ReaktorFreak
Joined: Sep 28, 2007 Posts: 20 Location: Jakarta, Indonesia
Posted: Fri Sep 28, 2007 3:43 am Post subject:
Audio To Pitch/Gate and MIDI Converter |
Hi, this instrument i made convert monophonic audio sources to pitch/gate and MIDI, but the MIDI still had lots of problems. It is based on Frequency Tracker Instrument from library and i've customized it to receive signal from my electric guitar. Anyone kind enough to give it a try and tell me your opinion ?
The Instrument is now moved to the bottom of this page. Last edited by ReaktorFreak on Tue Nov 13, 2007 8:12 pm; edited 2 times in total |
ReaktorFreak
Posted: Sat Oct 06, 2007 7:21 am Post subject:
Hi, this is my latest update for Elektro Guitar. MIDI Out is now functioning but no pitchbend yet. Lots of stuff added. I also add a screenshot. Last edited by ReaktorFreak on Wed Nov 07, 2007 6:51 am; edited 1 time in total |
W.T.
Joined: Jul 11, 2004 Posts: 216 Location: The Netherlands
G2 patch files: 11
Posted: Mon Oct 08, 2007 3:58 pm Post subject:
this cool, thanks.
i am playing with it right now  |
ReaktorFreak
Posted: Thu Oct 11, 2007 2:27 am Post subject:
Thanks W.T. , hope you enjoy it as much as i do.
Fix some problems when changing control rate to other than 400 hz, and a lot better MIDI Out, although still not complete (no retrigger, PBend). I guess i just take a break for a while... coding MIDI is so frustrating. Last edited by ReaktorFreak on Wed Nov 07, 2007 6:51 am; edited 1 time in total |
ReaktorFreak
Posted: Sun Oct 14, 2007 11:54 pm Post subject:
Whew, finally i got my ins the way i wanted it. Everything's been working quite well and very playable, so i guess i could start my music project that has been left out since i started building my ins. Last edited by ReaktorFreak on Wed Nov 07, 2007 6:52 am; edited 1 time in total |
Luka
ReaktorFreak
ReaktorFreak
Posted: Tue Oct 30, 2007 8:23 pm Post subject:
Another try in building audio to MIDI converter.. i got the idea for this one from hearing guitarist talk about their hardware guitar synth, that they can play drums on low E string, bass on A string, trumpet on D string, and so on. It makes me wonder if i could build a MIDI converter that could function like their hardware stuff did.
Beside that, i also want to try the method of using static resonators, unlike my prev ins that based on Frequency Tracker Ins' moving resonator. This method results in very accurate pitch tracking that there's almost no glitches at all, which i think that will simplify the MIDI function to 'understand' the pitch data, because the pitch from audio input is sort - of - quantized by the resonators.
On the downside though, the pitch from audio input has to be almost perfectly in tune to be recognized by the resonators, and the 'infamous' audio to MIDI latency also occurs in the conversion.
Maybe anyone knows other method/technique for tracking pitch ?
| Description: |
 Download |
| Filename: |
MIDI Slot Machine v0.5.zip |
| Filesize: |
100.25 KB |
| Downloaded: |
89 Time(s) |
ReaktorFreak
ReaktorFreak
ReaktorFreak
ReaktorFreak
ReaktorFreak
Posted: Tue Apr 29, 2008 1:38 am Post subject:
Another monophonic pitch to MIDI converter, in this one i try different approach on 'translating' the detected pitch into MIDI data (note on/off, pitchbend, velocity). And because it transmits MIDI signal, it can be used to control external synth like VSTi or recorded in a sequencer.
| Description: |
 Download |
| Filename: |
MIDI Translator v1.12.zip |
| Filesize: |
504.3 KB |
| Downloaded: |
40 Time(s) |
| Description: |
| A MIDI file created with regular electric guitar and the Ens/Ins, recorded in realtime without further editing (such as deglitch) |
 Download |
| Filename: |
Demo (MIDI file).zip |
| Filesize: |
4.32 KB |
| Downloaded: |
4 Time(s) |
Last edited by ReaktorFreak on Wed Sep 03, 2008 5:22 am; edited 2 times in total |
ReaktorFreak
