yep
Page 1 of 2 [46 Posts]
sallyjackmei
PostPosted: Wed Oct 17, 2007 2:13 pm    Post subject: yep Reply with quote  Mark this post and the followings unread
i try .... i try...
But can't use my Midi Keyb at this time...
Maybe a cable problem.don't find which cable i have to use with my Kenton Solo .
Hard to understand all sentences when you are french !!!!!
Technicals terms are hard to understand!
Thank you again for your help!
EdisonRex
Audio files: 168
PostPosted: Thu Oct 18, 2007 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Keyboard MIDI Out -> Kenton MIDI In. Check the MIDI channel for both, they should match.
Kenton GATE out -> S-1000 GATE In
Kenton CV out -> S-1000 CV In
Garret: It's so retro.
sallyjackmei
PostPosted: Thu Oct 18, 2007 1:05 am    Post subject: Reply with quote  Mark this post and the followings unread
yes i know that but with which kind of cable for CVgate ?
Stereo cable?
EdisonRex
Audio files: 168
PostPosted: Thu Oct 18, 2007 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I think your Kenton uses a mini-phone plug for the output. The Wretch wants a standard full size phone plug. You should use an adaptor for them.
http://en.wikipedia.org/wiki/TRS_connector
you want the 3.5mm mono on one side and 6.3mm mono on the other side. A music store or stereo shop should have these.
sallyjackmei
PostPosted: Thu Oct 18, 2007 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot...
One day i will play with wretch machine... one day Wink Wink
EdisonRex
Audio files: 168
PostPosted: Thu Oct 18, 2007 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
sallyjackmei wrote:
Thanks a lot...
The joystick works great, if you just want to make sounds come out of it.
sallyjackmei
PostPosted: Thu Oct 18, 2007 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
With the Joystick , i have just a little sound... and impossible to change it...
Hope My Device is OK !
sallyjackmei
PostPosted: Thu Oct 18, 2007 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you Send me an exemple of a "big sound" with the joystick ?
To check my Device...
The Big Lamps at the Right is still Cold... not hot at all, is it normal ?
i'm a little bit worry about it.
EdisonRex
Audio files: 168
PostPosted: Thu Oct 18, 2007 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
The Magic Eye on the far right should be at least lit, glowing a pale green.
Here are some pictures of mine in action. Most of the valves don't glow much, and the eye runs rather cool, but you should see the glow like mine.
 Filesize:  133.05 KB
 Viewed:  143 Time(s)
 Filesize:  149.17 KB
 Viewed:  134 Time(s)
sallyjackmei
PostPosted: Thu Oct 18, 2007 3:39 am    Post subject: Reply with quote  Mark this post and the followings unread
i think my Power Supplu is not good...
My lamp is quite red but like yours !!!!!!
And No Green in the Right Lamp
EdisonRex
Audio files: 168
PostPosted: Thu Oct 18, 2007 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I will send a sample later, I'm not at home right now.
sallyjackmei
PostPosted: Thu Oct 18, 2007 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
i still have a problem i think...
My lamps have just a little point orange/red... not lightning like yours....
Shit!
EdisonRex
Audio files: 168
PostPosted: Thu Oct 18, 2007 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
no, that is a trick of photography. They should not be all that bright to the eye.
sallyjackmei
PostPosted: Thu Oct 18, 2007 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
So...
i have bought some new cable... i succeed in making some noise with my Evolution Midi Keyboard.
BUT... No rune, always the same tune.
And i turn off the light of my room, and the lamps are very very very "quiet"... a little bit orange... but No Color in the Right Big LamP !!!!!!!!!!!!!!!
I think there is a problem...
And the noise i 've heard it's just like a buzzzz... always the same even if i touch every bouton i can!...
I 'm very sad tonight.... Sad
tiny333
PostPosted: Thu Oct 18, 2007 1:27 pm    Post subject:  sorry Reply with quote  Mark this post and the followings unread
sorry to here that your wretch is not working......
it most definatly is not working as with the joystick you can play the wretch
and get all sorts of sounds
i think the green lights on the big valve are the lfo speed...or the buss
they rise and fall with the sound....
if you go to muff wigglers
http://www.muffwiggler.com/forum/forums.html
i will post a picture of my power supply ..cant upload one here
it is also for halogen lamps..so i think your power supply is ok
but have a peek at mine....
i understand how frustrating this is and we will get thro it ok !! Rolling Eyes Rolling Eyes
sallyjackmei
PostPosted: Thu Oct 18, 2007 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you can send me a pix of your Power Supply at that email:
oli2sat@yahoo.fr
I will try to find out the problem.....
EdisonRex
Audio files: 168
I am suspicious of the power supply. I notice that it is an electronic halogen supply. I have not tried using that one, and I know the one that I use works. I can only think that it is not putting out a pure enough power, or low voltage. If it is low voltage, at least you are not hurting the S-1000.
I would rather that you got a proper 12V AC transformer. I do not want to give bad advice, especially as I am not a Metasonix employee or anything.
Please be careful with it.
EdisonRex
Audio files: 168
PostPosted: Thu Oct 18, 2007 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
By the way the green lights on the magic eye tube are for the 2 LFOs, and you will find a bar at the bottom for the gate. The two vertical bars will rise and fall (not fully, but they will wiggle) with the LFO frequencies.
The thing that makes me think you're on low voltage is because the magic eye is a fluorescent display and needs a particular voltage level to light, and you keep saying the heaters are dim, and that implies the same thing.
I really think you should get the HIT 60 or another larger non-electronic halogen transformer. The non-electronic ones are much heavier but in this application i do not trust the solid state ones.
sallyjackmei
PostPosted: Thu Oct 18, 2007 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
can you tell where did you find yours ?
i think there's still s problem with the power supply , too.
Because i haven't BUZ without playing with the Joystick so... i think the S1000 is OK ...
you have an 4.8 A .... not me !
And at the Back of Metasonix unit, it appears "POWER CONSUMPTION 3.0 amps at 12VAC" !
sallyjackmei
PostPosted: Thu Oct 18, 2007 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, i got to your PowerSupply website and i order the same PowerSupply !
I think that the only solution to know if everything OK in my device Wink
tiny333
PostPosted: Thu Oct 18, 2007 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
tho its not unheard of for the wretch to buzz......
you may know but i'll go thro it anyway....
you have (obviously) got a jack comming out going somplace you know is working
you have to press the joystick quite hard to trigger it....
switch the vca switch to the left (taking buss b out)
turn all buss A off
turn all attck buttons to 0
turn your osc up to 12 0'clock
turn your wavshaper on
press the joystick
that baby ought to be howling now !!!
move your osc tune
if you dont hear the osc changing pitch .....errrrr o dear
seek proffesional help
maybe a valve broke in shipment
mine arrived with a broken perspex cover so i think it fair to say
they get a bit of a bash in transit...
Sad Sad Twisted Evil Twisted Evil Evil or Very Mad Twisted Evil Evil or Very Mad Twisted Evil Evil or Very Mad Twisted Evil
EdisonRex
Audio files: 168
PostPosted: Thu Oct 18, 2007 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I hope it is okay, but we will know when you get the new transformer.
Fingers crossed! Did you still want to hear what sounds with the joystick were supposed to be like?
sallyjackmei
PostPosted: Thu Oct 18, 2007 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh yes !!!!!!
tiny333
PostPosted: Thu Oct 18, 2007 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
i am casting a vote for the power supply not being the problem...
unless it is wired up incorrectly
it is putting out the correct output
i was given a hologen lamp transformer by richard at rl music (official metasonix dealer)
im voting bust valve or just some setting fucking you up
tiny333
PostPosted: Thu Oct 18, 2007 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
as the wretch does make some horrible noise...is there a dealer in france?
