  Antimon Antimon Waves
PCMCIA card
Page 1 of 1 [8 Posts]
amnesia
PostPosted: Sat Aug 11, 2007 2:25 pm    Post subject: PCMCIA card Reply with quote  Mark this post and the followings unread
Hi all
I am looking to buy a PCMCIA card for the A6 does it matter if it has 2KB attribute memory and replaceable battery and rechargeable battery
Can i buy just any brand?
What do people recommend and where should I look to buy a card?
Saw one on ebay but it was secondhand, not sure of that is a good idea
Digimaus
PostPosted: Sat Aug 25, 2007 3:14 am    Post subject: PCMCIA 2mb Reply with quote  Mark this post and the followings unread
http://www.thomann.de/thoiw7_thomann_pcmciacard_sram_2mb_prodinfo.html
This is where I bought mine. bigsmurf
edobedo
PostPosted: Sat Sep 15, 2007 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I also bought it, works fine.
pophertz
PostPosted: Sat Sep 15, 2007 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys
Is it possible to setup this PCMCIA card to store only program patches on it? Current card setup allows you to store this:
2048K CARD - > SB1 = PROGS SB2 = MIXES SB3 = PROGS+MIX
edobedo
PostPosted: Sun Sep 16, 2007 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
My Andy formatted it as 8 program banks.
I tried to format different fro it but seems this is the only formatting mode.
pophertz
PostPosted: Sun Sep 16, 2007 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I've found answer on this site:
http://www.wohmart.com/a6/tandt/A6TipsAndTricks.html#0x11x2xENVELOPESx%20xoutline
Doug Pearson wrote:
The procedure is a little tricky; you have to follow the directions carefully or you'll miss the important step (like I did about 6 times).
After it displays the card size, it should then display a message something like:
SB1=programs SB2=mixes SB3=progs&mixes
This means that you hit soft button 1 to put only program banks on the card, soft button 2 to put only mix banks on the card, and soft button 3 to put a combination on. If you just hit "store" a second time without having pushed one of the required soft buttons, it will abort the initialization process.
And it works Smile
"Listening to the music
That machines make
I left my heart break
Just for a moment"
rh2y
PostPosted: Sun Sep 16, 2007 10:49 am    Post subject: Re: PCMCIA card Reply with quote  Mark this post and the followings unread
amnesia wrote:
Hi all
It's probable that these http://www.envoydata.com/shopping/display_products.php?catid=13 cards should work, as well.
I don't know of anyone who has tried one, but it seems to have the same specs as the cards from thomann.
I'm pretty sure the A6 doesn't use bigger cards than 2MB though, so no point spending more on the larger cards.
I already have my card (bought it on eBay), but still waiting on the synth. Luckily, I also have a QS6, and the A6 card also works in the QS6 (but not all QS6 cards work in the A6).
Good luck,
Russ (rh2y)
Shameless plug: http://www.whiterose.net/~russ/synth.html
Shameless-er plug: http://www.evatontechnologies.com/music-products
Music: http://www.soundcloud.com/rh2y
edobedo
PostPosted: Wed Sep 19, 2007 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank Prophertz!
