today> Twyndyllyngs Live - special shelter in place episode experiment Chez Mosc
Schulte Compact A Phasing
Page 5 of 27 [660 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, ..., 25, 26, 27 Next
Scott Stites
Audio files: 96
PostPosted: Sat Oct 13, 2007 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, that's good! I suppose this means, however, you're probably not getting to the moon.... Very Happy
My Site
germaniac
PostPosted: Sat Oct 13, 2007 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Happy to learn you're regaining "balance" and feeling better! Very Happy
Wise man once say, Walk lightly and you'll walk long, so take it slow and easy. . . . Wink
Regards,
Joe
jhaible
PostPosted: Sun Oct 14, 2007 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Hey Jurgen have you had a chance to find any suitable LDR's yet?
Tom
I'm starting to evaluate suitable LDRs again.
Right now, I have the Perkin Elmer M996011B in my focus.
It looks about right from the data and physical size.
While I'm going to test these some time next week, can anybody check the availibility from mail order shops outside Germany, and the USA in particular? (In Germany, it's available from Schuricht.)
Mind you, this is still completely untested.
JH.
germaniac
PostPosted: Sun Oct 14, 2007 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey JH,
I think Perkin Elmer might be better known in the US as the "Vactrol" line, which is stocked by Allied Electronics. They carry lots of LDRs like these
But I don't find any part number resembling M996011B. Maybe a different part numbering scheme for US and Europe?
Regards,
Joe
[Edit Blue Hell: shortened the link]
jhaible
PostPosted: Sun Oct 14, 2007 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
That's the one I mean:
http://optoelectronics.perkinelmer.com/content/datasheets/dts_m9960.pdf
http://optoelectronics.perkinelmer.com/Catalog/Product.aspx?ProductID=M9960+11b
JH.
germaniac
PostPosted: Sun Oct 14, 2007 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
It doesn't look as though the PE flatpack LDRs are very available here--Google only delivers nine results, none of which is a small-quantity supplier in the US. Here's a comparison chart with everything PE makes, but I'm having trouble ( Embarassed ) comparing the dissimilar spec parameters:
http://optoelectronics.perkinelmer.com/content/RelatedLinks/SpecificationSheets/SPC_Photocells.pdf
If the flatpacks turn out to be must-have, probably something more available here with similar on/off ohms, etc. could be found?
jhaible
PostPosted: Sun Oct 14, 2007 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Flatpacks are not a must.
What I know by now: The lowest on-resistance you can get is probably right for this application.
So I've been looking for low Z, and things like NORP-12 (or even better, NORP-13) might work, but they are quite expensive and rather bulky. Then I found these flatpacks and their specs seem to be roughly in the right range, and they look so damn similar to the unmarked old surplus LDRs I've used 8 years ago, that I thought I will try these first.
Once I know there work (hopefully), we can simply match specs to find something similar.
As of now (before I've tried these), it's hard to tell, because I have no reference for measuring the light conditions for which LDRs are spec'ed.
JH.
jhaible
PostPosted: Thu Oct 18, 2007 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
Tom
JH.
Got my samples today. They look the same, they measure the same. Gotta solder them in and listen, just to be 100% sure.
Then it will all be easy. Either I can match specs with other more available parts, or just try to buy a thousand of them. Or two thousand. Very Happy
JH.
ETA: Bot sure about Bingo. See my next mail.
PostPosted: Thu Oct 18, 2007 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Superb! Cool
ACHTUNG!
jhaible
PostPosted: Thu Oct 18, 2007 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
jhaible wrote:
Tom
JH.
Bingo!
JH.
Sorry - I was too fast.
The Perkin Elmer M996011B match the LDRs that gave good results on my new version of the CC. But apparently I have used others on th eold one. I just found some photos that hint in that direction. I'll have to dismantle it again to be sure.
Looks like I got tired and should stop working now. Exclamation
Also, they give Ken Russel's "Gothic" on the TV tonight. Must go and watch it, probably for the 4th or 5th time. Awesome film.
See you tomorrow. Laughing
JH.
germaniac
PostPosted: Thu Oct 18, 2007 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Ken Russell's "Lair Of The White Worm" is also lots of fun. Have not seen "Gothic" yet, but will check it out sometime. Very Happy
PostPosted: Thu Oct 18, 2007 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
'Gothic' is a classic! Very Happy
It sounds like you got what I had over the summer- it really does. It goes away eventually but it takes ages. I was initially told it was Glandular Fever- but all the blood tests came back negative. Confused I'm still getting mild dizzyness- especially when I get tired.
ACHTUNG!
jhaible
PostPosted: Fri Oct 19, 2007 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Update
More pictures of the prototype:
http://www.jhaible.heim.at/compact_clone/compact_clone.html
JH.
jhaible
PostPosted: Fri Oct 19, 2007 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
fluxmonkey
PostPosted: Fri Oct 19, 2007 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
that is so damn sexy.
PostPosted: Fri Oct 19, 2007 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
you're telling me! Very Happy
ACHTUNG!
PostPosted: Fri Oct 19, 2007 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh yeah, the board has that Lauren Bacall look. Cool
jhaible
PostPosted: Fri Oct 19, 2007 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ha ha, sexy. Laughing
You have to hide these incandescent lamps inside, of course.
But did I mention there's a 3rd of these on the front panel?
It's in the red socket above the "Modulation" Knob in this picture:
http://home.debitel.net/user/jhaible/compact_clone1.jpg
JH.
PostPosted: Sat Oct 20, 2007 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes it's a shame that there really isn't such a thing as 1-way glass! Crying or Very sad Wink
ACHTUNG!
Peake
PostPosted: Sat Oct 20, 2007 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
This is the kind of old-school technology that give me grins, relying on natural and varying rise and fall times... Kudos, Juergen!
jhaible
PostPosted: Sat Oct 20, 2007 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Well the good thing is that with the incandescent lamps being so slow that they dominate the time constants, I don't have to worry that much about the time constants of the LDRs.
And the lamps, together with the control circuit, absolutely make a difference. I have a phaser setting in my Matrix FX that emulates the structure of the Compact A's audio path (which is quite unique, too), but not the incandescent lamp control, and something is clearly missing.
JH.
PostPosted: Sat Oct 20, 2007 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
JH, I reckon you need to update your avatar with a pic of these bulbs! Very Happy Wink
ACHTUNG!
mono-poly
PostPosted: Sat Oct 20, 2007 10:40 am    Post subject:   Reply with quote  Mark this post and the followings unread
So true!
jhaible
PostPosted: Sat Oct 20, 2007 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
I made another demo; wanted to know how the effect sounds on Mellotron strings. Excuse my sloppy playing.
Setup is GMedia MTron -> Roland RE201 -> Compact Clone -> Quantec QRS
The Compact Clone still has the flatpack LDRs which give a too high idle setting of the pole frequencies. This will be cured later, either with larger capacitors, or with a different LDR type.
But I think that typical sweep waveform at th elow frequencies is already there.
JH.
jh_cc_mysterious_tron.mp3
 Filename:  jh_cc_mysterious_tron.mp3
 Filesize:  1.37 MB
 Downloaded:  795 Time(s)
Peake
PostPosted: Sat Oct 20, 2007 8:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are about to be single-handedly responsible for a huge amount of new TD-ish space rock! Very Happy Laughing
Sounding great! I can't wait.
You have a Quantec? Shocked
