 Forum index » Instruments and Equipment » Cwejman Sound
mono forward comp vs. stereo
Page 1 of 1 [2 Posts]
erich
PostPosted: Fri Oct 12, 2007 6:24 pm    Post subject: mono forward comp vs. stereo Reply with quote  Mark this post and the followings unread
I can't decide on whether to wait and get the stereo forward compressor or just get a mono one. I'd really like to use it to process stereo signals from my computer, but also want to run some mono signals (mono synth, guitar, mic) I should know this, but could you just use one side of the stereo forward compressor to process a mono signal?
PostPosted: Fri Oct 12, 2007 7:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
There shouldn't be any reason why you couldn't use a mono signal in it. It probably sums the L/R channels to determine the amount of compression anyway. Worse comes to worse, you send the same signal into both inputs.
Niio1
