I get clicks on bass sounds that are in mono
Page 1 of 1 [4 Posts]
Roman
PostPosted: Sun Oct 21, 2007 5:19 pm    Post subject: I get clicks on bass sounds that are in mono Reply with quote  Mark this post and the followings unread
The only way to get rid of the click on the attack that happens when another note is played cutting off the previous is to raise the attack.
This isn't totally satisfacory because you have to actually alter the sound to get rid of the click. I doubt there is a real fix for this. My Korg MS20 doesn't have this problem.
Roman.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Oct 21, 2007 11:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could you send in the Program, in sysex format?
It could be anything, like mono mode (which is more pronounced then other modes) or the filter cut-off in combination with another parameter.
If you need a tool to create sysex files, go to http://nm-archives.electro-music.com/020_NordLead2/023_Miscellaneous/NordGenerator_Editor/
BTW the whole site could be interresting http://nm-archives.electro-music.com/020_NordLead2/
Wout
Roman
PostPosted: Mon Oct 22, 2007 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use a mac. Can't use that application.
Roman.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Oct 23, 2007 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Roman.
On the same page is http://www.snoize.com/SysExLibrarian/
Not the same interface, but it can down and up load sysex.
Wout
