you never know... might drag out the PCB kit someday just for the fun.
DJ
Pehr
PostPosted: Fri Nov 25, 2005 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice work! Very Happy I have done the same, but with boards with fotoresist already on them, and with a UV-lamp... The result is really good! Very Happy Rolling Eyes
Don't forget that there are copper traces on the component-side on the sequencer boards, you'll have to add jumper-cables or something... I had to modify the board for that... Confused
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
K
PostPosted: Sat Dec 03, 2005 2:26 pm    Post subject: Re: Easy PCB making Reply with quote  Mark this post and the followings unread
wow...you make it look simple Very Happy
babuf77
PostPosted: Thu Aug 09, 2007 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
This link is no longer functional... Sad
gubbeper
PostPosted: Thu Aug 09, 2007 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Ops, sorry! Embarassed The url must have changed when I reinstalled the server some time ago. I changed the original posting to point to the new address so it should work now.
/Per
/Per
I'm on Twitter
babuf77
PostPosted: Fri Aug 10, 2007 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I cannot find this "photoresist" ANYWHERE. I found some pre-treated boards at a local shop, but that won't do. Anyone have anything for me? Or must I use the radioshack marker method?
Also, sources for copper clad boards would be MUCH appreciated.
Thanks to all!
gubbeper
PostPosted: Fri Aug 10, 2007 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I just asked at a local supplier so I'm afraid I can't help you there. I've included the instructions I got with the can though if that can be of any help.
Instructions for the can of photoresist used
 Filesize:  333.54 KB
 Viewed:  159 Time(s)
/Per
I'm on Twitter
DETOX
PostPosted: Thu Jul 10, 2008 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
does anyone of you (germans/german speaking) know the german name for "photoresist" and where to get it (all those chemicals in general)?
cool and very easy to understand tutorial gubbeper, thanks for that !
Floppy
PostPosted: Thu Jul 10, 2008 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello detox, same question here, sorry i cant help.
and thank you gubbeper for the great tutorial.
Audio files: 116
G2 patch files: 317
PostPosted: Thu Jul 10, 2008 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.elv-downloads.de/downloads/platinenfolien/leiterplatten.pdf
has some of the words in German ... like "Photopositiv", "Eisen III Chloride", "ätzen" and what not Wink
I did a Google for German pages on the words "platinen selbst machen chloride" (without the quotes), there seem to be lots of useful links.
Coriolis
PostPosted: Sun Jul 20, 2008 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Good tips on pacifying your better half - I took notes... Laughing
C
Burn These Beats - drum loops | Prototype Graveyard - drum samples
gubbeper
PostPosted: Sun Jul 20, 2008 11:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the kind words! I just realized that photo album has 6315 views Very Happy
I am going to update it soon though. I ran out of spray and started using PCB:s that where pretreated with photoresist and found out that they weren't at all as responsive to the kitchen sink light.
I kind of gave up and bought some special, non kitchen related, equipment Shocked It's a very small and generally crappy looking exposure box bought at Kjell.com:
http://www.kjell.com/?item=89445
I'll ad some information about that in the coming weeks.
/P
/Per
I'm on Twitter
Ilanode
PostPosted: Mon Jul 21, 2008 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
It should translate as "Photolack/Fotolack".
DETOX
PostPosted: Mon Jul 21, 2008 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
have you seen it yet (to keep the board's language english)?
are you sure about that?
EDIT:
now i've read something about it too ! Smile
gubbeper
PostPosted: Mon Jul 21, 2008 10:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I re uploaded the instructions a few messages above that had disappeared somehow. It says "Fotokopierlack" in the lower right corner. Can that be the magic word you're looking for?
/P
/Per
I'm on Twitter
Ilanode
PostPosted: Tue Jul 22, 2008 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
The German Wikipedia knows only Fotolack which is translated into Photoresist.
http://de.wikipedia.org/wiki/Fotolack
Niio1
