HOW TO PLUG a Kenton SOLO to METASONIX Wretch Machine ?
Page 1 of 1 [11 Posts]
sallyjackmei
PostPosted: Thu Nov 08, 2007 3:02 am    Post subject: HOW TO PLUG a Kenton SOLO to METASONIX Wretch Machine ? Reply with quote  Mark this post and the followings unread
I don't succeed in playing keys with my Kenton.
Only one sound everytime, on each keys!
How ti plug it ?
Thank you
tiny333
PostPosted: Thu Nov 08, 2007 5:14 am    Post subject:   Reply with quote  Mark this post and the followings unread
i know its a silly question but you have both the trigger and cv jacks connected?
mono-poly
PostPosted: Thu Nov 08, 2007 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
You can only play one note at the time.
Polyphonic won't work.
And i think you need a volt/hz cv connection to get a proper tuning.
tiny333
PostPosted: Thu Nov 08, 2007 6:50 am    Post subject:   Reply with quote  Mark this post and the followings unread
or to put it another way
come out of the gate out of the kenton plug it in to the trigger in on the left of the wretch
also
come out of the hz/v cv output of the kenton and plug that into the pitch cv in on the far left of the wretch
you will then have 2 jacks going into the wretch and hopfully at long last a fully functioning unit !!!
sallyjackmei
PostPosted: Thu Nov 08, 2007 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok now it works
But still have a problem for the Tune!....
I can't play with true Tune in an octave!... Just 4 or 5 keys are OK...
Higher is out of tune!
tiny333
PostPosted: Thu Nov 08, 2007 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
or you could be sending notes to high or lo?
i dont have a kenton so dont know if it could have a transpose set?
tiny333
PostPosted: Thu Nov 08, 2007 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
lol welcome
Smile
http://www.muffwiggler.com/forum/topic-345.html
tiny333
PostPosted: Thu Nov 08, 2007 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
the fun of it for me has been finding the wretches strengths and learning how to use it
i dont know all the answers but can promise you that it is without doubt the most stunning sounding box i have ever come across.....
tiny333
PostPosted: Thu Nov 08, 2007 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
but you obviously have to tune each osc seperatley
and then if you change them have to tune them again....
you should get an octive or 2 in tune kinda ok... Wink
EdisonRex
Audio files: 168
PostPosted: Thu Nov 08, 2007 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
re: tuning.
The Wretch Machine is only capable of tracking about 2 octaves accurately.
You have to adjust the tracking as explained in the manual.
If you change ranges you will probably have to re-adjust the tracking.
You have to adjust each oscillator separately.
If you move the joystick and press down on it, do you get variable sounds?
Garret: It's so retro.
tiny333
PostPosted: Thu Nov 08, 2007 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi edison
think he/she has note control now
just a little freaked out by what that might mean lol
Twisted Evil Twisted Evil Twisted Evil
