midioxse how to send sysex
Page 1 of 1 [5 Posts]
amnesia
PostPosted: Fri Sep 28, 2007 3:00 pm    Post subject: midioxse how to send sysex Reply with quote  Mark this post and the followings unread
Hi all
sorry never done this before
I have midi in and out connected to the A6 from my Presonus Firepod.
I have opened the MIDI OX program and can see that ins and outs are active by hitting a key on synth keyboard.
I am in USER bank....i open Sysex Scratchpad - file - send sys file - open a sys file and it says it is sending it but i cant see it on the A6?
i can work most things out in life but this has me stumped!
amnesia
PostPosted: Fri Sep 28, 2007 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok i seem to have 16 programs loaded, can see how i did that as i didnt choose them????
When i try to transfer a larger file I always get the error
Sysex output Devices port is transmitting data wait and try again...I assume this means that info is being transmitted ? but how can i see when it is completed?
amnesia
PostPosted: Sat Sep 29, 2007 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok i found out that the first 16 programs were changing and then there would be others i had loaded all over the place!
Is there a way to say i want this sound loaded here via sysex?
still cant work out the error message seem to happen with all larger sound files??????
Audio files: 278
PostPosted: Sat Sep 29, 2007 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
It might go too fast. The transfer takes place in blocks usually and probably you can set a time delay between the blocks.
I'm not an Andy nor a midi ox user, so I can't help you really, but that fastness thingie is not unusual.
invalidbuffalo
PostPosted: Sun Sep 30, 2007 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I had this same problem. The solution is to go to Sysex->Configure in the scratchpad and set the delay between buffers to 120ms and delay after F7 to 120 ms.
Hope this helps
