  Muied Lumens Frequencies
 Forum index » Instruments and Equipment » OSX as a music workstation
Macbook wirelesss speed
Page 1 of 1 [18 Posts]
BobTheDog
Audio files: 32
PostPosted: Tue Nov 06, 2007 3:59 am    Post subject: Macbook wirelesss speed
Subject description: Should it be this slow.
Hi Guys,
I am getting about 200KB/sec over wireless, wired I get the normal 10-11MB/sec.
I would expect to at least see 2MB/sec over wireless, is this something Macbooks suffer from?
Andy
PostPosted: Tue Nov 06, 2007 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I´ve never seen anything that slow. The MBs and MBPs are just fine when using the built-in wireless cards. Is this on your own private network?
BobTheDog
Audio files: 32
PostPosted: Tue Nov 06, 2007 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep private network, about 1 metre away from router which is a NetGear DG834N, signal strength on the mac is at full.
I have looked into it a bit more, FTP speed is very fast over wireless:
ftp: 163613696 bytes sent in 18.53Seconds 8829.19Kbytes/sec.
This speed made me check that the ethernet cable wasn't plugged in!
So the issue I am getting is when you use OSX copy.
I am carrying on investigating
Andy
PostPosted: Tue Nov 06, 2007 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
OK.. OS X copy.. so you are copying stuff from another mac or pc on a shared volume??
I´ve pretty much ditched non Apple wireless basestations here. The Apple basestations are reasonably good, I get updates to the base station software/firmware from one source and the compatibility is really quite good. I don´t know much about Netgear stuff, some of the products I´ve used have been good and others not so good. Does the basestation device have some sort of port management/firewall?
BobTheDog
Audio files: 32
PostPosted: Tue Nov 06, 2007 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I am pretty confused now!
OSX copy is now manageing 6-7MB/sec over wireless, I didn't change anything at all.
I do get a huge cpu hit though, kernal_task is sitting between 50% and 70% which seems a little high for a network copy!
I will keep an eye on it, thanks for your help.
Andy
PostPosted: Tue Nov 06, 2007 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, I dunno... from which machine are you actually copying stuff?
A mac and which OS version? How is it connected and which type of filesharing?
PostPosted: Tue Nov 06, 2007 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
If you copy a huuuuuger number of small files you will see a nasty drop in speed. In those cases I will always use tools that stream the files as one.. or zip or rar the folders and then copy the compressed version to another machine.
Copy across a LAN of some medium sized to big files is mostly unproblematic. OS X is pretty stable and I´ve seen few problems. There can be certain issues if the AFP settings on the server are weird.. but that is probably not the case here.
PostPosted: Tue Nov 06, 2007 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah FWIW, my wireless router is a cheapo unit made by ASUS- and I get this shit all the time. I don't know what it's like with an Apple router, maybe there's some protocol built into Apple products? But the wireless at the university is a lot better- despite it still being in the 'b' & 'g' category.
ACHTUNG!
PostPosted: Tue Nov 06, 2007 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
AFP is using the AFP protocol, and there just might that cheap PC oriented routers/base stations for some mindless reason will cap AFP speeds.
PostPosted: Tue Nov 06, 2007 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
again, Andy fwiw, I've had nothing but problems with Netgear stuff and Macs. The router before was a netgear. It worked fine with Windows, but hated my previous Mac, so it had to go. Perhaps it's another Microsoft partnership conspiracy ?? Laughing
This ASUS one is pretty good- especially with Intel, but then asus make decent Intel based motherboards too. Their internet service is bobbins though Sad
ACHTUNG!
BobTheDog
Audio files: 32
PostPosted: Tue Nov 06, 2007 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Guys,
It seems to be going really well now so Christ knows what was going on before.
I have been really impressed with this NetGear router though, this is the first issue I have seen. We have a couple of other laptops, Wi FI Printer, a Playstation 3 and a Nintendo Wii useing it with no issues.
I will keep an eye on it.
Andy
PostPosted: Tue Nov 06, 2007 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I use a D-Link "Gamer Lounge" (or something), and I have issues sometimes with the wireless connection dropping out from my MacBook Pro. There is one spot that used to be OK, but then it started to act up constantly, so I plugged in an ethernet cable instead. That spot is close to the router (2 meters), but there is a thick brick wall in the way, so I figured it was due to that, even though there is a doorway less than half a metre off the line between the router and the Mac.
Can other WLans nearby cause these kinds of disruptions? There are loads in my block of flats...
/Stefan
PostPosted: Tue Nov 06, 2007 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
yes that's true. There are 3 routers on our Avenue (when I say 'avenue' I'm not talking about those American-style 'avenue's btw Laughing ). Actually mine isn't security locked- it's open (yes I knew that one would send a few shock waves!!). As a matter of fact, one day there were 5 or 6 people all on our line together, so I logged into the router and one of them was playing on some sort of games console Shocked So after that, I've just 'allowed' certain people on and not others.
btw, my bank balance and PayPal accounts are still kosher - so much then for that bloke in the bushes with their laptop then......? Rolling Eyes
btw, there is a brick wall between me and the asus- but it's only about 4 inches wide Confused
ACHTUNG!
Audio files: 218
G2 patch files: 319
PostPosted: Tue Nov 06, 2007 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes very well. For the .g variety it is advised to have a five or six channel distance between nearby WLAN routers - near impossible in an apartment building (it would mean (for .g again) that effectively only channels 1, 6 and 11 should be used when other routers are around, for all parties involved).
PostPosted: Tue Nov 06, 2007 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
what about the 'n' variety?
ACHTUNG!
Audio files: 218
G2 patch files: 319
PostPosted: Tue Nov 06, 2007 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
dunno, never looked it up, I don't have any n stuff except for the wlan router itself (an apple thingie btw Very Happy ).
PostPosted: Tue Nov 06, 2007 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Same there, a very high density of base stations will lead to a mess and reduced speed.
Depending on the gear, you could see sets of basestations and clients set to handle stations on "auto" to go into change and seek modes. It´s kinda fun to see say 40 sets of basestatioons/clients all go into the "find a free channel" stupor at the same time.
BobTheDog
Audio files: 32
PostPosted: Wed Nov 07, 2007 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
The netgear I have here is 'n' as well as the Macbook, this is why I can see 8MB/sec over wireless, around 80Mbit/sec which isn't too bad.
The router is set at 270Mbit/sec but I don't know what the max on the mac is.
Andy
