Pointers for Atmel AVR uses?
Page 2 of 2 [32 Posts]
Goto page: Previous 1, 2
PostPosted: Wed Apr 11, 2007 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I started off using the stimulators myself, but found it much easier to just connect the switch on a breadboard, and make an LED blink. Once I had the basics proven, I started learning about the device more quickly by just doing it, and keeping my momentum (& excitement) going, rather than simulating things & stepping through all the code.
BTW - there is a free simulator that is included with WinAVR (simulavrxx) that one can use if you wanted to step through code just to see it.
bugbrand
PostPosted: Wed Apr 11, 2007 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool. I was only really interested in AVRstudio for the sim. (and I'm programming the chips via it too at the moment) so that's good if there's a WinAVR (simple) sim.
I now need to get going again 'cos I made the proto sequencer block - haven't tied it to the AVR dev. yet but its working as a block (four stages with a global range dial (c.1v range to 5v range) and glide ----- nice!)
http://www.bugbrand.co.uk
dave_b
PostPosted: Thu Apr 12, 2007 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
For me, the blinking LED was the biggest hurdle. After I was able to make the chip do something, it got much easier and more rewarding.
I use the simulator when I don't have the hardware handy (during lunch at my dayjob). I also use it to find bugs before they become an issue. On the downside, I've found it real easy to make a mess that appears to work in the simulator, but runs into a ditch on the hardware at 4Mhz. Maybe that's more of an assembler thing?
PostPosted: Thu Apr 12, 2007 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I can see the value in that. Especially if you're coding in assembly.
synth_ollie
PostPosted: Mon Nov 19, 2007 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking of building this
http://www.borg.com/%7Ejglatt/hardware/pc_keys/adapter.htm
myself I know nothing about avr/microcontrollers, but a guy I know
has the equipment/skills for programming it, but he says that he needs
the data in hexfile format, so I was wondering if someone here could help me to convert this
http://www.borg.com/%7Ejglatt/hardware/pc_keys/pckb.asm
into hex format, I guess you need some kind of software to do this ?
Audio files: 278
PostPosted: Mon Nov 19, 2007 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, you need an assembler to translate the assembly code into numbers that can be understood by the processor. The numbers can be put into a hex file and in that format most programmers can burn them into a chip. Usually one of the output file formats for an assembler for a processor like the AVR is hex.
I don't use AVR myself, but a quick google showed that Atmel has a development environment that seems to be down loadable (after registration) - that one should do the trick ( http://www.atmel.com/dyn/products/tools_card.asp?tool_id=2725 )
Another option would be to have a look at http://sourceforge.net/projects/avra
But probably AVR diehards have better suggestions for tools.
You should consider making your own development environment , as software is never bug free and if it were you still might want to modify it.
The AVR chip used in the link features in circuit programming, which makes it possible to program the device while it is in the circuit with relativley simple and cheap (serial, parallel or USB) interfaces (from your computer). This will enable you to modify the program and beam it up to the controller immediately.
The interface might even allow you to single step through your code to help you see where things go wrong - I'd be disappoited if it wouldn't allow for that Very Happy
synth_ollie
PostPosted: Thu Nov 22, 2007 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for your reply BH,
a person who is into this kind of software has now helped me out Smile
OLLIE
