Using MIDI to select variations of a patch
Page 1 of 1 [3 Posts]
alchemist
PostPosted: Tue Aug 21, 2007 2:12 am    Post subject: Using MIDI to select variations of a patch Reply with quote  Mark this post and the followings unread
Hi Guys,
I have a sequenced patch whose variations are good to pass from one to another for constructing a certain part of a song. I want to change the variations not manually but from a sequencer by sending a kind of program change MIDI message from a sequencer. Is it possible to change the variations of a patch by using a MIDI signal?
Or is it possible to assign each variation to a different MIDI channel so that change can be done again in a sequencer by just sending note messsages to related midi channels accordingly. Thanx in advance...
G2 patch files: 584
PostPosted: Tue Aug 21, 2007 2:47 am    Post subject: Re: Using MIDI to select variations of a patch Reply with quote  Mark this post and the followings unread
Yes, CC70 will select a variation. It is simpler to do it from another slot so for example, see attached. Slot B changes variations in slot A.
varchange.prf2
 Filename:  varchange.prf2
 Filesize:  3.76 KB
 Downloaded:  676 Time(s)
alchemist
PostPosted: Tue Aug 21, 2007 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
thanx g2ian for your information and sample file. cheers!
