Escobedo Q&D VCF goes chaotic
Page 1 of 2 [39 Posts]
frijitz
Audio files: 54
PostPosted: Thu Nov 29, 2007 9:12 pm    Post subject:  Escobedo Q&D VCF goes chaotic
Subject description: Can your VCF do this?
Yes folks, it's real. If Tim Escobedo's Q&D VCF:
http://www.geocities.com/tpe123/folkurban/fuzz/simplevcf.gif
is overdriven a bit it goes chaotic.
The circuit I used is almost the same as Tim's, except that it is run from a 12 V supply. With low Q (10 k on the resonance pot) and 0.6 V peak drive (from a TRI VCO) a sweep of the drive frequency produces a series of period doublings followed by a chaotic region (even with the usual small windows of periodicity!) followed by a final period undoubling. The attached file is a recorded sweep.
I've checked quite carefully that this is real and not just an artifact. The chaotic pattern depends on the type of diode used and goes away if the diode is substituted by a resistor. In the latter case, the filter looks like a bandpass filter driven into clipping, as expected.
Analyzing the circuit and simulating its response would be a fairly tedious job. But the necessary conditions for chaos are there: the system is of third order (with the drive included) and the diode provides the necessary nonlinearity.
This encourages an idea I've had for some time: to make a combo module that will operate as either a filter or a chaos generator. This now looks within reach.
Many thanks to Graham Meridith for pointing out this circuit, to Tim for a patient discussion of the filter's operation and to Scott Stites for pointing out that the MS20 filter has some unusual multiphonics when overdriven.
Ian
filt_ch02.mp3
 Filename:  filt_ch02.mp3
 Filesize:  379.31 KB
 Downloaded:  1508 Time(s)
loss1234
PostPosted: Thu Nov 29, 2007 9:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
so you did nothing to the circuit except change to a 12v supply?
I have been interested in non-linearity for a long time and I see that you have mentioned many times that diodes have non-linear properties. So is it possibe to add chaotic elements to circuits by replacing resistors with diodes? Or do you really need to approach this from a math standpoint?
I ask because I am wondering if there are ways to take MORE pre-existing circuits and push them toward chaos.
thanks for all your work into chaos circuits. I only hope my skills catch up to my interest in this field.
Tim Escobedo
PostPosted: Thu Nov 29, 2007 9:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow. That's a pretty neat bug/feature. I can't even begin to account for that behavior. If only I knew about it earlier. Smile
I'm curious. What kind of op amps are you using? I almost universally use plain low powered TL06x chips. Occasionally TL07x series. I noticed the SK quad filters were 5534 I think. I have in the past treated op amps rather generically.
frijitz
Audio files: 54
PostPosted: Fri Nov 30, 2007 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
No significant changes. The feedback network is the same, except for 450p instead of 500p for the small cap. (A larger cap actually gives a more dramatic chaotic behavior.) The CV input is not connected. The freq control has a bypass cap, but it doesn't make any difference. The bypass cap at the Vcc/2 supply is left off, but that doesn't make any difference either. The audio coupling cap is 0.1 instead of 0.01.
In general, chaos only occurs under special conditions, so just throwing some nonlinear element into a circuit usually doesn't result in anything interesting. That's why I was so surprised to see chaos in this circuit. Most of the work I have done with chaos is based on systems that have been studied previously.
Ian
frijitz
Audio files: 54
PostPosted: Fri Nov 30, 2007 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, i didn't expect the chaos at all. At first I thought I was just having trouble with my scope triggering. But triggering off the input signal straightened me out on that.
I used an LF351 (similar to TL071). I also threw in an older slow opamp (BB3500, similar to LM307), but other than the slower slew rate it worked the same. So I don't think there is any major contribution from an opamp pole or anything weird like that.
The signal is different from anything I have seen before. As the input signal crosses zero from below, the opamp slews very rapidly upward, usually clipping. Then the decay of the waveform is much slower. So the opamp clippping may be an important part of the systems nonlinearity. Not sure about that at this point.
Ian
frijitz
Audio files: 54
PostPosted: Fri Nov 30, 2007 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've looked at this interesting circcuit a bit more. After reducing the input drive to +/-50 mV there is still nonlinear behavior. As the driving frequency is increased there is a resonance when f = f0 (the main resonant frequency) then around f = 2f0 the period of the output signal doubles and there is another resonance at f = 2f0. So the resonance occurs twice at the same output frequency but for input frequencies of f0 and 2f0. I'm surprised nobody has noticed this before. I have checked all the wiring and the component values very carefully. Well, perhaps it's the larger supply voltage.
Ian
frijitz
Audio files: 54
PostPosted: Sat Dec 01, 2007 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
A little further work on this interesting circuit. I tried it powered by a 9V battery and I seems to behave about the same as with 12V. Adding a small resistor in series with the diode reduces the tendency to chaos and rounds off the waveform a bit. A scope shot of the attractor seen with a 1 k series resistor is attached. The two signals used were the output and the voltage at the top of the diode. It's a very interesting shape. I can't recall seing an attractor quite like this before, although I can't quite follow how it is folded.
Ian
 Filesize:  22.02 KB
 Viewed:  28036 Time(s)
loss1234
PostPosted: Sat Dec 01, 2007 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow.
i need a scope!
ordered those parts for the chaos circuits today.
hopefully next week i can start learning more about this.
thanks as usual for the great info
StephenGiles
PostPosted: Sat Dec 01, 2007 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Our dog was quite alarmed at the noise!
gmeredith
PostPosted: Sun Dec 02, 2007 9:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Frijitz,
You seem to really be developing something here! If you can figure out just what makes the chaos, it would make a great bend for the Casio SK Phat Philter he he Very Happy
Did you build the filter straight from Tim's schematics, or from my Phat Philter plans? I'm trying to find out what the difference must be. What op-amp are you using?
I did come across an anomality while designing the board. I found that a TL071 op-amp has a dead zone when you turn the cutoff 100K pot below, say, 1 quarter. it just seemed to mute. Other op-amps didn't show this behaviour.
I had the input attenuated a fair bit for line level input, so I didn't have it overloaded to see what it would have done otherwise. Interesting.
Cheers, Graham
frijitz
Audio files: 54
PostPosted: Sun Dec 02, 2007 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Graham -- As discussed some above, I have looked at a number of variations of the circuit, including different opamps and supply voltages. I RE'ed your layout, and it seems to me basically the same circuit as the original. There is no chaotic behavior when the diode is replaced by a resistor. So the diode is actually doing two things, I believe: (1) it acts as a tunable resistance in the twin-T network (as intended) and (2) it acts as a nonlinear circuit element, thereby inducing the chaotic behavior. It would take some fairly tedious numerical analysis to show that the chaos is expected, but it really doesn't seem all that improbable (in hindsight!). If you have the means, you might try driving it a bit harder to see what happens in your setup.
Ian
loss1234
PostPosted: Thu May 08, 2008 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
ian
i have been building this circuit and I wanted to know if you bothered using the VR bias (when you used a 12v supply)
in other words, on tims original schematic he shows a SINGLE supply being split in half and then fed into the 1m vr resistor going into the +input. did you emulate this with 12v or just skip it and use bipolar?
one thing i noticed (and most likely why tim included the trimmer) is that the circuit distorts very easily, and not in a very pretty way either. is this the key? just overdriving that input? i can tell already that this has a much stranger response than my other filters.
thanks
(scope is coming this week!)
frijitz
Audio files: 54
PostPosted: Thu May 08, 2008 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Both. I used 0/12V (and 0/9V) with the split, and I used +/-12V without it.
I dropped working on this, as the Threeler was much more interesting.
Ian
loss1234
PostPosted: Thu May 08, 2008 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
well then i must buy the threeler pcb!!
BUT i am working with this for a 9v battery powered circuit
Mikmo
PostPosted: Thu Sep 04, 2008 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to revive an old thread, but did anybody design a PCB for this filter?
If so i would really like to see / buy it.
Thanks
Mikael
Stay Cool
Mikael
http://www.mikmo.dk
PostPosted: Fri Sep 12, 2008 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
i have to confess: i don't get it from the schematic Shocked
if i use the split i get a virtual ground labeled Vx, right? where does this apply to the circuit? what does Vr mean? why is the attenuator wired to the ground symbol when i split the supply?
i would have expected the following:
using the split, the attenuating pots are wired to virtual ground Vx. same applies to the 1M resistors at the positive OpAmp inputs. freq control potentiometer goes from +V to ground (actual the virtual -V)...
maybe i am a little bit dumb, but i don't understand the schematic here, so any explanation is appreciated.
fonitronik at
PostPosted: Fri Sep 12, 2008 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Where is the schem?
jnuaury
Audio files: 9
PostPosted: Fri Sep 12, 2008 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
Where is the schem?
frijitz
Audio files: 54
PostPosted: Fri Sep 12, 2008 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't see any Vx on the schematic. It's an odd circuit, but it goes chaotic under a variety of conditions.
Ian
PostPosted: Fri Sep 12, 2008 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
right. i misread the Vr in the split circuit for Vx, due the serife font Rolling Eyes
however, i would have expected the attenuating potentiometer on the audio input to go to Vr then. isn't Vr the virtual ground here?
fonitronik at
frijitz
Audio files: 54
PostPosted: Fri Sep 12, 2008 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right. That's just how Tim's circuit is. The circuits I did with unipolar and bipolar supplies were not equivalent to each other. But both showed chaos. Whiteboard it up and try it!
Ian
PostPosted: Fri Sep 12, 2008 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ian
thank you ian. i will do that. again you gave me some good answers today (as always) - thank you very much.
fonitronik at
alcofribas
PostPosted: Sat Nov 07, 2009 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Geocities has been dead for a while now, can somebody post that mysterious schematic again?
Thnx
Alcofribas
andrewF
PostPosted: Sat Nov 07, 2009 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
this is a version I used for getting chaotic signals
pretty sure the only change is the CV input was removed and R9 (1k) was added (Ian Fritz's suggestion).
To add a CV input just connect it via a 100k resistor to the junction of D1 and R2. You can leave in R9 if you like.
Doesn't matter what op-amp, any will do.
q&dschemo.pdf
 Filename:  q&dschemo.pdf
 Filesize:  40.59 KB
 Downloaded:  853 Time(s)
crochambeau
PostPosted: Sat Nov 07, 2009 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I too am interested in the chaotic version, the attached files does not come through... (edit, as soon as I open my mouth I'm proven wrong..)
How's it different from the schematic culled from archived geocities?
http://web.archive.org/web/20060402010333/http://www.geocities.com/tpe123/folkurban/fuzz/simplevcf.gif
http://crochambeau.blogspot.com/
