  Various Artists March Equinox 2017 streaming concert
Super Klee Sequencer
Page 26 of 27 [659 Posts]
Goto page: Previous 1, 2, 3, ..., 24, 25, 26, 27 Next
sneakthief
PostPosted: Thu Aug 30, 2007 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
at least with the MIDIbox CV, there's provision for setting the pulse width:
Code:
The pulsewidth of the clock output can be configured in pieces of 500 uS. By default it's 1 mS:
; 0 -> 500 uS
; 1 -> 1   mS
; 2 -> 1.5 mS
; etc...
#define DEFAULT_EXT_CLK_PULSEWIDTH 1
A pot (or even a CV!) could be hooked up to one of the PIC's analog inputs to control this pulse width variable.
Sneak-Thief - raw electrofunk
Scott Stites
Audio files: 96
PostPosted: Thu Aug 30, 2007 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
My Site
vtl5c3
PostPosted: Thu Aug 30, 2007 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Sneakthief. I wasn't aware that there are problems with the Blacet PIC. Good to know, though.
R.
TheAncientOne
PostPosted: Thu Aug 30, 2007 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I can endorse the MIDIbox kit too - the sync works well, and it's a tiny board.
The MIDIbox monitor is a cool project in its own right, a good first MIDIbox, and a very useful tool. Cheap too - the core, a 4x20 LCD and a couple of buttons.
Mike
PostPosted: Thu Aug 30, 2007 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Code:
; 0 -> 500 uS
; 1 -> 1   mS
; 2 -> 1.5 mS
; etc...
would this require high programming skills?
fonitronik at
sneakthief
PostPosted: Thu Aug 30, 2007 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik - no, i think it's relatively easy. i'm consulting some gurus right now and will have a solution shortly. it's just a matter of assigning one of the analog inputs to pulse length variable.
if you like, i can compile it and send you the .hex file to upload when it's ready.
PostPosted: Thu Aug 30, 2007 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
wow, that's great, sneakthief! thank you very much! highly appreciated.
fonitronik at
Clack
PostPosted: Sat Sep 01, 2007 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I was wondering where I could find the schematics for theese projects? are they public? some links seem to be dead that point to them?
Clacktronics.co.uk
sneakthief
PostPosted: Sat Sep 01, 2007 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you're talking about the MIDIbox project, then look no further than http://midibox.org
Clack
PostPosted: Sun Sep 02, 2007 3:04 am    Post subject: Reply with quote  Mark this post and the followings unread
no sorry, I mean the klee?
Clacktronics.co.uk
Randaleem
PostPosted: Sun Sep 02, 2007 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
See the first page of this thread.
Best regards,
Randal
Clack
PostPosted: Sun Sep 02, 2007 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
yes I have tried that. it appears to be missing Shocked
Clacktronics.co.uk
THeff
Audio files: 31
PostPosted: Sun Sep 02, 2007 12:02 pm    Post subject: VC Clock for Klee or Other Sequencer Reply with quote  Mark this post and the followings unread
All,
I just finished building a voltage controlled clock for the Klee. The design is based on the Roland M-182 sequencer and it works great!
Features:
1.) Voltage Controlled
2.) Freq: 0.14 Hz to 33 Hz, (7s - 3ms).
3.) Clock and Gate outputs with variable Gate width.
4.) Start/Stop button and ext. Start/Stop
5.) Temperature stabilized.
6.) Free run and single-step.
I have enclosed the edited schematic and the original can be found here:
http://fa.utfs.org/diy/roland100m/index.html
Fairly easy to build.
Regards,
Tim
 Filesize:  83.14 KB
 Viewed:  501 Time(s)
THeff
Audio files: 31
PostPosted: Sun Sep 02, 2007 12:05 pm    Post subject: Clock for Klee Reply with quote  Mark this post and the followings unread
All,
Here is the finished module waiting for front panel graphics.
Tim
 Filesize:  43.48 KB
 Viewed:  411 Time(s)
bugbrand
PostPosted: Sun Sep 02, 2007 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tim, that's A.C.E.! Nice work and nice share!
http://www.bugbrand.co.uk
Scott Stites
Audio files: 96
PostPosted: Sun Sep 02, 2007 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm....a very nice addition indeed!
And the Klee schematics - AAAARRGGGHHHH! I was going to fix the swapped pins on the TL074 sections, then re-upload it, but it's not going to happen in a while (maximum effort going into Klee proto). So, thought I'd upload warty version 3.03, which is quite usable, but it's not on this computer.
Anybody got the 3.03 zip file handy?
My Site
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Sep 03, 2007 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
Well, look at his avatar - wouldn't a crown of laurels look good on there?
Anyway, here's a sort of plea for the Klee thread readers: I'm uploading a draft of part of the Klee ops manual. It's the section that attempts to describe what it is the Klee does. This thread is huge, and the information is so scattered throughout, I wonder if what a Klee Sequencer is generally known by more than a few people.
So, this portion covers the basic fundamentals of the Klee pattern generator and gate bus - it stops right at the description of the merge switches (I'm still working on that). There will be a separate operations section (programming the pattern, clocking it) - this section is more along the lines of understanding the underlying nature of the beast.
I certainly would appreciate feedback - is the style too simplistic, unnecessarily technical, confusing? Does it help to clear confusion or serve to inflict it? Please let me know!
Scott
Edit: It probably would have helped to number the pages - I can fix that and upload a numbered version (and fix a couple of minor grammatical errors, and one error right after Figure 22 - it should read "step three selects stages three and seven" not "three and four").
Edit 2: Numbered version uploaded, fixed the figure 22 thing.
hej Scott. Could you reupload missing "know_the_Klee_draft2.pdf" file? thanx
ivan
THeff
Audio files: 31
PostPosted: Mon Sep 03, 2007 5:47 am    Post subject: know_the_Klee Reply with quote  Mark this post and the followings unread
Hi a.b.o.z.,
Here is the file you are looking for.
Regards,
Tim
know_the_klee_draft2_671.pdf
 Filename:  know_the_klee_draft2_671.pdf
 Filesize:  208.47 KB
 Downloaded:  437 Time(s)
Scott Stites
Audio files: 96
PostPosted: Tue Sep 04, 2007 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
[Edit by Blue Hell : please follow http://radio.electro-music.com/forum/topic-24821.html for the docs]
Actually there was a later draft of "Know the Klee" (rev 3) posted here:
http://electro-music.com/forum/download.php?id=8646
Things are getting pretty scattershot for the Klee Sequencer - I'm going to try to consolidate the info for the electro-music Klee Sequencer PCB project to this thread (which was formerly the original PCB poll, but is now more of a build thread):
http://electro-music.com/forum/topic-19278.html
This thread, which was about the development of the Model 2 Klee, which is essentially the electro-music thread, is going to be unstickied to make room for a new, more useful thread for everybody.
As things progress here, things tend to get lost in the roar of what's going on - I plan to sticky a new directory of projects so that everyone's PCB project can be found easily through all of the threads. I figure this will be handy for those of us that have been here a while, and for new members who may still be coming to grips with what's offered.
Scott
My Site
THeff
Audio files: 31
PostPosted: Tue Sep 04, 2007 3:27 pm    Post subject: Klee 2 Schematic Documents Reply with quote  Mark this post and the followings unread
All,
At Scott's request I have edited the pin numbers of the TL074 op amps in the Klee 2 schematics and I am re-posting them as version 3.02A.
Regards,
Tim
kleev302A_krunkus_edition.zip
 Filename:  kleev302A_krunkus_edition.zip
 Filesize:  1.93 MB
 Downloaded:  496 Time(s)
Scott Stites
Audio files: 96
PostPosted: Tue Sep 04, 2007 10:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Tim!!
My Site
Sound
PostPosted: Sat Feb 21, 2009 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
One other unrelated note: the gate bus schematic defaults to +5V gates and triggers. That is determined by running the outputs of the LM324s through 3K with 1.5K to ground. This divides the original 15V level to 5V and creates a 1K output impedance, because the 3K and 1.5K are essentially in parallel.
One thing has bugged me about that - not all synths will respond to +5V. Though it's the Electronotes standard, it's not a universal standard. For example, Ray Wilson's EG's will not respond to those levels. This is easily remedied - instead of running the output through 3K with 1.5K to ground, run the output through 1.5K with 3K to ground - IE, swap the two resistors around. The same output impedance is maintained, but now the gates and triggers will be 10V. That's a personal preference decision that can be made at time of build, and I'll note it on the updated schematics, which are coming down the pike.
Only curious,
Is there any inconvenience, any incompatibility, running the gate trigger outputs at 10V?
Scott Stites
Audio files: 96
PostPosted: Sat Feb 21, 2009 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, not with my system. I know the electronotes standard uses 5V gates and triggers, so that's why I put the option in. I seriously don't know if those types of levels would bother anything, or blow anything up, if it was designed for 5V levels. Maybe someone could kick in with more info on that.
BTW, Ray's EGs now do respond to the lower levels. I think I built my MFOS EGs (on proto-board) about 2.5 seconds before he designed some that respond to lower levels.
Cheerios,
Scott
My Site
Sound
PostPosted: Sat Feb 21, 2009 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Sat Feb 21, 2009 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
@sound:
how great you digged the origin klee thread. IMHO it is one of the greatest e-m threads ever! it is such a great example of sharing, collaboration and such from the beginning - outstanding and striking!
fonitronik at
