Brussels G2 sequencer patch & Sebber seq patch
Page 1 of 1 [12 Posts]
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Aug 14, 2007 9:42 am    Post subject: Brussels G2 sequencer patch & Sebber seq patch Reply with quote  Mark this post and the followings unread
Here is the demo of the Brussels inspired g2 lookup sequencer.
[edit - removed video and replaced it with the patch - see post below.]
/Dasz
http://www.dasz.com
Electronic Music Instruments From Vancouver, Canada
(Cycling log - https://www.strava.com/athletes/5681257 )
Housefly
PostPosted: Tue Aug 14, 2007 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
i don't understand a word of what you are saying in that video Rolling Eyes
also are you sure that's a pic of brussels Very Happy
that's a site in brussels that i do not recognize immediately Embarassed
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Aug 14, 2007 11:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the bad audio.
values of knobs 1 - 4 are retrieved by values on knobs 5 - 8 (which are cycled through). Essentially the 2nd 4 knobs are a sequence which picks which of the 1st 4 knob's value will be heard at the step. A lookup.
/Dasz
http://www.dasz.com
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Aug 16, 2007 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
The patch is pretty simply. The 1st sequencer seeks the value from the 2nd sequencer (lookup. by limited the number of unique lookups (in this example to 4), I can assign the value and lookup sequencers (step 1-4 of each respectively) all to one panel page.
/Dasz
ps.: I also created a sequencer which uses the lookup values are either increments from current step (+ve values) and decrements (-ve values). 0 keeps the step at one step.
http://www.dasz.com
cebec
G2 patch files: 31
PostPosted: Thu Aug 16, 2007 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool! Thanks, Dasz. How can this be adapted to allow pre-programmed selection of multiple sequencers?
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Aug 16, 2007 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
create multiple lookup sequencers or multiple value sequencers and mux them on the downbeat. or put sequencers only in one slot use variations and control sequencer in different slot (this way you do not need to create multiple panel assignments per each pattern.
/Dasz
http://www.dasz.com
Audio files: 143
PostPosted: Thu Aug 16, 2007 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Dasz, I didn't get this when you showed it to me at Chateau Sonore. It was probably a combination of my poor close up vision and the abundance of that wonderful inexpensive Dutch "coffee". Wink
Anyway, I'm in a little better shape now and I can study this at the proper distance on my screen. This is pretty cool. Cool
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Aug 16, 2007 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is one that kind of like Sebber's piano performance.
Lookup sequencer with multiple modulations. also a good source of patterns. Playing with the values of the steps in the green "values" sequencer really changes a lot of things. Now I suppose you could modulate them & maybe a morph of them with a clocked rnd??? Wink
Someone want to try this?
/Dasz
Sebber_DZ.pch2
[ re-upped ]
 Filename:  Sebber_DZ.pch2
 Filesize:  5.03 KB
 Downloaded:  1006 Time(s)
http://www.dasz.com
sebber
G2 patch files: 33
PostPosted: Thu Sep 06, 2007 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, I didn't see this one until now. Now there's a sebber-dasz-patch. How cool is this?
Thanks, man!
Fish don't swim. They dive.
For everything else: The Patcher's Toolbox
G2 patch files: 625
PostPosted: Thu Sep 06, 2007 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, man!
Looks like this one needs restoring.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Sep 06, 2007 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
done = re-upped.
http://www.dasz.com
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Jun 18, 2009 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
here is a simplified version of this concept:
BrusselsSeq_DZ.pch2
 Filename:  BrusselsSeq_DZ.pch2
 Filesize:  2.16 KB
 Downloaded:  1037 Time(s)
http://www.dasz.com
