danbaygo
Posted: Fri Oct 12, 2007 9:12 am Post subject:
not transmitting any sysex data... |
| Hi, just received new Andromeda,all good! however there appears to be no sysex data being transmitted from any of the knobs. Keys/pitch wheel/modulation wheel/ribbon transmitting & receiving fine. TXMODE is on local/midi. OS is 01.40.12 Also RXMODE seems to be missing on the global page. Any help most appreciated...D. |
Joined: Apr 03, 2004 Posts: 19623 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Fri Oct 12, 2007 4:53 pm Post subject:
D, I hope one of the experts will step in. _________________ Jan |
danbaygo
Posted: Sat Oct 13, 2007 2:28 am Post subject:
| Thanks Blue Hell, all I want to do (initially) is record & playback filter sweeps etc as midi....D. |
soundwave106
Joined: Nov 24, 2004 Posts: 310 Location: Elmo's Mud Wrestling Club
Posted: Sun Oct 14, 2007 12:19 pm Post subject:
I don't believe the Andromeda knobs transmits Sysex data, it transmits NRPN data.
NRPNs are an abbreviation for MIDI "non-registered parameters". Basically, it's very similar to a MIDI controller code -- however, the values are 14 bit. (There's also registered parameters (RPNs), parameters the MIDI specification has defined, but there's not to many of these predefined.)
That's different from Sysex, so if you are looking exclusively for that you won't find it. Cakewalk has an article here that can perhaps help you describe what to expect... basically a sequence of four CC values.
Most modern sequencers should handle NRPNs without much effort, I would think?[/url] |
danbaygo
Posted: Sun Oct 14, 2007 4:41 pm Post subject:
| I see what you are saying, soundwave106 you're right it wouldn't be sysex. The problem i'm having is there is no data of any kind being outputted from the knobs. I'm wondering if there is a parameter somewhere that's not turned on or the OS is an old version (i'm on 1.40.12). I'm hooked up to Logic and can record and playback notes/pitch wheel/ribbon etc without any problem. (also seeing what's happening in the midi monitor window...nothing from knobs..) Thanks for your help, D. |
soundwave106
Posted: Sun Oct 14, 2007 8:28 pm Post subject:
| danbaygo wrote: | | I see what you are saying, soundwave106 you're right it wouldn't be sysex. The problem i'm having is there is no data of any kind being outputted from the knobs. I'm wondering if there is a parameter somewhere that's not turned on or the OS is an old version (i'm on 1.40.12). I'm hooked up to Logic and can record and playback notes/pitch wheel/ribbon etc without any problem. (also seeing what's happening in the midi monitor window...nothing from knobs..) Thanks for your help, D. |
1.040.12 is the latest OS. TXMODE should turn the NRPNs on when it is set to MIDI or LOCMIDI, so I'm a bit surprised you can't see anything. Maybe the TXTHIN parameter (that controls the density of knob data) can be turned so low that the data coming out doesn't look like anything to a sequencer. |
danbaygo
Posted: Mon Oct 15, 2007 4:20 am Post subject:
| Soundwave 106 I got the NRPN's working, thanks for your help. D |
