  bingsatellites Mostly Ambient
 Forum index » Instruments and Equipment » Samplers
Yamaha A3000 and SCSI adapters
Page 1 of 1 [5 Posts]
Gothboy
PostPosted: Tue Aug 21, 2007 8:26 am    Post subject: Yamaha A3000 and SCSI adapters Reply with quote  Mark this post and the followings unread
I have a Yamaha A3000 sampler which uses a 50-pin connector. I'd like to use a 25-pin zip drive with it for backup so I would need to buy a 50-pin male to 25-pin female SCSI adapter for it. Anyone know if adapters work with samplers like this?
Apple Mac Pro 2.66 GHz. Intel Xeon Quad core
9GB RAM
Snow Leopard 10.6.8/Pro Tools 8.0.5 Digi 002R
M-Audio Radium 61/Novation Remote Zero SL/AlphaTrack controllers
Automap 3.7
Fxspansion VST-RTAS adapter
Networked to>
G4 Dual 1.4 processor 1.25GB RAM
Pro Tools 7.3.1cs8/Tiger 10.4.11
"We are the music makers and we are the dreamers of dreams"
Dymaxion Vehicle Music at www.dymaxionvehicle.com/
EdisonRex
Audio files: 168
PostPosted: Tue Aug 21, 2007 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Typically, yes. Make sure you terminate the SCSI bus correctly.
Garret: It's so retro.
Gothboy
PostPosted: Thu Aug 23, 2007 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, well that's good to hear. I have some Roland VS recorders and I'd heard those didn't accept adapters so I wasn't sure if it was the same with a SCSI sampler. Cool
9GB RAM
Automap 3.7
Networked to>
EdisonRex
Audio files: 168
PostPosted: Thu Aug 23, 2007 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think with the Rolands it's the usual Roland screwed up implementation of SCSI and lack of support for most SCSI devices except those they could charge an arm and a leg for. Some of the Rolands worked pretty well with 3rd party stuff, some didn't. The S-50 was a good one, but some of the others were not so helpful.
My old Ensoniq ASR-10 sampler had no problems with most of the SCSI-1 disks I had lying around at the time. And my Akai S-6000 has absolutely no problem talking to pretty much any SCSI device.
The Yamahas should work, but keep it simple. If it doesn't work, report back with that it's doing, a lot of problems usually boil down to improper termination. Newer SCSI kit will probably talk, slowly, on SCSI-1, but some kit, like tape drives and other single ended stuff, gets very cranky indeed.
Gothboy
PostPosted: Sun Aug 26, 2007 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info. I'll report back later when I get the adapter. Wink
9GB RAM
Automap 3.7
Networked to>
Niio2
