Nord Lead 1 Factory reset?
Page 1 of 1 [10 Posts]
laserrr
PostPosted: Sun Jul 08, 2007 7:02 am    Post subject: Nord Lead 1 Factory reset? Reply with quote  Mark this post and the followings unread
hi
i wanted to know if i can have my Nord lead 1 rack reseted as i giot it from the factory?
is there a possibility?
cheers
laserr
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Jul 08, 2007 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
What's wrong with it?
Wout
laserrr
PostPosted: Sun Jul 08, 2007 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
nothing really wrong
but i would like to have the previous sounds..
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Jul 08, 2007 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you mean Factory sound 1 to 40, they are still in your machine.
Try Performance mode L0 to L9. In each location 4 Programs.
Take a look at [Manual page 106]
If this doesn't work, the Programs are in the electro-music.com Clavia user archives at
http://nm-archives.electro-music.com/020_NordLead2/
At
http://nm-archives.electro-music.com/020_NordLead2/023_Miscellaneous/NordGenerator_Editor/
you'll find a useful editor tool which also works on the NordLead(1). You can save your patches on the harddisk of your computer. Midi needed...
Wout
wizard
PostPosted: Thu Nov 22, 2007 2:28 am    Post subject: nord 1 reset Reply with quote  Mark this post and the followings unread
There is a way of resetting presets 1-40 to their factory settings. I have forgotten how its done. They told me in the shop when i bought it years ago as it wasnt in the manual. Its really simple. If i remember i will let you know. Actually, i will play around with mine today until i remember.
EdisonRex
Audio files: 168
PostPosted: Sun Nov 25, 2007 4:39 pm    Post subject: Re: nord 1 reset Reply with quote  Mark this post and the followings unread
welcome to the forums, wizard. I have a Nord Lead 1 too. If you remember, I'd like to know, I remember it was some poweron-with-buttons-pressed thing; I long ago forgot it.
Garret: It's so retro.
wizard
PostPosted: Mon Nov 26, 2007 5:37 am    Post subject: nord reset Reply with quote  Mark this post and the followings unread
I was too busy to mess around with my Nord the other day. I will try today being that you also need to know Edison. I dont recall it being a power on thing. Maybe it included going into performance mode and back because the factory presets are all duplicated in the performance banks. i will be on a mission to sort it today. I will let you know either way.
wizard
PostPosted: Mon Nov 26, 2007 8:01 am    Post subject: Nord Factory reset Reply with quote  Mark this post and the followings unread
Okay Edison Rex. Ive done it. Its as Wout Blommers referred to above. Heres what you do. Press shift, keep it held down and press performance. Use arrows to scroll up to L0 performance. If you press slot 1 you will see the preset thats stored within that slot. Slot 2 is the next preset and so on. So, press slot button 1 and you will see preset number, keeping the button pressed, hit store. the number of the slot where you are going to store it will flash. It will be the same number as the preset. Press store again and its done. Go to slot 2 and do the same again and so on The next 4 presets are in performance L1. Basically they are stored in performances L0 to L9. I just restored all of mine and its really inspiring to hear those sounds again. I forgot how fat some of them are. Good luck and enjoy
EdisonRex
Audio files: 168
PostPosted: Mon Nov 26, 2007 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, I don't think I ever heard that, although I swear someone showed me about 10 years ago. Thanks!
wizard
PostPosted: Tue Nov 27, 2007 5:07 am    Post subject: Nord factory reset Reply with quote  Mark this post and the followings unread
There is another way where you dont have to go in performance mode but i cant remember or figure it out. The way i showed you is still quick though. If i remember the other way, i will let you know.
