If I'd make a string chorus PCB, what kind of multi-BBD circuit would you prefer? |
Solina style (also: Crumar Performer, Böhm Phasing Rotor, and others) |
62% |
[ 28 ] |
ARP Omni style |
13% |
[ 6 ] |
Elka Synthex 4 BBD circuit |
11% |
[ 5 ] |
other (please name in thread) |
6% |
[ 3 ] |
I would want neither - it's old fashioned and overused, and if I need it, there are digital FX boxes |
6% |
[ 3 ] |
Total Votes : 45 |
kokoon
Posted: Fri Oct 19, 2007 4:21 am Post subject:
mine were shipped from vintageplanet.nl yesterday. apparently he's out of them too now. |
softfin
Joined: Oct 11, 2006 Posts: 271 Location: Far in the north
Posted: Fri Oct 19, 2007 5:00 am Post subject:
kokoon wrote: | mine were shipped from vintageplanet.nl yesterday. apparently he's out of them too now. |
True. I ordered from them too and they had three pieces left after my order on thursday. Those three are probably sold by now as well. |
Usine Karate
Joined: Jun 09, 2007 Posts: 64 Location: Hackney Wick
Posted: Fri Oct 19, 2007 11:31 am Post subject:
Hi all, just looking for 18v AC transformers to power this and can only find this from Banzai, is this going to work?
their code number is : EH 18V AC UK, 1000mA , on this page :
http://banzaieffects.com/18V-Power-Supplies-c-938.html
Looks okay to me, but that is based on my limited knowledge, and I don't really like dealing with the mains, I tend to plug stuff into my modular supply (12v) but I'd quite like to make this a seperate unit, any advice would be most appreciated!
thanks
Usine |
jhaible
Posted: Fri Oct 19, 2007 1:37 pm Post subject:
Usine Karate wrote: | Hi all, just looking for 18v AC transformers to power this and can only find this from Banzai, is this going to work?
thanks
Usine |
18V AC looks right.
It's quite oversized, with its 1000mA, though.
So you must make sure that with the light loading of the Solina, the output voltage doesn't get too high.
Check if the LM337 gets too hot, and add a heat sink (insulated!) if necessary.
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
Usine Karate
Posted: Fri Oct 19, 2007 1:52 pm Post subject:
Thanks JH!
would it be better if I used one to power the Tau Pipe, the Solina and the Compact all together, thereby spreading the load a bit? I suppose they would all draw a little bit of the current reducing the amount going in to the boards?
If anyone could enlighten me further I would be most thankful, I'll do some research myself of course and attempt to learn something.
Usine |
jhaible
Posted: Fri Oct 19, 2007 3:54 pm Post subject:
Usine Karate wrote: | Thanks JH!
Usine |
I wouldn't recommend that. Ground loops and all.
If you want to use them all together, better buy a decent +/-15V DC stabilized Power supply, omit the PSU components on my boards, and power it from the DC supply.
But I didn't say that 18V AC wallwart doesn't fit; I just said you have to be carefull to handle the excess voltage and excess heat.
I've tested my own Tau with a 14V AC (nominal) / 7 Watt wallwart, which - to my astonishment - had enough voltage for the Tau to work. I wouldn't recommend that, though.
jgrisso
Joined: Oct 22, 2007 Posts: 2 Location: Salt Lake, UT
Posted: Mon Oct 22, 2007 8:45 am Post subject:
Group Buy! |
Hi Gang,
Sorry it took so long for me to get here, the weekend was busy. I'm organizing a group buy of TDA1022s, and have a large number of folks wanting these already. Currently, I'm working with a component headhunter to secure between 200 and 300 pieces.
I don't have pricing or availability yet, but if you want me to keep you posted on the progress of this order, email me at jgrisso at det3 dot net
Tschau! |
jhaible
Posted: Mon Oct 22, 2007 11:02 am Post subject:
Re: Group Buy! |
jgrisso wrote: | I'm working with a component headhunter to secure between 200 and 300 pieces. |
vtl5c3
Posted: Mon Oct 22, 2007 11:08 am Post subject:
Re: Group Buy! |
If that works out, I would love to order a board. I hope the ordering can wait until we get confirmation that the TDAs will be available for sure.
jgrisso wrote: | Hi Gang,
Tschau! |
jgrisso
Posted: Mon Oct 22, 2007 11:18 am Post subject:
Re: Group Buy! |
jhaible wrote: | jgrisso wrote: | I'm working with a component headhunter to secure between 200 and 300 pieces. |
JH. |
Hold your enthusiasm until the order gets closed out. I'm still working with the supplier on cost and which parts to snatch. It's no good working on this if we get a box of parts that aren't qualified and are going to show up as duds.
The scary part is that the 200 pieces will satisfy anyone who has e-mailed me so far, but not much more than that. If there's much more interest I could see this order getting a mite bigger.
You designed quite the board there, Herr Haible. |
jhaible
Posted: Mon Oct 22, 2007 11:46 am Post subject:
Re: Group Buy! |
jgrisso wrote: | jhaible wrote: | jgrisso wrote: | I'm working with a component headhunter to secure between 200 and 300 pieces. |
JH. |
Yeah, it's scary that the number of boards could be limited by the number of available chips, when I intentionally chose a BBD I thought was not one of the rare ones.
Don Solaris
Posted: Tue Oct 23, 2007 6:57 am Post subject:
Well, first i'm getting 6 BBD's, then, once i have them here, right next to me, i'm ordering two ensemble boards for some true stereo goodness.
@jhaible: One question. In that first demo - which filter setting on the ensemble board did you used - the 16kHz or the 12kHz? Is there external switch option provided so that i can select between the original (12 kHz) vs high bandwidth (16 kHz) sound color? |
keithwin
Posted: Tue Oct 23, 2007 7:07 am Post subject:
Found them here too but expensive:
www.mark5.com
They also have my E101 FETs for my mini - YAY!!!! |
jhaible
Posted: Tue Oct 23, 2007 9:52 am Post subject:
Don Solaris wrote: |
The switch offers 3 options: 16 kHz, 12 kHz, and Crumar EQ.
I don't remember in which position I've made that demo. (If you'd have seen me under what conditions I've made it, you'd understand. )
But there's not much difference between 12k and 16k, when th einput signal isn't overly bright to start with.
jhaible
Posted: Wed Oct 24, 2007 8:11 am Post subject:
Apparently there are TDA1022's available in Argentina.
I just forward this from synth-diy; haven't checked it myself.
JH.
I bought lots of parts at Dicomse in the past (obsolete now and back then)
but personally from their shop, never by mail.
In a spark of curiosity I called them and they said the 1022 are in stock
at 8 USD each and they send them worldwide.
The shop is in Buenos Aires.
http://www.dicomse.com.ar
There is a decade that I don't buy something from them, and of course
I have no affiliation with them. Just take this as a public service.
Fabio
============================================== _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
Luka
kokoon
Posted: Wed Oct 24, 2007 10:12 am Post subject:
Luka wrote: | i thought i sent this link to joe
i found a supplier with a truck load of them 12000+ in fact
http://www.4starelectronics.com
looks like its a group buy option only. minimum 300$US order |
woah! did you check with them if that's true? cause if it is, then JH can order a second run of the boards AND start working on his next BBD project |
Luka
Don Solaris
Posted: Thu Oct 25, 2007 1:45 am Post subject:
Re: Group Buy! |
BBD's solved. Last edited by Don Solaris on Thu Oct 25, 2007 4:44 am; edited 1 time in total |
Don Solaris
Posted: Thu Oct 25, 2007 4:22 am Post subject:
jhaible wrote: | The switch offers 3 options: 16 kHz, 12 kHz, and Crumar EQ. |
Ok, one more question. Is there a trimmer inside that lets me change the speed of modulation; and a trimmer to set the depth of modulation. Or, are those parameters permanently set?
(i talk about small adjustments, for example: Solina that my friend owns has a little bit slower ensemble speed)
Would it be possible to control these two above parameters using external potentiometers? |
Dave Kendall
Posted: Thu Oct 25, 2007 5:15 am Post subject:
Hi.
For Eastpondians who don't want to wait for a group buy, I just received some TDA1022s from Cricklewood electronics in the UK . The bloke I spoke to said that "they'd got loads of them......"
£5 each + £2.50 delivery + VAT. Not particluarly cheap, but very fast delivery - ordered 17.30 PM , arrived just before 1 PM next day
Dave |
jhaible
Posted: Thu Oct 25, 2007 11:29 am Post subject:
[quote="Don Solaris"] jhaible wrote: |
Yes, there are potentiometers for fine adjustment of the slow and the fast LFO rate. These are 1MegOhm trimmers.
The Shape trimmer is 10k.
All three can be brought out to the front panel, as 1M lin and 10k lin potentiometers.
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Thu Oct 25, 2007 11:36 am Post subject:
jhaible wrote: | Apparently there are TDA1022's available in Argentina.
JH.
Fabio
I bought 15 pcs there.
Gyeah!!!!! |
keithwin
Posted: Thu Oct 25, 2007 2:56 pm Post subject:
Got my TDAs from smallbear today! |
germaniac
Posted: Thu Oct 25, 2007 3:21 pm Post subject:
Don Solaris wrote: | . . . i'm ordering two ensemble boards for some true stereo goodness. |
So the stock Solina is not a stereo output device? Would it be possible to create non-inverted+dry, inverted+dry pseudo-stereo outputs with the Solina? If this is not possible with the existing PCB (I assume it's no longer in the drawing-board stage now) could it be modded afterwards? Anyone try this or have any idea whether it would be worthwhile?
Regards,
Joe |
