jhaible
Posted: Mon Sep 10, 2007 3:18 pm Post subject:
| v-un-v wrote: |
Any thoughts? |
Way too complicated, IMO.
When you've seen the adhesive tape mothod, you won't look back, I promise.
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
jhaible
Posted: Mon Sep 10, 2007 3:19 pm Post subject:
Are the Perkin Elmer A906011 and A906012 easy to get in the US ?
(I don't say these will work - I just want to know before I buy samples here in Germany.)
Joined: May 16, 2005 Posts: 8902 Location: Birmingham, England, UK
Posted: Mon Sep 10, 2007 3:21 pm Post subject:
| jhaible wrote: | | v-un-v wrote: |
Any thoughts? |
excellent! (I was just showing off my Solidworks skills anyway ) _________________ ACHTUNG!
vtl5c3
Posted: Mon Sep 10, 2007 3:24 pm Post subject:
| I just checked at Allied. They don't have them. They're one of the better places to get Perkin Elmer components in the US. Maybe you could do a catalog search on their site for "perkinelmer" to see what comes up. http://www.alliedelec.com |
jhaible
Posted: Mon Sep 10, 2007 3:33 pm Post subject:
| vtl5c3 wrote: | | I just checked at Allied. They don't have them. They're one of the better places to get Perkin Elmer components in the US. Maybe you could do a catalog search on their site for "perkinelmer" to see what comes up. http://www.alliedelec.com |
I just checked the perkinelmer site and couldn't even find them _there_.
Have I mixed up manufacturers?! No - I checked again at Reichelt: Clearly a Perkinelmer data sheet.
Posted: Mon Sep 10, 2007 3:38 pm Post subject:
http://doc.chipfind.ru/perkinelmer/a906011.htm _________________ ACHTUNG!
moosapotamus
Joined: May 11, 2007 Posts: 96 Location: New Hampshire USA
Posted: Mon Sep 10, 2007 5:42 pm Post subject:
Here are some pics that were posted at diystompboxes a while ago...
FRONT
TRANSPARENT
BACK
... it doesn't look like they bothered with tape or any covering at all for the bulb/LDRs in the original unit.
~ Charlie _________________ moosapotamus.net
"I tend to like anything that I think sounds good" |
Posted: Tue Sep 11, 2007 12:14 am Post subject:
Ahh look at those gorgeous knobs!
Thanks for posting this! _________________ ACHTUNG!
moosapotamus
Posted: Tue Sep 11, 2007 6:50 am Post subject:
Actually, looking at that cropped pic of the opto set-up and seeing that yellow tape around the bulb, I recall reading somewhere that the original actually had tape wrapped not around the LDRs, but just around the bulb, only. That's sort of how it looks in the pic, too. Maybe that's to diffuse and even out the light that hits the LDRs? Or, maybe it's because the wavelength that the LDRs were most sensitive to was in the yellow range, hence, the yellow tape around the bulb... maybe??
jhaible
Posted: Tue Sep 11, 2007 8:11 am Post subject:
| moosapotamus wrote: | Actually, looking at that cropped pic of the opto set-up and seeing that yellow tape around the bulb, I recall reading somewhere that the original actually had tape wrapped not around the LDRs, but just around the bulb, only. That's sort of how it looks in the pic, too. Maybe that's to diffuse and even out the light that hits the LDRs? Or, maybe it's because the wavelength that the LDRs were most sensitive to was in the yellow range, hence, the yellow tape around the bulb... maybe??
~ Charlie |
Maybe it's a way to "trim" the sweep range?
In the schemos, there's a trimpot, _and_ a hint on selecting capacitors.
That means the trimpot alone probably isn't enough, and the tape around the bulb _may_ be a way to shift the pole frequencies down, if you got LDR specimens on the low end of their resistance tolerance?
Who knows ...
But I think I'll manage to (re)design something you all can build and get into the "right" range. Nict to see that with this tape around the buld there obviously is another parameter that can - in emergency case - be used to adjust this thing.
jhaible
Posted: Tue Sep 11, 2007 8:17 am Post subject:
| moosapotamus wrote: | Here are some pics that were posted at diystompboxes a while ago...
FRONT
TRANSPARENT
BACK
~ Charlie |
Thanks for the links! Nice pictures.
See how they managed to put jacks and pots onto one single pcb - and why the enclosure is shaped as it is!
In my Compct Clone I had Alps pcb mount pots , but mounted on the solder side of the board, board mounted in an ordinary enclosure bottom side up, so all the other components would point down, inside the enclosure.
This needs re-rating of the heat dispensing components, though!
I don't think it's important for DIY that the pots are on the board. Everyone can solder a few wires to a front panel. It's only 4 pots, after all.
jhaible
Posted: Tue Sep 11, 2007 8:19 am Post subject:
| v-un-v wrote: | | http://doc.chipfind.ru/perkinelmer/a906011.htm |
Does this mean they are obsolte by now ?!
frijitz
Audio files: 54
Posted: Tue Sep 11, 2007 9:04 am Post subject:
| v-un-v wrote: | | Hmm- do they look like this;? |
So that would be for the worlds fastest phaser  |
jhaible
Posted: Tue Sep 11, 2007 10:19 am Post subject:
FRONT
TRANSPARENT
BACK
~ Charlie |
BTW, this looks like a different revision than the schemos you can find everywhere:
Schemos show 2 separate bridge rectifiers, combined with 2 positive regulators. Pictures seem to have one bridge plus an integrated tracking regulator (?) with transistors to boost it (?). And not as many heat sinks.
Just a first impression - haven't traced the traces.
moosapotamus
Posted: Tue Sep 11, 2007 1:31 pm Post subject:
I think you're right! Also, looks like an extra quad opamp package just below the transformer. And, I don't see nearly as many diodes as there are in the schematic.
jhaible
Posted: Tue Sep 11, 2007 1:59 pm Post subject:
| moosapotamus wrote: | And, I don't see nearly as many diodes as there are in the schematic.
~ Charlie |
... which kindles some hope that maybe, maybe it would be possible to get this running at +/-15V. With a complete redesign of the CV driver circuit and the oscillator section. Would be some hard work to make the waveforms _exactly_ the same., under all circumstances.
We'll see ...
23isgood
Joined: Nov 18, 2006 Posts: 236 Location: San Francisco, CA bay area
Posted: Wed Sep 12, 2007 1:08 am Post subject:
Hi JH. Could you post a sample of your compact clone? I think the sample you have earlier was going through some other effects? I would love to hear a clean sample of a nice pad going through it. I love phasers. Its my favorite sound effect.
thanks
pete _________________ Check out my music |
jhaible
Posted: Wed Sep 12, 2007 3:52 pm Post subject:
Update
My version will run from +/-15V !
Going thru my old documents, I noticed that I've also taken some precautions that will allow the use of slightly different LDRs.
JH.
Now playing: Vangelis, Apokalypse des Animeaux _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
jhaible
Posted: Wed Sep 12, 2007 4:10 pm Post subject:
| 23isgood wrote: | Hi JH. Could you post a sample of your compact clone? I think the sample you have earlier was going through some other effects? I would love to hear a clean sample of a nice pad going through it. I love phasers. Its my favorite sound effect.
thanks
pete |
I'll see if I find the time.
Maybe makes more sense when I have the new Clone, rather than making samples from the old one ...
Meanwhile, you may listen to this:
http://jhaible.heim.at/mp3/jh_sec_1.mp3
http://jhaible.heim.at/mp3/jh_sec_2.mp3
http://jhaible.heim.at/mp3/jh_sec_3.mp3
Ok, I know there are many layers of sound here. But there's these OB-8 arpeggiator notes that run throughout all three mp3's, which are processed in stereo with the Compact Clone, creating some really deep resonance.
Posted: Wed Sep 12, 2007 4:11 pm Post subject:
| jhaible wrote: |
Now playing: Vangelis, Apokalypse des Animeaux |
Posted: Wed Sep 12, 2007 4:14 pm Post subject:
| jhaible wrote: |
WOAH!!!!!!
These sound fucking fantastic!!!!!!!
OH MAN!!!
Posted: Wed Sep 12, 2007 4:19 pm Post subject:
Yes!! it's thee Krautrock phaser without any doubt at all!  _________________ ACHTUNG!
Posted: Wed Sep 12, 2007 4:23 pm Post subject:
This sounds like the real thing! Yes! _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
