astedra
Posted: Thu Oct 25, 2007 10:36 am Post subject:
How to run Chuck |
I downloaded it, unziped it, how do I run the program? What do I have to ad it to, or with what program can I open it?
Thanks for the help,
Andrew |
Joined: Apr 03, 2004 Posts: 11349 Location: Netherlands, Enschede
Audio files: 28
G2 patch files: 293
Posted: Thu Oct 25, 2007 12:09 pm Post subject:
You really should read the manual, there is no way out
Type "chuck manual" without the quotes into google and then hit "I'm feeling lucky", or search the folder where you unzipped ChucK for a folder called doc, in that folder is a file called "ChucK_manual.pdf", probably.
You might also want to have a look at mini audicle, that one makes things a bit easier. _________________ Jan |
kruhft
Posted: Thu Oct 25, 2007 12:39 pm Post subject:
ChucK is a bit different in that it's a programming language, so it requires a bit more knowledge to make it produce some sound. You should (as said) read the Manual, but that doesn't help to much when you have no idea of what you're doing, so first it's best to look at some examples. You can find some (including a couple of mine) up on the Wiki:
http://wiki.cs.princeton.edu/forums.html/ChucK
Look under Sounds to find some examples. You can also find some Tutorials and a bunch of other nice documents up there.
As the above poster said, there are interfaces for ChucK such as MiniAudicle/Audicle that make working it a bit easier for the beginner. Once you get the hang of actually writing code and how to work the command line bit you can move on to using Emacs/VI (programmer's text editors) and some actual shell code to take you to the next level, but you have to crawl before you can run
Hope this helps. _________________ http://www.myspace.com/kruhft
http://kruhft.info |
Inventor
Joined: Oct 13, 2007 Posts: 1416 Location: Florida, USA
Audio files: 54
Posted: Thu Oct 25, 2007 2:32 pm Post subject:
| I had trouble navigating the Wiki, I couldn't find a table of contents anywhere. What am I missing? |
kruhft
Posted: Thu Oct 25, 2007 2:41 pm Post subject:
That was a link to the table of contents. The wiki is a bit wierd; use that link as your starting point. Check out the 'Sounds' and 'Tutorials' link on that page. _________________ http://www.myspace.com/kruhft
Inventor
Audio files: 54
Posted: Thu Oct 25, 2007 2:53 pm Post subject:
| kruhft wrote: | | That was a link to the table of contents. The wiki is a bit wierd; use that link as your starting point. Check out the 'Sounds' and 'Tutorials' link on that page. |
Oh, duh on me, I didn't even check your link, I was just remembering going to it before and not finding stuff. Thanks. |
Nalaregeork
Joined: Oct 26, 2003 Posts: 17 Location: South East New York
Posted: Thu Oct 25, 2007 6:52 pm Post subject:
| I think if someone is not comfortable with ChucK starting with mini Audicle is a good possibility, in conjunction with reading the manual as already suggested... |
